Question about Kohler Model 7202: Drain For Purist® Baths - Polished Chrome
Bathtub leakes when the drain plug is activated, no leak when not
This is a Kohler bathtub about 24 years old, it has started to leak when the drain plug is activated and floods the ceiling below. When you just run the water there is no leak. The plug feature on the tub is not used very much.
  • Anonymous Mar 31, 2014
    It also looks like the overflow drain has a cap on it
  • 374 Answers
This usually is caused by a detiorated O ring that compresses to make a watertight seal at the transistion points from them drain shoe and overflow tube to the trap adapter. However it may be the trap adapter as well. Either way the best solution is to access the tub waste from the wall behind the tub drain and replace the necessary parts. Your issue is showing up because the gallons per minute/hour rate that the tub drains is far greater than the tub valve is allowed to fill the tub. This causes a greater volume of water to fill the tub waste and as such the backpessure is greater as the entire volume of water in the trap weir must be evacuated as opposed to when the tub is not plugged and the valve is ran requiring the trap weir to evacuate gradually. Some tub wates are made of metal and may have developed holes in them but they generally form along the pathway the water uses to drain. Unfortunately the only real solution is gain access to the tub wate and replace the defective part. Thanks for using Fix Ya.
Posted on Mar 10, 2009
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Mar 08, 2015 | Kohler Home
I need my bathtub resurfaced
For bath refinishing there are several companies out there that do that. My suggestion is to do a google/bing search and see what comes up in your local area.
Rod
US Parts Center
888-521-6183
Feb 14, 2013 | Kohler 1107-R-0 ProFlex Bath Tub with...
I can't remove the bathtub drain to fix the clog on my kohl bathtub
get yourself some thrift and you wont need to take it apart
Sep 16, 2011 | Kohler Plumbing
Drain plug leaks, won't hold water. Where are parts available for this problem?
you can find the replacement parts to fix this problem at your local plumbing wholesale store.
Dec 22, 2010 | Maax Calla 6042 Bathtub - 101058-000
Our Kohler bathtub is leaking water under the tub. We think the rubber ring in the drain needs to be replaced, but we have no idea how to remove the drain, or where to buy a new one, or how to install a...
The drain portion of your tube is fort he most part universal, go to the local Home Depot or Loews and ask some questions sometimes they even have samples set up on boards in the plumbing dept you can look at. Get out there! Good Luck
Nov 10, 2010 | Kohler Home
I have a Jacuzzi brand bathtub/whirlpool 6 years old. One of my jets leaked and created a significant damage downstairs. How can I fix the jet, how can I prevent other jets from leaking? Can I just kill...
The gasket around the jet may be leaking because it is deteriorating or the flange nut on the outer side of the jet has loosened up. Check all jets for loose hardware.
Sep 12, 2010 | Jacuzzi Home
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
My bathtub drain leaks. Is there a product to
No, not without sealing, I mean clogging, the drain. Do you know exactly where the leak is coming from? I would suspect that the water is getting around the drain, instead of down the drain. The visible part of the drain should unscrew from the part that is underneath. That bottom part is likely permanently sealed to your drain plumbing.
You may be able to easily fix your leak by:
#1 Unscrewing the visible drain top.
#2 Replacing the washer under that top. This will seal your tub to your drain. All water will then be forced to flow down the drain properly.
#3 Screw the top of your drain back into place WITHOUT folding or wrinkling the new washer.
Good luck
Jan 03, 2010 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
Bathtub whirlpool leaks. problem is that the tub
Stop leak in a bottle absolutely does not work, look closely there should be some sort of access panel (maybe well hidden) to get under there.
Mar 24, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Kohler Model 7202: Drain For Purist® Baths - Polished Chrome Logo
608 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
