Question about Water Heaters
Temperature drop very little hot water from the Amtrol Boiler Mate model temperature dropped from 140 to 108
    Sergeant:
    Champion:
  • 234 Answers
Is there problem with the in coming water to this unit?
Posted on Mar 15, 2009
Why the hot water temperature couldn't reach the set temperature (130 degree) in Amtrol WHS80Z indirect water heater?
I have a couple of thoughts. You may have air in the boiler water circuit at the loop that feeds the tank. You'll have to find the vent in the loop to get it out. Second, the automatic valve that opens for hot water may not be opening fully. Have you felt both the boiler water lines that go in and out of the tank? If the water going in is hot and the line out is very cold you have very little boiler water going through the loop. Make sure the isolation valves on the loop are open. Is your boiler full of water? If the boiler loop lines are hot going in and coming out, the tank is full of rust or debris and no water can get to the fins on the internal tubing to pick up heat. If that's the case there is no repair and its time to get a new tank. Hope this helps good luck.
Nov 04, 2014 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
Boilermate er3
is it an electric or gas or oil fired. Er3 means it is not getting up to temperature within the required time. Electrical - element bad. for oil or gas, no ignition or fuel supply.
Oct 28, 2013 | Amtrol ST-120V-C THERM-X-TROL ASME...
AMTROL Boiler Mate no hot water
You might have bad faucet cartridge or check valve.
Possibly a clogged line.
Contact amtrol info@amtrol.com to hear them suggest calling local technician
Otherwise Amtrol does not post service information or service manuals.
Post question on pro water heater forum to hear them suggest a few things before you call local service technician.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Use search feature on forum above, before calling local service technician
Read suggested answers at fixya before calling local plumber.
Call amtrol and ask why they do not post service manuals or service information when so many promoters are selling the product.
May 17, 2013 | Water Heaters
Amtrol boiler mate wh7l error code 2
I have also problem before on my Amtrol boiler mate wh7l but it has a warranty, so I did bring it to my local dealer shop and they had fix it. I think no other solution than bringin them on local dealer shop they had plenty of technician to fix em.
Dec 15, 2012 | Water Heaters
Armitrol boiler mate hot water maker has code er3 and we have not hot water. can u tell us what that code means?
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand. multiple scenarios can cause this
CAUSES
-bad sensors
-no hot water from boiler
-bad thermal transfer
-low delta T across water heater
Dec 02, 2010 | Amtrol ST-120V-C THERM-X-TROL ASME...
Wh 9L amtrol water heater..the water temp is too hot.. the heater is 10 yrs old is it possible to remove the temp probe and clean?
Amdrol makes indirect-fired water heater that gets heat from a boiler
http://www.amtrol.com/boilermate.htm
1) Pdf manual on amdrol website show a mixing valve that mixes cold water with the hot water so water temperature going to faucet stays the same:
http://www.amtrol.com/pdf/MC10169%20BMconstantempflyer.pdf
You set the temperature of the mixing valve.
You can also set up 2 sets of pipes ... one is connected to mixing valve that goes to sinks and tubs. The other pipe bypasses mixing valve sends hotter water to washing machine.
2) The manual for Amdrol:
http://www.amtrol.com/pdf/9040-586%2001_09%20BoilerMate%20Indirect%20IO.pdf
The new models has a temperature sensor that plugs into digital readout.
This is a thermistor sensor wire that can be ordered as repair part
3) Amdrol has e-mail address:
info@amtrol.com
4) You can post your question on a water heater forum
Nov 11, 2010 | Amtrol Water Heaters
AMTROL Boiler Mate - No hot water
Most likely either a bad controller (which is the little display you use to reset) or the temperature probe which is accessible on the underside of your tank. Sensor is a 2 wire probe in center of underside and easily replaced.
Jun 08, 2009 | Water Heaters
No hot water at faucet
may need new circulater or bleed air from that zone
Apr 14, 2009 | Water Heaters
No hot water from the Amtrol Boiler Mate model wh7p
The smart control was only reading 140 it never went up or down from that number and now it has an ER3 code seem the circulator just runs and runs
Mar 09, 2009 | Water Heaters
Water Heaters Logo
116 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
