Question about ZT Group CISNET A7050 PC Desktop
When i put in a CD or a DVD to play it makes a rrrrr.and clicking sound and when i press play it say no disc.....help....
  • ZT Group Master
  • 3,051 Answers
Hi there
you can try to get some canned air and blow it out really good but it sounds like to me that it may be starting to fail and you need to replace it sorry.
Posted on Mar 10, 2009
  • Michael Thomas
    Michael Thomas Mar 10, 2009
    hi there again you can also open the tray and get a flashlite and see if there is somthing small in the drive and try to remove any obstructions ok hope this helps a little
  • 135 Answers
Check the physically the CD rom inside your computer, Make sure that the power cord is connected properly and the IDE cable.
My dvd combi is saying invalid disc and sounds like its spinning but then makes a clicking noise
Make sure the disk you put in the player is compatible with what is in the manual. Don't try to use disks you burned yourself when the manual does not say it is compatible with CD R or DVD R + or -
And when it is compatible with CD / DVD R, put the files on the disk in a format the player can read. Don't try to play MP4 disks, because almost no MP4 format is compatible with w DVD player.
Jan 14, 2015 | Televison & Video
I have a memorex 700MB dvd/cd , i made a video for my family for christmas and ever type i press burn it says disc type mismatch... i need help! please.
You need to use a DVD+R disc or a DVD-R disc to burn a video. It sounds as if you have made a DVD type video and put a CD-R in the slot and your burning software is detecting that and refusing to put the data on the disc, knowing that it wouldn't play on a DVD player.
Look at the front of your dvd drive - if it has a "DVD" symbol with an oblong disc below it and says "-R -RW" then you need to use a DVD-R disc. If it has a symbol of a big "RW" then you need a DVD+R disc. If it has both, then you should be able to use either one.
Dec 18, 2010 | Computers & Internet
How to play a cd
Usually the DVD drive or the CD drive has a very small button on the front side of the Drive, if you see a button press it, the tray will come out and you will be able to put the cd on the tray and than press that button again it will take the cd in and will play for you.
However if you feel that difficult, try doing this,
simply go to MY COMPUTER, there you can see your dvd-drive or cd-drive, you can right click on the drive and click on "eject" it will eject the tray just like a normal dvd or cd player and you can insert the disc to play.
if there is anything else i can help you with please let me know.
Thank you.
May 18, 2010 | E-Machines eMachines Desktop PC
Power dvd 5 will not play. When I put dvd tries to play floppy dr
OK, try this then
Put in a dvd again, when asked if you want it to open with Power DVD, press yes
When power dvd open, DONT press play, in the meny you will find the add button, press that one, and point it to the dvd, that will hoppfully mount the image to the power dvd since you told the program where the file is.
You know that power dvd dosent lay all formats right? so if it is a burned dvd you trying to play make sure that it is a format supported with power dvd
Let me know how it goes
Nic
Mar 30, 2009 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Compaq presario 700us will play cds wont play dvds
Try to put your laptop always on flat surface. Uneven base gives angle to the already tiny clearance space for the disc. Could be that the DVD disc run coz its finer, it will spin much slower than CD disc.
Hope i give you some good observation.
Mar 29, 2009 | HP Compaq Presario 700, 700A, 700AP,...
When put cd in compartment, press play - it says NO DISC
it seems to be like bad optical picup.you have to replace the picup.
dont do you arent technicaly sound with electronic.
nuwan.
Jan 13, 2009 | JVC FS-S77S DVD Micro Component Stereo...
How to make DVP5990/37 Region Free
First I recommend that you upgrade the factory firmware to the latest version. The current version is .31 and available here. Click "I accept" to accept the license agreement and start the download. Open the zip file and burn the file named DVP5990_37.bin to a CD. Put the CD in the DVD player and it will begin the upgrade and open the DVD tray. Remove the CD but leave the DVD tray in the open position. After just under 10 minutes (6-8) the DVD player will report that the update was successful and close the DVD tray. Press the setup button, go to preferences scroll down the choices (past the bottom of the screen) and select reset to default values. The player will reboot.
Next press Setup
select the Preference menu
Press 1,3,8,9,3,1 on the remote control.
Use the up/down arrows to select region "0" which means all regions.
If you ever get a disc that won't play correctly due to a region error, just use the code above to select the correct region for the disc and you will still be able to play it.
Nov 02, 2008 | Philips DVP5990 DVD Player
Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
Aug 07, 2008 | Disney Princess DVD Player
Denon 2910 CD player malfunctions
you could try this http://www.fixya.com/support/t244156-denon_2910_cd_player_malfunctions or clean the lens
Nov 06, 2007 | Denon DVD-2900 DVD Player
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
ZT Group CISNET A7050 PC Desktop Logo
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
