Question about Dell Inspiron 9100 Notebook
How cheap can I find a new monitor to hook it up to?
    President:
  • 1,179 Answers
If you're looking for a standalone monitor you can check stores like newegg.com & tigerdirect.com. I just picked up a 22" widescreen 1080p monitor from newegg.com for $179.99. Hope this helps.
Posted on Mar 10, 2009
My lcd monitor become very dark
The issue you are describing may be with your video card rather than the monitors. Do you have an onboard video jack? If so, hook one of the monitors to this jack and disable the video driver for your installed vidio card. If it works, you have the answer. If you do not have an onboard card perhaps you can borrow a video card from another computer to test if it is indeed your video card or monitors. You might also try to uninstall and then reinstall the driver from your video card maker. They usually have driver downloads on the site. Lastly, you can buy a cheap video card for testing and if you discover it is your video card buy a new one.
Oct 27, 2012 | IBM 9512-hb0 - 15inch Lcd
I purchased a new computer and after hooking everything up, everything works except I have no audio. I believe the speakers are internal to this monitor.
Double check that you have the speaker cable plugged into the proper jack (audio out - green) on the computer. Make sure that the audio hasn't been muted and that it is set for the correct output type (if you have a multi-channel audio option).
Try a standalone set of speakers to check if the audio driver for the on-board audio or sound card is working.
I hope this helps.
(I've found that the integrated speakers will fail before the monitor does. Since the integrated speakers are low-end and similar speakers are fairly cheap, get new speakers of a quality you like. Repairing the speakers isn't worth it.)
May 19, 2010 | AOC LM729 17" LCD Monitor
I have 3 outside cameras (SSC-12C) hooked up need cameras
i recommend pelco day night dome camera they are cheap and the resolution is great. they are originally bnc type connector which usually take rg59 or rg6 coax cable but if you have like cat5 or some other kind of stranded wire you can by a balum adaptor that takes stranded wire but has a bnc female end. now with your monitor they make a cheap device called a multiplexer it takes bnc connectors and to hook up to your monitor you can use regular adio video cables like for your vcr. the multiplexer also lets you scan thru your cameras one at a time or have all three up or it can scan thru by itself like every five minuets.
Jan 17, 2010 | Samsung Weather Resistant Security Camera...
My Samsung 913t says "Check Signal Cable." HELP PLEASE!!!
Cheap CRT monitors can be picked up at Thrift Stores, quick and cheap way to test your computer output.
Sep 22, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
No monitor
No. Find cheap replacement on ebay or cl
Jul 14, 2009 | Samsung SHR-2042 4 Channel Stand Alone Dvr...
Screen went black
I don't know. I've never actually replaced parts in a monitor. If the bulb is expensive, it might be best to buy a new monitor. They're cheap nowadays. Or you can check if there's warranty on the monitor and it can probably be fixed for free.
Apr 20, 2009 | Acer X221WSD Monitor
Monitor won't come on
Right this problem could be the result of a couple of possible faults, the first thing to do is rule out the cables. Try connecting your PC to a monitor using a different cable... check all the connections. Try connecting you PC to another monitor again... If you are still not getting a picture It sounds like you have a problem with your computer's graphics card - new graphics cards are fairly cheap and quite simple to install.
A+Support
Apr 13, 2009 | IBM Aptiva E 240 (2158240) PC Desktop
Dell Inspiron 9100 Notebook Logo
49 people viewed this question
Alun Cox
