Question about Dryers
I'm trying to install a used Shell Electric Manufacturing (Holdings) Co. LTD. model U42 ceiling fan, however it appears that the internal wiring has been moved around and in some cases cut off. I am looking for an internal wiring diagram for this fan. I have been to SMC's website, but had no luck finding a wiring diagram. The fan is equipted with a 3-speed pull chain switch, a reverse switch and a rectangle with 3 wires coming out of it; I think this is a diode or capacitor. Can you help me? Confused.
  • 74 Answers
The black rectangle is a capacitor! there is no diode in a ceiling fan, usually the white wire is the common or neutral , the blue is for lighting and the black one is for the fan
Posted on Mar 10, 2009
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
I am trying to install a ceiling fan and from the ceiling I have a copper white and black wire. Now from the fan itself there is a black blue and white wire. Not sure where to connect the copper wire.
Good question, proper wiring is a crucial virtue that needs to be one hundred percent accurate.
Three wires showing from the ceiling lamp fixture harness, positive, negative, and ground.
The negative wire is the white wire,
The Hot wire (positive) is the wire of brighter color than known negative,
220V AC (alternating current) home wiring to(" duplex outlet switch, GFI switch, single/dual pole light switch, lamp fixtures,") the Hot wire or lead, is normally Black, the lighter color, or White is neutral or neggative,
Neutral wire (completes circuit) allows current flow to continue through to other parts of house, Alternating current.
The Ground wire is usually wrapped in green color, or unmarked copper.
The copper wire from the ceiling will need to be grounded to the metal bracket on the new light fixture, a gold or silver screw, sometimes tagged with green, is the proper grounding location, Any place on Metal not attached to ceiling bracket, Ground should be attached to metal on fan,
White wire from Fan is neutral, Negative.
Black wire from Fan is Hot Wire, Positive,
If Blue wire from Fan is Not Manufacture spliced, Meaning no Copper is exposed, Wire is not used, Blue wire is NOT ground,
If Fan has a light, Voltage from Hot Black wire will supply both light and fan functions,
Safety First.
flip off breaker switch to the room fan is being installed.
Doubble Check
Black^Black wire connection is secure.
White^White neutral wire connection is secure.
Ground is fastened securely to metal or wrapped under a screw.
Using splice caps is recomended, The plastic shell encloses the wire connection ensuring No stray copper is exposed, limits possibility of cross wiring.
Google the brand of fan being installed, and Check wire color code, and wiring diagram, Info good to have, and checking twice will only guarantee Lamp Fixture Install Well Done.
(Blue wire may be there for installing multiple ceiling fixtures in a loop circuit, so all controlled by same light switch.)
Enjoy Your New Fan,
Jos
Thoughts&Comments, encouraged jtobias1020@gmail.com
Mar 26, 2017 | Dryers
Belling Piano W H PALING & Co Ltd serial number 21714
Maybe 1908. That's a Beale Piano Manufacturing Co. number. The Beale Piano Manufacturing Co made several different brands in New South Wales. W. H. Paling & Co was one of many.
Nov 18, 2014 | Music
Is there fuse panel in 2008 shanghai shenke scooter
Here is a contact for the company:
If you want to contact us, please reference the contact information as below:
Factory Adress:SHANGHAI SHENKE MOTORCYCLE MANUFACTURING CO., LTD ZHEJIANG JONWAY MOTORCYCLE MANUFACTURING CO.,LTD.
Address: HOU RUAN,LU QIAO DISTRICT, Taizhou City, Zhejiang, China
Mr.Leo guan
MSN: guanjinguo@hotmail.com
E-MAIL:kinggo.guan@gmail.com
Mobile:+86-18501138727
May 18, 2014 | Cars & Trucks
I need a diagram to install a Westinghouse 3-way light switch (#77052) on a lighting fixture on the bottom of a ceiling fan. I did not do the removal of the light fixture so I don't know how it was wired...
If by a 3-way switch, you mean a switch with 4 steps of brilliance: off, low, medium, and high when used with a 3-way bulb. The black wire of the switch is connected to incoming power wiring hot wire. Most often also black. The red switch wire connects to the center contact of the lamp socket. The blue wire connects to the small pin connection that is physically between the center connection and the screw shell of the lamp socket. The screw shell is connected to the incoming white wire of the house wiring.
Dec 30, 2010 | Westinghouse Electric Ceiling Fan 3-way...
My ceiling fan, model, 5745, has a broken switch.
ANy electric store will have different switches (lowes and home depot do too) just make sure you bring the old one with you. The colors of the wires shouldn't make too much of a difference just the amount
May 15, 2010 | Aloha Housewares (93645) Ceiling Fan
Noisey Minka Aire Napoli ceiling fans
Minka fan are life time warrantied, have you tried contacting customer service... Minka fans motors have a very simply design... uninstall the fan... try balancing the fan on a table or some where that allows you to remove the shell that covers the main body of the fan... Carefully (someone that is very familiar with the electrical components.) soft wire the fan allowing you to see the motor as the blades turn... You will then see what is making the scraping noise... I may have some extra fan parts that you can easily replace... If you like to write me at payitforwardx2 @ gmail . com I am willing to try to further assist you...
Dec 27, 2009 | Minka Aire Ceiling Fan
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Again hello sir
Hi again,
Appreciate the direct "Ask Me"
I am afraid being a Chinese clone, there would be several possible firms including some not only in China but in HongKong or Taiwan. You could try:
  • Union Camera Ltd.;
  • Beelan Enterprise Co., Ltd. ;
  • Nebula Services Ltd.;
  • Qanstar Development Ltd.;
  • Computer Dynamics International;
  • cooptrade co.;
  • Games Ltd.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 28, 2008 | Apple iPod nano 3rd Generation
Ceiling Fan Electric
hi,
you may have two dedicated ceiling fan circuits coming out of that box, check to make sure theres not a black wire bunched up in the ceiling or cut off, or try this
1.white to white wires, and black wire and black with a white stripe to red wire out of ceiling for fan and light together operation
2. If you can find the black and the red and the white coming out of the ceiling then you may have two switches on the wall for that fan, red for black fan wire, black with white stripe for the to black out of the ceiling , white all together. try that combination
for separate light and fan control from the wall
good luck, and be careful
J
Aug 06, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Dryers Logo
799 people viewed this question
Top Dryers Experts
