Question about Campbell Hausfeld WG2060 Mig/Flux Versa - Arc 95 Amp Welder
Welder work OK with flux wire, cannot get penatration in MIG mode
I am trying to weld 18-20 ga sheet metal (car fender body work). Works great in flux mode. But I have tried .030, .024 and .023 mig wire at all power settings and wire speeds and cannot get any penetration into the base metal. It just beads up and can be easily knocked off with very little force even with fingers. I properly converted to mig and am using a brend new bottle. I have a campbell Hausfeld WF206400AV. 115 volt unit.
  • gordondjm Apr 30, 2009
    Same welder, exact same problem. Just came back from the garage after trying every setting I could possibly go with (for the 3rd or 4th time) - no luck, just like you said; no penetration.
    I've tried .26 solid wire and .30 and haven't noticed any difference (high voltage, low to medium speeds. Also tried leaving the machine in Flux mode (electrode negative) while welding with solid core - still no good. Meanwhile I can burn through the same material in a heartbeat with flux core. Just doesn't make sense.
    Glad you posted this, I though it was just me. Seems it's the welder...
    Gordo
    By the way, I'm also using a 75/25 Argon/CO2 mix - no impact.
    Problem Solver:
  • 7 Answers
Same here, just a tall cold bead in MIG mode using .024" wire and 75/25 gas
Posted on Nov 10, 2009
    Novelist:
  • 152 Answers
Are you using combination argon/co2 gas? You need a flow regulator and should have it set for about 10cfm. Note that this is different than a pressure regulator. The problem you note is a result of inadequate or improper gas.
Posted on Apr 29, 2009
My lincoln mig 140 feeds the flux wire through, but it just sparks, will not weld
Make sure the ground clamp has a good connection to both the work piece and to the welder Sometimes the welder connection is overlooked.
Jan 13, 2014 | Lincoln Welding Tools
Will a ya219b snap on by century mig welder weld flux core wire
Are you using knurled rollers? Check the wire. Is it reversed polarity. Flux cored wire is very voltage sensitive.
Jun 14, 2012 | Century Welding Tools
How do you switch the polarity switch on the 115 farmhand versa-arc mig welder. trying to switch from mig to flux core wire.
Hi:
Disconnect you ground clamp form the negative side pole and switch it to the positive pole, same for the gun disconnect the from the positive side and switch it to the negative pole.
Good luck.
Sep 07, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
How thick of metal will this unit weld
Hi:
Your unit will be capable to weld up to 3/16" using FC wire and 1/8" using gas wire.
Aug 06, 2011 | RTO Flux Wire Welder Dual Mig 131 Ti 1 Gas...
My welder does'nt feed a constant feed motor seems to slow down and wire pushes my hand away when hitting metal.
If wire pushes your hand away when welding you need to do one of the following:
Reduce your wire speed, or increase the voltage.
Nov 24, 2010 | Campbell Hausfeld ® 115V MIG Flux Core...
I dont know what kind of metals this wire type can do, it says fire power 1440 u235 flux wire, but not sure what kinds of aluminums or steels it can weld. Im a certifed MIG aluminum welder, but this is a...
Usually a flux core only welds steel. It is a higher penetration weld than a MIG. Usually it acts similar to 6011 rods in SMA (Shielded Metal Arc) welding -- a.k.a. stick welding -- if you're familiar with that. I don't believe there is such a thing as flux wire for aluminum. There may be stainless wire for it, but I've never seen it. It probably could also be used for building up cast iron and cast steel, but nothing structural. I have a Chicago Electric one and I love it -- simple and it penetrates hard. My 90 amp will weld to 3/8" without breaking a sweat and if I baby it will go to 1/2" or better. It is difficult to go much lower than 12 or 14 gauge though due to the high penetration.
Nov 28, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
Nov 02, 2009 | Welding Tools
Trying to weld with Hobart 125 EZ
If you are using flux wire and not shielding gas, your clamp should be positive and the wire should be negative. Heat is provided by the electrical arc that happens between the wire and the material. Your welder by itself does not pre heat the material and with 3/16 material you should not need to preheat anyway.
The electrical arc is kept consistent by adjusting the wire feed rate and the current applied. You will need to experiment with these settings to find what works best with your welder. For this welder and 3/16 material, I would suggest you start at the upper end of the current scale and about a third of the way up on wire speed. The welder might have a chart for these settings in the manual or inside cover.
If the wire feeds too fast, it will push the probe around and you will feel pressure as the wire feeds out. If the speed is too slow you will get large spatters and intermittent arcs. When properly adjusted the arc will sound even and consistent. The arc gap should always be about 1/8 of an inch.
To maintain enough heat for good penatration, do not move the probe too fast, work in a pattern and watch the weld pool (melted metal) and not the arc. Watching the weld pool will clue you in if you are moving too fast or too slow.
I hope this helps.
-Scott
Feb 03, 2009 | Hobart Handler 125 Ez
Mig problem
For certain type of work TIG is required, like welding chrome moly for some racing organizations. Intricate work, like gunsmithing is also well suited to TIG. TIG is used by many auto restorers who prefer a more precise, perfect finish that requires little to no finish work. TIG is most similar to gas welding in technique, so if you've done oxy-fuel welding, TIG should be a natural transition. MIG is required by law and by insurance companies in many localities for structural repair of automotive frames. MIG is also much easier to learn and faster to weld. For doing other types of welding, like sheet metal, it can be a matter of personal preference. For an auto body repair shop or a novice welder, a MIG is a good, practical all-around welder.
Aug 27, 2008 | Troy MIG100 90-Amp. Wire Feed Welder
Campbell Hausfeld WG2060 Mig/Flux Versa - Arc 95 Amp Welder Logo
695 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
