Question about Vivitek V37835 46 in. LCD Television
I can't seeem to find out how to put the new lamp back into the t.v
    Problem Solver:
  • 10 Answers
if this is either of the 51" or 56" DLP tv's, it is very simple.
-Make sure tv is UNPLUGGED!
-Open the side compartment on left side of tv as you are facing it from the front.
-Take off the door and you will see the lamp housing.There are 2 screws facing you.Unscrew these and set the screws aside.
-Now pull on the housing a little and it should slide out.You may need to wiggle it a little.
-Set housing down on table or somewhere with good light.Make sure not to touch bulb of either the old lamp or new as oils from fingers can distort picture.
-Now,undo screws on shiny metal piece.There are 2.Take off metal housing piece.
-You now see the back of the bulb.If you look at the lamp from the front,you will notice where the 2 wires are fitted into a bracket with 2 screws.
-Unscrew those screws to loosen the bracket.The replacement lamp should have the exact same bracket.If not you can just undo the wires to the old lamp and connect the same wire harness to the new one.
-once the wire bracket is unscrewed, pull it out of its fitting and then unscrew the 4 screws holding the lamp in.
-Take notice of how the shiny metal clamp-fitting is situated to hold the lamp in place so you can put it back on the right way.
-Once loosened, the bulb should be able to come out and you can put the new one right in it's place. Make sure to keep the top wire connector on the bulb at about 11 o'clock and that a nub on the bulb fits through a spacer on the shiny metal clamp-fitting.
-Now tighten the 4 screws on the clamp-fitting and make sure the wire screw connectors on bulb are tight as well.
-Take the now loose rubber-covered wires and tighten them into the bracket-fitting the way the old ones were,with plugs and lamp facing the same way.
-With everything now tight,put metal housing back on and tighten the 2 screws down.
-Take the whole unit and slowly slide it back into the tv making sure that the plugs slide into their rightful place.This should be easy,but may require a wiggle or two.
-Now screw in the 2 screws you have left into the plastice mounting piece. Re-attach the door and plug the tv in.Wait a few minutes and then turn on tv.
-It should work.If not, unplug tv and check all connections.
TIP:Do not put a cold bulb in and then turn on immediately.I like to let the bulb sit in the tv with it plugged in for a while until the bulb is warmed and ready.
Good Luck! -Chris
Posted on Mar 31, 2009
  • gunner722 Mar 31, 2009
    Sorry,
    I am new to this forum and looks like you have an LCD tv, not DLP.
    This should be handy for anyone else trying to replace their DLP lamp though.
    Good luck.
I have a wd-57833 work good I got the same one from some one put in a new lamp tv work for 5 hr then stop working on sound or picture but the lamp is good i put in in my tv and it works so i put the p
If the lamp is new and good to go then you may have to reset the lamp replacement counter in your setting menu. When that is set back to zero you wont have a problem until it is time for a new lamp again.
Aug 19, 2014 | Mitsubishi WD Televison & Video
I bought a new Sony xl5100 lamp. Delicately and accurately replaced the old lamp with the new one. Installed the lamp and housing correctly. Closed the lamp access doors correctly. Turned on TV...red light...
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jan 11, 2014 | Sony (XL-2400) Projector Lamp for...
TV has new lamp but no color
Tried putting the old lamp back?
Jun 14, 2012 | Sony KDF-37H1000
How do i take the lcd lamp out?
Remove two outter screws from back of tv,
take off front panel
moz-screenshot.pngremove lamp cover with coin
remove old lamp
put in new one make sure you do not touch the glass you do not want oils on that surface
put back on lamp cover
put of front cover
Feb 14, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
Replaced the lamp in my Dell 3200mp projector when the lamp indicator came on. After replacing the lamp indicator is off , but the lamp will not even attempt to light. Anything else I can check?
did the old lamp fail? Or did the lamp light just come on?
Firstly I would disconnect the mains and carefully put the old lamp back in. Test the projector. Then put the new one back in and test.
There can be problems with lamps not being seated correctly, and/or the lamp cover not being fully closed.
Post back for more help if required.
Dec 29, 2010 | Dell 3200MP Multimedia Projector
How to replace the projection bulb?
LAMP DOOR LOCATED IN THE BACK ON THE RIGHT HAND SIDE LOOKING FROM THE BACK. IT IS HELD ON BY 2 SCREWS THE LAMP IS SET BACK IN THE TV ABOUT 5 INCHES FROM THE LAMP DOOR SUGGEST A LONG FLAT HEAD SCREWDRIVER TO LOOSEN THE LAMP. INSERT NEW LAMP AND PUT LAMP DOOR BACK ON. THERE ARE INSTRUCTIONS IN YOUR OWNERS MANUAL.
Dec 16, 2010 | Mitsubishi WD52527 52" Projection HDTV
How to replace a bulb for kd rangehood
This is for a smeg KD series, it depens on the model which lights are used.
LIGHTS REPLACEMENT:
Before performing any cleaning and/or
maintenance operation, disconnect the hood
from the mains supply.
According to the model, the hood can be equipped
with different kind of lighting such as incandescent,
halogen and neon lamps.
a) Incandescent lamps: E14 – 40W 230V lamps.
To replace them, remove the transparent fixture
from the control panel, unscrew the lamp and
screw in the new one.
b) Halogen lamps: G4, 20W - 12V lamps . To
replace the lamp, use a screwdriver to remove
the glass-supporting ring. Then remove the old
lamp and insert the new one.
Put the glass back, securing it with the ring.
c) Biax neon lamps: G23 11W lamp. Once the
fixture has been removed, remove the biax lamp
from its seat and support.
Put a new lamp in, performing the same
operations backwards.
d) Neon lamp: 15/18W neon tube. To reach the
neon tube, unscrew the glass framework screws.
Rotate the tube 90 degrees and remove the neon
lamp. Install the new neon tube and put the glass
framework back.
Hope this helps
Apr 13, 2010 | Kitchen Ranges
Changing lamp
Lamp replacement is not difficult in Sony KDF-E60A20 TV and procedure is written in user manual.
Unscrew two thumb screws at lower corner at back of TV and take off lower front panel, in approx center of lower front of TV, lamp cover is located, unscrew it, remove it and lamp is there, unscrew lamp with hex key (supplied in new lamp box) and take out old lamp, put new lamp and put things back in reverse order.
Click Sony Support if you want to download user manual copy of TV.
Thanks.
Sep 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
HL-P5O63W : Rear Lamp Cover Error!
That my be the color wheel you are hearing
They will make a huge whining noise
The lamp door also had issues the lamp switch must be in the up position when you put the door back on
Feb 09, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Lamp Indicator is Orange
Press 'Enter' on the TV then press 'Mute' on the remote while holding 'Enter' down. A menu will pop up on the screen, allowing you to reset the light. It's also worth noting that you can get to the service menu by pressing 'Menu' on the remote and TV at the same time. There is an option for checking the number of hours on the lamp.
Apr 19, 2007 | Zenith E44W46LCD 44" Rear Projection...
Vivitek V37835 46 in. LCD Television Logo
99 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
