Question about Frigidaire GLWS1233A Top Load Washer
During wash cycle the tub doesn't lock. - Frigidaire GLWS1233A Top Load Washer
  • 1 more comment
  • bradad Mar 24, 2009
    Is the lid lock the same as the switch that activates the machine when the lid is closed?
    That switch seems to work fine. When the lid is opened the machine will stop.
    When washing, the agitator does what it's supposed to do but unless I hold the tub with my hand, it just turns freely so the clothes don't get much activity. ( I use an old toothbrush to depress the switch while the lid is open. This is how I found out about the problem. )
    Thanks,
    TB
  • rainy66 Mar 28, 2009
    The tub turns all the time its in wash cycle and the agitator does too but since the whole tub is moving the clothes don't get 'agitated' enough to wash well. It won't even pull the clothes on top down into the water. If I put downy in the fabric softener dispenser it ends up in spots and blotches all over the clothes. Any info will be appreciated because I hate to have to buy another washer right now. Thanks.
  • salamorning Mar 29, 2009
    Correction, the model # is FWS833AS2
During the wash cycle the tub doe not lock
Posted on Mar 29, 2009
  • Frigidaire Master
  • 4,655 Answers
Lid lock may be damaged. Unplug, remove the front by the bottom 2 screws. Look at lid lock to see if it has overheated or damaged. Let me know, Thanks, Sea Breeze
Posted on Mar 23, 2009
  • John Tripp
    John Tripp Mar 24, 2009
    Then, I think I misunderstood your question, my apologies. Can you find the complete model number?
    Look at following areas for the model number
    • Rear Center Of Lid Well
    • Left Upper Back On Base Cabinet
    • Back Top Control Panel
    • Right Rear Corner Of Washer Top Lid
    • Open Lower Left Front Base
    • I will try to give a better answer after I see your model number. Thanks, Sea Breeze
  • John Tripp
    Just talked to my friend and he told me the washing machine has a one way clutch bearing. He said also that the price of replacing the bearing is too expensive and difficult to work on.You need also to ask around to see if you could have it replaced or if it is cost effective to do so. Thanks, Sea Breeze
2 Suggested Answers
  • 163 Answers
SOURCE: Washer tubs turns continuously during wash cycle,
the brake has gone bad to your transmission.the tub should not turn while agitating
Posted on Mar 06, 2009
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Makes banging sound during agatation cycle, tub and agator both rotate back and forth.
Lift the top cover of the unit from the front of the unit once it is free from the front locking clips, which hold the cover in place. Two things you need to inspect for damage. 1) You should see four rubber straps, which should restrict the movement during the wash and spin cycle (cost is around $4.00 each). 2) Check the shocks on the tub support rods and plastic hardware for damage.
Feb 21, 2011 | Hotpoint VWSR4160GWW Top Load Washer
LG Washer WM2455H Tub Clean Problem
Yes, it's normal. It is a safety feature because of the hot water used during the tub clean cycle. It prevents the machine from opening while the tub clean cycle is in process.
Jan 02, 2010 | LG WM2455 Front Load Washer
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
During the wash cycle on a maytag epic mfw9800tq0 my daughter opened the door and after water splashed on the floor she slammed the door shut. It will not drain and spin out now. the tub will agitate...
if she could open the door during wash cycle the door lock is broken and you may need a new one also inspect pumpn and tub to pump hose for foreign objects
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
140 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
