Question about Dryers
The coil will light the flame for 15 seconds then the flame goes ouy for 1 minute then the flame will light for 6 seconds every minute
  • Dryers Master
  • 8,220 Answers
Sounds like a corrosion problem with the sensor. igniton confimation is bleek captain we cannot tell if the dilitum crystals are firing. Dayum it Scotty I have to have confirmation of that ignition. I keep trying sir but it's no use. Ya might as well be Bones do something! Dayum it Jim I'm an alky not a gas jockey. Ohora get on the horn and contact startfleet command. Tell em to send a specialist cause ain't nobody on Fixya got a clue. LOL
Posted on Mar 10, 2009
  • Dan Webster
    Dan Webster Mar 10, 2009
    Fire a couple of these proton torpedos:
    At that old gas valve and see if she will wake up and fly right amigo.
Ignitor is lighting but silinoid is not opening to let gas through.Roper model # RGS7646KQ3
Your have one of two problem causing the gas to not come on on your dryer.
1) the flame sensor is bad...if the igniter comes on and stays on and doesn't go off...usually within 1 minute the flame sensor isn't working as its supposed to
2) the coils on the gas valve could be the problem...if the igniter does indeed go off within 1 minutes and as soon as the igniter goes off if their is no flame the coils on the gas valve is what would need to be replaced
here is what each part looks like
I hope i have been able to help you fix your dryer,
GENE
Sep 17, 2011 | Dryers
I have a kenmore gas dryer is it good if on # 1 coil on #1and 2 i get1328 ohms 1and3 i get 528 on #2 coil i get 1220 ohms
On the gas valve are one or two coils (solenoids) used to open and close the valve to control the flow of gas. If a coil fails, gas will not flow and the dryer will have no heat.
The easiest way to diagnose a problem in the burner assembly is to observe the burner operation. Remove the small access panel at the bottom, front of the dryer, select a high temperature setting and start the appliance. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. Next you should hear the click of the gas valve coil and a flame should ignite. The flame should be mostly blue and it should remain on for a minute or more.
If the ignitor glows for several seconds (up to 15 seconds) and then goes out, the problem is probably the coils (solenoids). If the ignitor glows and stays on, then the problem is usually the flame sensor. If it ignites and then quickly goes out, it is most likely a problem with inadequate air flow.Test the coil for resistance using a multimeter. Set the multimeter to the ohms setting X10. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 1300 ohms (+/- 150 ohms) when the probes touch the terminals. If the reading is infinity or substantially different from 1300 ohms, the solenoid should be replaced.
Jan 11, 2010 | Kenmore Dryers
The flame goes out after 15 seconds, then 1 minute later comes on for 6 seconds. Replaced the coils and the problem continues. Replace the flame sensor?
Pull the 2 wires going to each thermostat and tape them together until you find the defective t-stat...I beleive you have 2 of them plus 1 white one in the rear of the dryer..
Oct 20, 2009 | Whirlpool LGV4634JQ Gas Dryer
I have a Neptune Gas Dryer MDG300AW and the flame goes out.
Well, first of all, the flame is not supposed to be continuous... it cycles on and off during the dry cycle because it staying on would incinerate your clothing. However, there are magnetic coils that do often go bad and cause the valve to stop opening after the beginning of the cycle... so you get a flame in the beginning, but if you were to sit there for 5 minutes with the dryer running, you would find that the flame stopped lighting completely.
They are pretty easy to replace... you will have to unscrew the little plastic pieces from the inside edge of the door, and unscrew the hinges and remove the door, then pull the front panel off (pull at the top).
Of course... UNPLUG before opening any appliance.
here's a picture of what you are looking for... they are completely outside the gas line, so changing them is very simple and doesn't require any handling of the gas. they are held on with a small metal plate.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500-%3d%3dd563888i3479&PartID=3479
Jul 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Burner lights for about 15 seconds then goes out.
sounds like flame sensor mounted on burner off chance may be burner coils failing but ck flame sensor first
Jul 28, 2008 | Frigidaire Dryers
Gas Dryer not heating
You will have to replace "BOTH" of those gas solinoids. First, be absolutely sure that you "TURN OFF THE GAS". Then be sure the unit is unplugged. Remove the phillips head screws, remove the small metal top bracket, and slide the coil up and off. Then replace the coil, rehook your wire, and replace the metal holder. Upon testing, be sure to turn your gas back on. The first time it may act like it wont start, but let it cycle through a couple times to remove air. Good Luck And Be Safe. Jim
Sep 07, 2007 | Kenmore 72062 Gas Dryer
Dryers Logo
80 people viewed this question
Top Dryers Experts
