Question about Sun Computers & Internet
What is swing components? - Sun Computers & Internet
  • 32 Answers
Swing is java library that provides basic GUI controls [also called widgets like buttons, checkboxes, labels, menus, etc.. You can use it to create a interactive application with nice interface.
More info here http://en.wikipedia.org/wiki/Swing_(Java)
Posted on Oct 12, 2009
WIRING FOR CID brush swing boom
    Wiring Harness for swing boom - Skid Steer Genius
    www.skidsteergenius.com/blogs/news/.../wiring-harness-for-swing-boom
    Aug 21, 2015 - Posted by Robert Leib in bobcat 7 pin cable for swing boom, CID ... The CID Swing Boom, Prowler Swing Arm & Spartan Articulating Brush ...
    WIRING FOR CID brush swing boom - Fixya
    www.fixya.com/cars/t26003553-wiring_cid_brush_swing_boom
    4 hours ago - WIRING FOR CID brush swing boom - Cars & Trucks question. images for WIRING FOR CID brush swing boom
Dec 11, 2015 | Cars & Trucks
1973 ford bronco speedometer broken at gage
age mainly need to get a quality remanned speedometer to fix this issue.
Jun 27, 2012 | Ford Bronco Cars & Trucks
I just want to no is there two washers on the back swing arm or is there only one on the chain carrier
I am unsure which washers you are asking about. You can go to the web site below and view an exploded diagram of the swing arm and rear wheel components. Do the "PARTS SEARCH BY MODEL" option. Please rate my answer. Thanks.
www.babbittsonline.com
Apr 07, 2011 | 1999 kawasaki ZX-6R Ninja
Error 59 co in 5550DN
Hello thanks for using fixya
59 C0 error code usually affects the printer motor. The problem can range from a couple of issues that occur within the printer's motor. It can also be a cartridge issue. Depending on the printer and which manual the user is referring to, the solution to fix this error varies.
  1. Error code 59 C0 due to problems with printer motor
  2. Error code 59 C0 due to problems with cartridges
  3. Error code 59 C0 due to broken back sliding lock
Error code 59 C0 due to problems with printer motor:
This is referred to as "developing disengaging motor rotation error" Most likely, this problem points to an issue with the function of the DC controller either it has failed or it has affected the developing disengaging assembly.The solution is quite simple and you may fix the error in a matter of few steps.
The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller).After connecting these two connectors to each other,you must replace the developing disengaging drive assembly directly.The final step is to replace the DC controller PCB, after which the printer is to be recalibrated.
Error code 59 C0 due to problems with cartridges:
Another more complex problem that leads to the 59 C0 error code is a problem with the cartridges.You must first remove all the printer cartridges in order to view the right swing guide. Once these have been removed, you must check for certain parts in the printer, which mostly resemble upside-down. If you finds that the swing guide does not move all the way backwards,then the most likely problem is a missing plastic component of the swing guide. This part also resembles an upside-down T.
Another problem that may cause the error to display is when the black sliding lock is broken out of place or missing its spring. If any of these cases, you must replace the swing guide completely. You should attempt to locate the missing piece within the printer so that it does not cause further problems in it. If the swing guide does function properly, then gently close the door, paying close attention to the right side of the printer's swing arm.If the right side swing arm closes in the same manner as the left side swing arm, then your printer is functioning just fine and you may simply need to turn it off to fix the error.If the right swing arm does not close properly, then the machine should be serviced by a professional to fix the problem.
I hope this solution will helpful 4 u
Please keep thumbs up in do Rating if it is helpful
THANKS & Keep Using fixya
Jan 10, 2011 | HP LaserJet 5550DN Printer
Swing kit for cobra 29 ltd bluetooth
It wil be the same for any 40 channel cb.. lower the bias and it will give it more swing. we make our own. for a cobra there are only 2 components. unless you want it a variable... and they only cost a few dollars to make. variables are little more because of the transistor and needing a way to control it. if you dont use an existing knob on the radio.
Jan 02, 2011 | Cobra 29 LTD CB Radio
Printer reports blocked paper,even without paper.
This is a very old printer, I dought you'll get parts for thi printer. Pull out the paper tray and check under the printer, there should be one or two swing sensors. it should swing both ways. If it does'nt then it's either out of position or broken.
Apr 24, 2010 | HP LaserJet 4L Printer
I have a DX929,with after-market upgrades including super Mod/swing kit 2w dead key swing to 37,Turbo echo Board ( Pro-trucker TRB1) it has a Mosfet final,it has Receiving an Mod. upgrades.My radio has...
Check Q37 (2SA473) a large TO 220 case style Transistor on the right side of the board when looking at the component side with the front of the radio facing you.
Also check D73 (7.3 volt zener diode) Q35 (2SC945), and D72 (MA27 W-A Diode).
Apr 10, 2010 | Galaxy Radios DX-929 40-Channels Base CB...
About java swing..
Hi, if you have a specific query about java Swing, I can try to help you. Please find a small java code with using swing as example.
import java.awt.BorderLayout;
import java.awt.Font;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.WindowAdapter;
import java.awt.event.WindowEvent;
import java.awt.event.WindowListener;
import javax.swing.AbstractAction;
import javax.swing.Action;
import javax.swing.ButtonGroup;
import javax.swing.ImageIcon;
import javax.swing.JButton;
import javax.swing.JCheckBoxMenuItem;
import javax.swing.JFrame;
import javax.swing.JMenu;
import javax.swing.JMenuBar;
import javax.swing.JMenuItem;
import javax.swing.JRadioButtonMenuItem;
import javax.swing.JToolBar;
public class ToolbarDemo extends JFrame {
public static final String FontNames[] = { "Serif", "SansSerif", "Courier" };
protected Font fonts[];
protected JMenuItem[] fontMenus;
protected JToolBar toolBar;
public ToolbarDemo() {
super("Toolbars & actions");
setSize(450, 350);
JMenuBar menuBar = createMenuBar();
setJMenuBar(menuBar);
setVisible(true);
protected JMenuBar createMenuBar() {
final JMenuBar menuBar = new JMenuBar();
JMenu mFile = new JMenu("File");
ImageIcon iconNew = new ImageIcon("file_new.gif");
Action actionNew = new AbstractAction("New", iconNew) {
public void actionPerformed(ActionEvent e) {
System.out.println("new action");
JMenuItem item = mFile.add(actionNew);
mFile.add(item);
menuBar.add(mFile);
toolBar = new JToolBar();
JButton saveButton = new JButton("Save");
toolBar.add(saveButton);
getContentPane().add(toolBar, BorderLayout.NORTH);
return menuBar;
public static void main(String argv[]) {
new ToolbarDemo();
Thanks and Regards,
Supa.
Mar 10, 2009 | Microsoft Internet Explorer 7
Honda vt1100 drive shaft problem
Hi, Sparkie43 the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Good luck and have a wonderful day.
Mar 06, 2009 | 1994 Honda VT 1100 C Shadow
Java project (core and advanced)
Hi I am Nitin Daharwal .. If you want make project in Java using Swing only. You may opt for these options 1. Java Image Viwer 2. Exam Simulator 3. Bulk E mail 4. Snake Game 5. Chatting Client 6.Inventory Mangement System you can mail at nitin.daharwal@gmail.com for any help ..
Happy Programming!!!
Sep 25, 2008 | Microsoft Windows XP Professional
Computers & Internet Logo
76 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
