Question about Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV
Sony Bravia KDL-46Z4100
I have a green vertical Line on right side of screen I was watching a movie whan it just appair I change the channel to make sure it's not the recever i change input but line is still on screen need help fixing TV PLEASE
  • 59 Answers
If the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
Posted on Mar 10, 2009
Sony tv KDL-40S4100 vertical lines on right side
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 09, 2015 | Sony Bravia KDL-40S4100 40 in. LCD TV
My Sony Bravia picture turns green.
check cable, if its using an HDMI, replace it: if component RGB cable, reseat or replace.
Oct 03, 2015 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
I have a sony bravia tv which i have had about eight years. four vertical lines have appeared in the bottom right hand area of the screen. one long red line one long green line. and two short lines on...
Jan 18, 2015 | HCDZ General Remote Control Fit For Sony...
Sony Bravia KDL-46Z4100 46 in. LCD HDTV TV does
Probably its not a problem. On the menu You should have a Headphone audio level control (when needed you can mute the set speakers and still have headphone audio).
Oct 10, 2013 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Needs some help figuring out what causes colored vertical lines on an lcd panel on model kdl-46z4100 sony bravia I have a picture of it but can't post it on here. I have a link of someone who actually has...
Plasma has a problem that if you do not use it for even a short period, the liquid inside the layers of the screen will get hard because of cold , it needs to be running or in room temperature. so kindly get it repaired by a TV expert if that's the problem , then you have to buy a new plasma..
thanks for rating Good luck
Jan 12, 2011 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
My kdl46z4100 has vertical black line on the screen
Unless it is spot on dead center of the set, you need to replace the LCD panel. In these models, the suspected TCON (time control) board might do the trick, but I've yet to have success with that board fixing a vertical line issue.
Hopefully you are still under manufacturer's warranty or have some kind of extended warranty, 'cause the price of that panel exceeds $1,500.00.
You could give a shout to Sony customer relations in the event you don't have a way to get the part paid for. Sony may ask that you pay for an estimate, in return for covering the part for you.
Jan 22, 2010 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
Sony Bravia 46Z4100 has a thin vertical red line on the screen
I assume that when you get the line you lose the picture, if so, you have vertical collapse, either a dry joint in the vertical section or capacitors or vertical I.C., I would doubt that the scan coil would be O/C as that is rare. if you can't do it yourself I suggest taking it to a repairer, as it should be an easy fix...Hope that helps...Phil
May 19, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line on left side of screen
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
Mar 10, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I have a Sony Bravia KDL-32v2500, 16 months old, a thin vertical green line has appeared just off centre. It is on all channels and all input sources. Any suggestions?
If it still under warranty, no cost will be there, but if its out of warranty, you have to pay to Sony (might be they give you some discount) because its problem in LCD Panel.
Aug 05, 2008 | Televison & Video
Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV Logo
753 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
