Question about Microsoft Xbox 360 Console
Dvd drive is not responding
I had the three ring problem and fixed it now the dvd drive will not respond is doesnt spin or eject when i push the eject button the light will blink once thats it
  • bryan_mauree Mar 10, 2009
    thanks but i already tried that
  • Anonymous Apr 26, 2009
    I'm having the sam problem, has anyone been able to fix there and if so how did you it
    Problem Solver:
  • 16 Answers
Turn off your console, unplug from the power source, remove the harddrive, reattach the harddrive, plug it back in, power on
Posted on Mar 10, 2009
How do I eject a disk from my dell studio labtop
To eject a disk from the CD or DVD drive when the elect button does not respond, use a straighten paper clip and push it gently into the pin hole int the drive tray. The tray will pop out and you can then grab the tray to fully open the tray.
Mar 23, 2011 | Dell Studio 15 Laptop
Door will not open
make sure the drive is not reading a disk, because if its spinning it can break when you do this process.
look for a hole in the front of the drive, get a paper clip and stick it in there all the way, the tray will now eject or if its a slot loading drive the cd will eject
Sep 06, 2010 | Computers & Internet
Power light is yellow and won't respond
Return or take to a tv repair, most fix dvd players.
Dec 23, 2009 | Cyberhome CH-DVD 300 DVD Player
It won't eject.
I assume you are talking about the cd/dvd drive. Almost all of these drives have a tiny little hole in the cover. This hold is just big enough for a straightend out paper clip.
Turn off and unplug the pc. For laptops remove the battery. Then push the paper clip gently into the little hole and the drive should open a little. Don't force it open. If it doesn't open easily, you probably have a cd/dvd inside that is hung up. Gently turn and/or shake the pc/laptop to see if you can free up the cd/dvd.
Oct 08, 2009 | Dell Latitude D520 Notebook
My dvd and cdrom in Compaq Presario R3000 quit working. Help!
Unfortunately these devices will fail.
A new one will cost in the $20-30 range and is easy to install.
Mar 20, 2009 | Compaq 350831-001 - Presario R3000 Series...
Dvd drive is not responding on 360
the ROM drive has failed. you will have to install a new drive or repair the components within this ROM.
Mar 10, 2009 | Microsoft Xbox 360 Console
I have a new sony vaio VGN-FW230J that recently the dvd drive has stopped opening and when i found the button to manualy open several disks will not play at all. I am currently in Afghanistan so it is...
due to dusty environment as in the area u mentioned it happens the lens gets dusty and when it tries to read during that period it doesnt respond to the opening button so the only solution is
open the dvd tray u can see that shiny eye like thing try cleaning th lens gently in round movement with a tissue paper or very soft cloth used to clean lcd screens see if it works , other wise ur DVD drive lens got weak from use now adays service centers are getting tons of them everyday for replacements
next time if u get into trouble try pressing the eject button for like 5-8 sec it will respond otherwise restart immidiately then it will respond to ur press when the sys is restarting take out the disk and try the cleaning process
pls do rate me if i fixed what u wanted
Feb 24, 2009 | Sony VAIO VGN-FW230J/B Notebook
Philips DVP-3020K not eject my CD
hello my friend! my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Dec 21, 2008 | Philips DVP-3005 DVD Player
DVD Player won't open
check if your dvd door is driving by belt or gear . if its belt ,check if its slack, if gear check for worn gear. weather gear or belt check if the motor driving it responds each time you press the eject button .check if the eject switch is ok .then if all this are ok ,check the ic controlling the eject/close functions
Jul 11, 2008 | Samsung DVD-V1000 DVD Player/VCR
DVD stuck in drive
try ejecting through my computer then right clicking on the drive and select eject or there should be a little pin hole at the front of the drive to push and force a manual ejection
May 30, 2007 | LaCie (300987U) DVD RW Dual Layer Burner
Microsoft Xbox 360 Console Logo
146 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
