Question about Samsung WF337AA Front Load Washer
My samsung compact front loader washer has error code 1E..help
When the washer is turned on, the 1E error code comes on, and sounds like it's trying to drain machine, but never stops. Thanks
  • 3 Answers
SOURCE: error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Posted on Jan 26, 2009
SOURCE: Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
Posted on Jun 10, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
SOURCE: washing machine stops and flashes 4E
1. WATER SUPPLY ERROR – Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Posted on Feb 23, 2010
TheMobilian
  • 8220 Answers
SOURCE: front loader washer machine will not drain all
I would check the pump for objects, clean the filter, look into the hose adjacent to the pump for objects slowing the flow. I have a manual for you: HERE
Posted on Feb 24, 2010
ERROR CODE 1E SAMSUNG TOP LOADER
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve. TO TEST IT SEE PICS ATTACHED
MAY WANT TO TEST THE WATER PRESSURE SWITCH AS WELL BELOW
Jun 15, 2015 | Samsung SW62ASP Top Load Washer
LG Tromm wm1815cs front loader washer error message 1e. Have cleaned filters, checked hoses,and supply source, I still get message,
R u sure it is not an (LE) error code. Kinda looks like an upside down (F)? Very common on older LG washers. Indicates a hall sensor/ motor position sensor error.
Mar 22, 2015 | LG Washing Machines
How doI unclog the drain on my front washer. It runs and then the last 5 minutes the error code 5ud5 comes up.
5UD5 =SUDS Indicating inability to drain or an unbalanced condition due to using too much or the wrong kind of detergent. You may need to use HE type for high effenciency. Very important for front loaders. If the drain is truly clogged try back flushing with a hose before tearing it down. It's messy but may save you a service call.
Oct 08, 2014 | Maytag MAH2400AWW 2.4 cu. ft. Compact...
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
My washing machine had an error code of 1E, and now will not wash on any setting except the "quick wash" - and even then, occasionally the detergent will not go through. It is an LG front...
It is not 1E, but I.E which is "INLET ERROR", the inlet valve is not letting the water through, it does sound intermittent though, please check the following, if it does not solve your problem, the Inlet valve should be replaced (Which can be bought at any reputable Appliance Spares Shop)
- Is the tap open fully?
- Check the Inlet Hose, is it kinked in any way?
Hope this helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM-2277HW Front Load Washer
May 19, 2009 | Samsung SW62ASP Top Load Washer
Samsung B1245 front loader
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Mar 15, 2009 | Samsung B1245 Front Load Washer
Samsung WF337AA Front Load Washer Logo
762 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
