Question about Belkin F1DK102P 2-port KVM Switch
Don't have scroll lock on wireless keyboard/mouse combo, what other hot keys can i use?
You can try CTRL CTRL instead of scroll-lock. it was working for me. It is not mentioned in the manual.
Posted on Aug 27, 2009
The solution given by oslonch seem to ignore the fact that the problem is related to the KVM switch which wired up to recognise the scrol lock buton only. Perhaps the answer will be to find out what code is generated by the scrol lock key and sending to the system as an acii extended code?
Posted on Aug 26, 2009
    Problem Solver:
  • 10 Answers
Sorry, I don't think that there are any hotkeys to replace the scroll lock on your wireless keyboard/mouse combo. In modern GUI environments, scrolling is usually accomplished using means such as scrollbars or scroll wheels. (i.e. the wheel on your mouse) Many keyboards as well as programs no longer even support use of this key on the keyboard as Scroll lock has fallen into such extremely infrequent usage. If your mouse as a scroll wheel I would suggest just using that. Or click on the scroll bar on the side of your screen and drag the bar up and down to view the rest of the page you are trying to view. Hope that this was helpful.
Posted on Mar 23, 2009
  • Riley Durant Oct 10, 2011
    you do realize they are talking about a Keyboard Video switcher that uses scroll lock as the hotkey right?
    I mean, sorry for posting on the dead thread but i thought it needed said......
Page up button not working
Unfortunately it sounds like you're keyboard is malfunctioning and the only permanent fix is to replace the keyboard. In the mean time, since you are unable to do so, I would suggest using the touch pad to manipulate the scroll bar for the faster scrolling. For more control you could use a USB mouse with the laptop which would give you a scroll wheel. (I personally use a Wireless Mouse with my laptop because I find touch pads don't react they way I would like my mouse to use)
Nov 29, 2011 | IBM ThinkPad Computers & Internet
Need help to install wireless mouse keyboard combo 867574-0403
make sure you have the correct keyboard and mouse selected
you might have to uninstall your keyboard and mouse then restart your computer and reinstall them make sure that you have there drivers backed up on a disk before uninstalling them
click start control panel,keyboard select hardware you will see which keyboard it is this will also apply to your mouse
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port
also select properties,general you will have options to troubleshoot,driver roll back uninstall ,update driver
or click start control panel administrive tools computer managent device manager scroll to keyboard you could see a yellow question mark? right click to install drivers
hope this helps
don
Feb 15, 2011 | Computers & Internet
Hi . .. I want to use this KVM switch to connect
The GCS632U has keyboard and mouse emulation that may not work with all wireless combos. If your wireless combo is going to work the single USB connection would need to go into the keyboard port as that is the only port that will recognize the hot key switching commands. If the wireless combo still has problems then try using a USB wired keyboard to ensure the GCS632U is working correctly.
Mar 18, 2010 | IOGear GCS632U 2-port KVM Switch
IOGEAR KVM gcs632U. Set up notes that to "toggle" between PCs you press SCROLL LOCK twice. My keyboard has no SCROLL LOCK so to change you are supposed to press NUM LOCK + "-"...release "-" after 1...
OK well usually in the "Setup" you can "Assign" whatever keys you need, so can't you change the keys used to what you have? ALL Keyboards have scroll lock, it is probably just "Hidden" for instance I found one accessed via pressing a Blue Fn Key and then F12. Look carefully for "Other: small writing on keys.
Feb 15, 2010 | IOGear GCS632U 2-port KVM Switch
Logitech MX 5000 Wireless Laser Keyboard & Mouse Combo
HELLO, ALL YOU HAVE TO DO IS TO DOWN LOAD THE SOFT WARE THEN PLUG IN THE USB AND AFTER THAT ON YOUR RECIEVER CLICK THE CONNECT BUTTON ON THE RECIEVER TILL IT RECONIZES BOTH KEY BOARD AND MOUSE I HAVE THE LOGITECH WIRELESS SYSTEM AND I LOVE IT TILL THE BATTERIES GO OUT ON THE MOUSE OR KEY BOARD LOL THEN RESTART YOUR COMPUTER.
Apr 05, 2009 | Logitech Cordless Mouse
Scroll Lock on -- mystery
On the Logitech LX710 Lazer the Scroll Lock option is toggled by holding down the "Function" key and pressing the "Pause/Break" key. If you look at the P/B key you will see a little orange symbol of an arrow pointing down to remind you of this feature. This can be disabled in the Setpoint panel by selecting Keyboard and Keyboard Inactive Keys then place a check in Disable Scroll Lock so you may have to remove a check mark first.
Jun 25, 2008 | Logitech LX 710 Keyboard/Mouse
Hotkey mode
This just worked for me. Using your PC keyboard, boot up to the PC first and then power up your mac. Hit the scroll lock twice and IMMEDIATELY hit enter. You have to go fast- click-click-click with no hesitation and it works great. I still can't toggle the hot keys to set up my mac keyboard, which I prefer using, but I'm assuming it takes the "right" timing on the keys. I'll keep trying.
Oct 23, 2007 | IOGear GCS632U 2-port KVM Switch
Keyboard not responding
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one. https://www.amazon.com/Logitech-MK270-Wireless-Keyboard-Mouse/dp/B00BP5KOPA/ref=sr_1_1?ie=UTF8&qid=1491364851&sr=8-1&keywords=Logitech-MK270-Wireless-Keyboard-Mouse
Apr 03, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Computer locked
there are combinations of function or "hot keys" for enabling or disabling these functions. The NuLk is a combo of the functin key and the NumLk key pressed simultaneously. The scroll lock is the one keeping your mouse from working properly. I'm not familiar with your particular unit to advise which keys are necessary to disable Scroll lock, but they should be marked. Also, some notebooks have a switch to disable the mousepad...Usually indicated by a light located above the pad itself. Good luck Harvester3
Aug 18, 2007 | Averatec 3200 Notebook
Belkin F1DK102P 2-port KVM Switch Logo
1,602 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
