Question about Consew 226R-1
In need to know how to adjust my stiching and needle adjustment/ the bobing is jamming(not stiching)
  • tflan May 11, 2010
    Adjust stitch length by holding down the small button on the bed of the machine and turning the wheel.Stitch length numbers are marked on the wheel, next to the belt on some machines. On others they're marked on the wheel under a cover on top of the machine. Open the small cover on top of the machine. Hold the button down and turn the wheel until it clicks. Then while still holding the button down, continue to turn the wheel either toward or away from you to get to the number of stitches you want. The run a few stitches and repeat as necessary.
    If the bobbin is jamming you probably have threaded it wrong. Thread comes off the top of the bobbin, down and through the slot in the bobbin case, under the tension spring and pulled toward the back of the machine. Adjust bobbin tension and top tension so that the top and bottom threads are connected in the center of the two layers of fabric.
  • 26 Answers
Stitch length is adjusted by holding down the small button in the bed and turning the wheel to the desired number of stitches. The numbers are either on the wheel, next to the belt pulley, or under a small cover on top of the machine. Hold the button and turn the wheel either toward or away from you to get the stitches you want.
Bobbin jamming is either because of incorrect top tension or incorrect threading. Go to www.consew.com and get a parts and operation manual for free for a 224. It 's the same as the 226.
Posted on Aug 14, 2009
Nx2000 keeps nesting bobing tthread needle changed lintcleared
nesting bobbin thread is an indication that the needle thread tension is too loose
adjust that tension up more
Oct 01, 2016 | Brother Sewing Machines
Needle keep breaking
maybe wrong needle .
Jan 15, 2015 | Sewing Machines
Do I need to adjust bobbin tension when changing stiches
Usually one does not change bobbin tension. Adjusting the tension on the needle thread is all that is required.
It is sometimes necessary to change the bobbin tension but only when changing to an extremely fine, slick thread or to a very heavy, rough thread.
Oct 02, 2014 | Brother Sewing Machines
Machine and Bobbin threaded correctly. When trying to sew will not pick up thread from bobbin to make a stich.
That sounds like the timing is off and unless you know how to adjust that you will need to bring your machine to someone to have them adjust the timing relationship between your needle and your bobbin. Good luck
Sep 29, 2014 | Kenmore Sewing Machines
Singer 522
Hi . try adjusting the tension screw on the bobbin case on the thread tension leaf . tighten it slightly just enough that the thread needs needs a little bit of nudging to come out . do the same for the thread coming through the needle . this should help .
Sep 12, 2013 | Sewing Machines
Trouble with the stiching on a juki7800
try changing the needle, make sure the needle is the correct one for the fabric being used
also adjust top thread tension
Apr 16, 2012 | Juki DDL-8700
Bobbin won't pick up stitch(thread)
Try a new needle, confirm needle is inserted correctly, needle flat side to back of machine. If still not needs timing, take to sewing machine tech.
Jan 08, 2010 | Singer 7422
Good Morning: My wife has a Husquvarna Viking 320 Electronic Sew Easy. I have tried to re-work the bobin and the thread through the needle. When she stiches the hem on a pair of blue jeans it stiches...
since you are doing jeans it can be on either side so lets start for the beginning, rethread the top thread making sure that the thread went through the upper tension, second remove the bobbin and make sure to thread it through the lower tension(there is a spot on the bobbin case for the thread to go through for there to be tension on the bottom) if the thread on the bottom pulls really easy by hand like there is no resistance then take it to a local dealer and have him adjust it if it feels like there is a pull do the same with the upper thread put the foot down and try to pull the upper thread(don't break a needle) if it has tension adjust the upper thread tension tighter
Oct 19, 2009 | Sewing Machines
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Getting jam all the thread and needle do not mooving
make sure your needle is not dul you may need to adjust your tension as well.
Oct 21, 2008 | Brother LS-2125 Mechanical Sewing Machine
Consew 226R-1 Logo
254 people viewed this question
Top Consew Sewing Machines Experts
River bottom
Custom Exchange
Custom Exchange
SewTechWayne
SewTechWayne
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
