Question about Kenmore Microwave Ovens
The fuse keep burned every day I do replace the fuse, what is the wrong with my Kenmore micrwave 565.61589011 model. Thank you
Chances are that you have a common connection with another plug. Microwave, Fridge etc.. Even if it's not the same plug it's still "In line" meaning that both outlets are on the same breaker. A: Find another outlet to plug your Microwave into or B: Put a surge protector in between the Microwave and the outlet.
Posted on Mar 10, 2009
Kenmore 721-89972590 micrwave oven
Take the cover off. Make sure you unplug it. You will see the fuse close to where the wire goes in. Replace and but back together.
Mar 31, 2013 | Microwave Ovens
Whirlpool microwave no power
not sure about this particular model but mos micrwaves have a fuse inside of them. Remove the screws for the back or side cover and check the fuse
Apr 07, 2012 | Microwave Ovens
The model R1750 Has no power. There is power at the wall outlet. is there a reset or way to get micrwave on?
I expect you will find the door interlock switches caused the main fuse to blow.
Check and replace the faulty switches.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 14, 2011 | Sharp R-1750 Microwave Oven
Model 63259 bought about 2 months ago. I went to
you can check and see if there is a fuse on the microwave, if not it may have just burned out, its probably still under warranty so try to take it back for a replacement
Jan 14, 2010 | Kenmore 63252 Microwave Oven
Kenmore Over the Range 1000 watt Microwave with no power.
I have the same problem now did you come up with anything for this model
Jan 05, 2010 | Kenmore Microwave Ovens
Kenmore micrwave overheated. now won't work. is
There is a fuse inside the chassis that can be accessed by removing the 4 side screws and the 6 back screws on the chassis cover. First unplug the unit then remove the 6 screws securing the cover to the shassis. Once the screws are removed lift the rear of the cover about 10 to 15 degrees and pull to the rear. The chassis cover will then come off. NOTE: There is a large capacitor inside the chassis that will stil have a charge. Make sure to avoid it when reaching inside the unit. Follow the power cord from where it enters the chassis to the end terminals. One of them will terminate at the fuse holder. Remove the fuse, obtain a new fuse of equal value amd intall same. Plug the unit in to see if you get some from of power be it a light inside or the contral panel lighting up. If it is just the fuse and you see signs of the unit having power once again unplug the unit and re-install the chassis cover.. Make sure that the cover interlocks on the front of the chassis properly. All mating surfaces should appear flush. Re-install the 6 screws and retun the unit to service. If nothing happens please reply to this post.
Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
May 23, 2009 | Microwave Ovens
MY SAMSUNG MW6574W OVEN FUSE BLOWS AFTER 4-5 MINS OF REHEATING-NO SMELL OF BURNING -EVERYTHING ELSE WORKS FINE- NO LOOSE WIRING-ALL BULBS WORK FINE TOO- THE FOOD HEATS UP FINE EXCEPT THAT THE FUSE BLO
the insulation of the wiring has detiorated and with temperatue rising it further deteriorates. thus increasing the current consumption and blowing the fuse
May 21, 2009 | Samsung MW6575G/MW6574W Microwave Oven
Microwave Ovens Logo
153 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
