Question about One For All URC-3415 Remote Control
TV was at Lock Mode How could I unlock the system.
We mislaid the original remote
control please advice
    Genius:
  • 1,847 Answers
Is this chid lock you are talking about, also let me know the make and model no of tv.
Posted on Mar 10, 2009
    President:
  • 987 Answers
Http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/one_for_all/urc3415-manual.zip&area=other
i had the very same problem go to the site above and click "clickhere if doenload bar does not appear' and then down load the manual andscroll down to find you tv and write down the numbers and then go toyour tv and press tv hold down the magic button for 3 seconds or untillit flashed twich form the start of the list type in the 4 digit numberone at a time and then press power off if it turns off then you no ithas worked.
good luck.
  • 10,515 Answers
Model, brand, of the televison?
Thanks for using Fixya.
    Sergeant:
  • 300 Answers
You will require the orignal remote or get the universal remote from local electronics shops with codes.it will support all types of tv.
  • 13,433 Answers
I can look for a replacement remote, what is the model and brand of your television
My TV model is co21slu250bb ,onida ultra slim.what is the remote number I need. Volume lock is on and hotel mode is on.
To unlock it and to release the Hotel Mode option to normal mode, you have to enter its service mode. To get into its service mode, you should have its original remote control. No universal remote control will go.
To buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
http://electrohelponline.blogspot.com/
Visit this site to know more about how to enter and adjust the service mode. Service mode entry and adjustments to many popular brand TVs and other devices are given.
See the site in Magazine view.
Jul 03, 2016 | Ultra Televison & Video
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
Awa lcd ltw32ds
You need the original remote control to unlock the TV.
Jan 01, 2018 | Televison & Video
Need a replacement remote control. also tv is stuck on child lock
Hello
If the tV is strucked at child lock, you must have its original remote control to unlock it. Just contact the nearest Maganvox authorised service center for details.
Mar 01, 2012 | Philips Magnavox 27MS343S 27" TV
Is RCA 24V511T digital or analog? Also can I use a universal remote or do I need the replacement for the original remote that came with it? I
Hello
This CRT based tV is an anlogue one. You can use a universal remote control, except to unlock the FPA lock to this TV. By anyway, this TV has been locked with FPA lock, you must have its original remote control to unlock the lock. You can use most of the RCA universal remote controls with this TV.
RCA RCR 311W will be better. The setup codes are:
1000, 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097, 1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1146, 1149, 1171, 1205
OK.
Sep 22, 2011 | RCA 24V511T 24" TV
Replaced batery in key fob and now there is no connection between fob and security system...I can lock and unlock doors with the key and I can start car ...fob doesn't work; does not lock or unlock...
reprogram the remote transmitter. first leave driver door open all other doors closed,key removed from the ignition switch. insert key into the ignition switch,then remove it.press lock and unlock on the vechicle door lock control switch at 1 second intervals 5 times. close and repoen drivers door.press lock and unlock on the vechicle lock control switch at 1 second intervals 5 times. insert key into ignition switch. switch ignition on and off twice to program a remote transmitter code whilst erasing the original codes or three timre to check how many remote transmitters are currently registered.remove key from the ignition switch.system should now lock and unlock.twice to indicate programming mode or one to four times,slowly to indicate number of remote transmitters registered.for the solara press and hold lock and unlock remote buttons together, press lock remote button for a second period of 1 second. system should now lock and unlock vechicle.once to confirm, twice to indicate registration has failed.if required repeat button procedure to program remaining remote transmitters.note to exit programming mode close drivers door or insert ignition key.maximum of 4 remote transmitters can be programmed.if akk failed let dealership reprogram remote transmitters.
May 18, 2011 | 1999 Toyota Camry Solara
The television has somehow gone into child lock mode and we have no remote control. Please advise how this can be removed without using the remote or please could you supply an unlock code which can be...
Unlocking child mode lock it is very difficult and nearly impossible without the tv original remote and the secret password word.Tries tv unplug,replug the tv back like about 24 hrs later.That all u could do,some tvs will reset itself and erase the password.
May 07, 2011 | Televison & Video
Programming a 1995 toyota avalon key fob
To program a remote... note that you must not delay more than 10 seconds between any of the operations.
Driver's door open, all other doors closed, key removed from the ignition switch.
Insert key into ignitions switch, then remove it.
Press LOCK then UNLOCK on the vehicle door lock control switch at 1 second intervals 5 times.
close and re-open drivers door.
Press LOCK and UNLOCK on the vehicle door lock control switch at 1 second intervals 5 times
Insert Key into ignition switch.
Switch ignition ON and OFF once to program a remote transmitter code while retaining the original codes or twice to program a remote transmitter code while erasing the original codes. three times to check how many remote transmitters are currently registered, or 5 times to erase all registered codes.
Remove Key from ignition switch.
System should now lock and unlock vehicle. Once, twice or five times depending which mode has been selected. It will lock and unlock one to four times slowly, to indicate the number of remote transmitters registered if you chose option 3.
Press and hold remote transmitter LOCK and UNLOCK buttons at the same time.
Press LOCK remote button for 1 second: System should now lock and unlock vehicle once to confirm, twice to indicate registration has failed.
NOTE: to exit programming mode, close drivers door or insert key in the ignition.
NOTE: a maximum of 4 remote transmitters can be programmed
Oct 13, 2008 | 1995 Toyota Avalon
Child lock
you will need your original remote control and go through the menu to unlock it. find your original remote control by typing in your TV model number in the search on www.replacementremotes.com and your original remote will pop right up. very easy to use.
May 31, 2008 | Philips Magnavox Learning Universal Remote
Blue screen and red padlock
It sounds to me like a child lock function, which is usually what the screen + padlock is on TVs. Usually your original remote would have a button / sequence to unlock the mode. If you still have your original remote, look for a child lock button or refer to your remote manual (and/or TV manual for the child lock feature) to unlock the mode.
Jan 24, 2007 | Haier HTF27R11 27" TV
One For All URC-3415 Remote Control Logo
52 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
