Question about Electrical Supplies
No output I have a 4ckm21 gen.which runs fine but has no output power. How to solve this problem. thanks|||
  • debrabob Mar 10, 2009
    All fuses and breakers good.What does all those led lights on circuit board mean?. thanks. Still no power.
  • 74 Answers
Try the check the fuses or break box of the gen first
Posted on Mar 10, 2009
Honda GX390 Generator not performing under load.
a GX390 Honda Motor but the used generator stator can be different cannot give more suggestions then measuring the circuitbreaker it can be broken the suggestion 60 mf capacitor can have trouble and electronic modul and bridge rectifier for some other dc connectors the coil diodes inside the stator. several options to go.
Jun 21, 2017 | Honda Electrical Supplies
My kohler 4ckm21 generator starts great but will run for 8 min. and shut down ?
If it runs that long, you may have a bad oil pressure switch, loose connection, or fuel pump. You didn't indicate whether the time was under laod or not
Aug 07, 2013 | Kohler Electrical Supplies
Engine runs fine but not putting out any power. thanks
Is the engine turning the shaft to the generator ? if it has a coupling device is it intact .. is there a reset button on gen output does it need reseting. or is it not working...
Apr 01, 2011 | Briggs Stratton Portable Generator 305cc...
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Aug 11, 2009 | Electrical Supplies
No Power Output
Okay, this is going to sound kind of hard but you can do it...you need to flash the field and try to get some 'excitation' back to the windings. It's a bit of a deal but here's how:
With gen not running, plug the battery charge plug in to the charger output and you need to reverse the leads at the battery. Hook the BLACK to the positive post. Then, just touch the red to the negative terminal for a second or two. That's it!
Then...start gen and check output. If it just needed a flash, that will do it, I'm serious!
Jul 26, 2009 | Electrical Supplies
No voltage output
It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
Apr 02, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
Coleman 1850 sport, no/ low generator output
The engine should run at 3750 rpm at no load. If that's OK then you may need to troubleshoot the capacitor inside the end of the generator opposite the rope. Since the thing has been stored for some time you may just need to flash the field of the generator to restore the residual magnetism in the rotor. The easiest way to do this is thru the 110 outlet but it's a little dangerous. Plug an old lamp cord into the outlet, start the generator, and momentarily connect a 9 volt dry cell to the wires, then shut the generator down and see if there is 110 when you restart it.
Regards,
Carl
Feb 19, 2009 | Coleman Sport 1850 Generator
Electrical Supplies Logo
105 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
