Using Photoimpressions crashes my computer. I uninstalled OVT Scanner and Photoimpressions - then reinstalled first the Drivers, and next the software. An error message to the effect that OVTBoot.dll could not be found. The system recognizes the OVT scanner, and Device Manager says the hadware is working normally - but photo impressions works UNTIL I try to aquire pictures from scanner. My scanner model is FS-C1-VP
  • obfullerton Mar 10, 2009
    OK so I can't find the file OVTBoot.dll on the installation disk or on my computer. where can I obtain the DLL file?
    Sergeant:
    Novelist:
  • 277 Answers
The drivers are gor corrupted.and in your windows the file is missing
Posted on Mar 10, 2009
  • top class Mar 10, 2009
    in your windows operating system system file.
    just reload the windows operating system file.and in that the DLL file.will be getting loaed and also all the other files.
Flatbed scaneer 22 device driver for window 7 ultimate
if using windows 7 just plug it in and windows 7 should automatically find the driver if you need the software and do not have the disk type in the name/brand support of the scanner into your search engine and you might be able to download it
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port?and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps
Jun 07, 2011 | Computers & Internet
Hi. I'm getting the next issue: From one day to another my Epson Stylus CX5700F is reading the next error: SCANNER ERROR --SEE YOUR DOCUMENTATION AND CALL SERVICE IF NECESARY. I'm new to this forum so...
It seems that the scanner protion of the drivers are corrupted. Please do the following:
1. Disconnect the all in one.
2. Go to Start->COntrol Panel->Add Remove Programs.
3. Uninstall the All in One.
4. Reboot the computer/laptop
5. Once rebooted, reinstall the drivers from the CD that came with the device.
6. When finished reinstalling, Connect the device again.
7. Allow Windows time to detect the device and load up its drivers.
8. Windows will tell you in the right bottom corner that "New Hw is ready to be used".
9. Start using the device.
Feb 08, 2011 | Epson Stylus CX5700F All-In-One InkJet...
OVT Scanner won't run with Windows 7. Vupoint
We suffered this initially on a new laptop with Windows 7. I can't tell if the driver on the Vupoint website has been updated, or is the old XP/Vista driver, but we installed this (1/2011). In Picasa or the Photoimpressions software which comes with the scanner, we were then only able to acquire solid black images. However, when we tried all of the USB ports on the computer, we found that one of them (a USB2 rather than USB1 port) was able to function like normal. We suspect there is a funny issue with the amount of power going to the scanner from different USB ports, and maybe this interacts with the driver in some way.
Jul 07, 2010 | Office Equipment & Supplies
My computer has Windows xp Home Edition Version 2002 Service Pack 3. Initially I was able to do first stage of installation install ovt Scanner but next stage of Arcsoft photoimpression started and then...
For a scanner driver it should not matter whether you have XP Home or XP Pro. Most probably there's a simple problem with the disc.
You can ask the vendor for a replacement disc, or go to manufacturer's website and find downloadable drivers & software there. However, on the website there may not be the full software set available, as usually scanners come with some bundled extra 3rd party software that cannot be made available online by the manufacturer for everyone to download.
The essential thing is to install the drivers properly, the other bells & whistles are not needed, you can use applications either built into the system, or available free online for image scanning and manipulation.
Jun 15, 2010 | Office Equipment & Supplies
Repeated message "windows cannot load OmnisuperCam" Followed instructions and reinstalled carefully twice. Photo Impression 6 loads and is active. OVT does not appear in control panel 'scanner and camers'
Hi.
This often happens because Image Copier installation must be done in exact order as described in the instruction manual. To fix the problem you need to uninstall and reinstall everything back in right order.Also remember to restart the system when required.
  1. Unplug the image copier
  2. Uninstall the driver (remove from installed scanners and remove driver files).
  3. Uninstall PhotoImpression6
  4. Restart your computer.
  5. Install the driver,.
  6. Restart computer
  7. Reinstall PhotoImpression6 software.
During installation ensure that you authorize the system changes when asked. If possible disable any security software.
If that does not fix the problem, then the registry must be cleaned of any entry related to the scanner software. This is rather difficult to be done manual. You can try doing a system restore to a recent date before the problem started after uninstalling everything, and then uninstalling again if needed (application and scanner are there after SR), and finally reinstalling everything in order. If that does not work you can try a registry cleaner or reinstall the system.
Here a copy of the manual.
Jun 22, 2010 | Computers & Internet
It does not recognize my memorease digital slide scanner. I am using windows 7 and the lates drivers from Pacific Image and Adobe elemnts is supposed to see the slide scanner bbut doesn't
If your scanner is like mine, the software is defaulted to look for the OVT scanner. Go into properties and change the default to Cyberview CS Memor-ease.
Jan 15, 2010 | Office Equipment & Supplies
My Hp Deskjet F4200 series printer will not scan anything to my computer, but it will copy just fine. How can I get it to scan? I have already uninstalled the printer driver & reinstalled it. It says...
Check to see that your Scanner drivers have been installed. Click on Start, then Printers and Faxes and see if a Scanner is listed. If not, you need to install the drivers.
Also, when you uninstall the printer drivers, you first need to disconnect the printer from the computer, and unplug the printer from the power source. Leave the printer unplugged for at least 15 minutes to clear the printer's cache memory.
Next, go to Add/Remove Programs in your Control Panel and uninstall the printer software. Then, turn off your computer.
Next, reboot your computer. Place the Deskjet cd in the drive and follow instructions for reinstalling the printer software and drivers.
CAUTION: DO NOT PLUG IN YOUR PRINTER CABLE TO YOUR COMPUTER UNTIL PROMPTED BY THE INSTALL DISK!!
Oct 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner only scans part of page
you will have to uninstall the scanner drivers from the computer in the control
panel>scanners..then uninstall the printer drivers from the orinter in the control
paneland then tryy reinstalling the drivers and the s/w using the disc that came with
the printer...see if works
Jun 04, 2009 | HP Photosmart C7280 Printer
Lg cdma lxu-800 modem crashes windows vista
First Uninstall the drivers of this modem and chk if any hardware is creating a conflict with it. Next uninstall that hardware or change its slot.
Now reinstall your modem with the latest set of drivers
May 16, 2009 | Computers & Internet
Vupoint FS-C1-VP scanner installed
i have vista home and mine worked fine until i installed a web cam and then it just gave up. But now it works great - here is what i did
unpluged both the scanner and the web cam
uninstalled everything to to w/ the scanner and the web cam.
Installed the driver from the CD and restarted my machine
Install the Photo 6 software
plug in the scanner - works like a champ.
have not reinstalled the web cam
Oct 02, 2008 | Office Equipment & Supplies
96 people viewed this question
jasbo
jasbo
