FixYa.com
Tags:
IBM 3580 Model H11  Ultrium Tape Drive
AS/400 not recognizing LTO drive
By Peter1 - usenet poster
I've got a problem with my AS7400 (model 720) not recognizing an IBM LTO
tape unit (3580-H11). The tape unit is Ok, the QAUTOCFG is 1 but the
hardware resource is not created (i've already executed an ipl).
I've got V5R10 instaled.
Any ideas?
Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 23, 2008
Not Rated (0)
Savyr
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
check SCSI id must be 0 for Iseries also terminator is correct ie HVD terminator
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 02, 2007
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
Hi
Sometimes those LTo's act a little strange.
Try this..maybe it helps:
1. Disconnect the cable from the magstorage ctl (#2729)
2. IPL the card (I/O debug under sst)
3. Clear any failed/mising hardware
4. connect the cable..pwr on the LTO and load a tape
5. If de resource isn't created...do an another IPL from the card (I/O debug
under sst)
And also take a good look at the pins of your cable...all the swapping might
maybe damaged one of the pins
"JRibeiro" < ...
Solution #3
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
No problem in SCSI id and it is terminated. The tape unit has been
working Ok but after an unexpected shutdown from de AS/400 (long time
power failure during the night exceding UPS capacity) the problem started.
Solution #4
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
Dnia Tue, 14 Sep 2004 14:59:37 +0100, Jos?? Ribeiro napisa??(a):
SCSI id conflict ?
You did not terminated ?
Can you Help with these Tape Drives problems?
Tape Drives
scanner
hi, I have a bright scanner s/n... Answer This...
Tape Drives
Legato Performance Issue
Performance of writing to tape... Answer This...
Tape Drives
DAT72 tape problem
I can't take backup of... Answer This...
Tape Drives
Quantum Scalar 50 Library...
we bought Quantum Scalar 50... Answer This...
Tape Drives
Need tape info from storstation...
I need someone to download info... Answer This...
Repair Service
Find Tape Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
