Question about Dell Latitude D800 Notebook
How to turn my blue tooth on - Dell Latitude D800 Notebook
  • 741 Answers
First you need to make sure you have it, many a headache has happened just to find out they don't have it. Go into Device Manager, scroll down and if you do have it you'll see a Bluetooth button. Then go into Control Panel>Classic View>there will either be a Bluetooth Icon or a network places Icon depending if you are using Vista or XP. Double click on it and then double click on Bluetooth. That will put it in Discovery Mode. Then if a Bluetooth device gets near it then it will automatically pick it up and work. If you have any questions let me know..
rate this solution before logging off.
Posted on Mar 10, 2009
How can I setup blue tooth on the tablet to talk to my cell
Go in to setting look for blue tooth press it, go to your phone settings and look for the same thing on both units press Pair with device. At this time the blue tooth should turn on, blue tooth then should allow both units to hook up with each other FYI pass word should be 0000. if you need it
Mar 14, 2015 | PANDIGITAL SuperNova
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
you could connect using your bluetooth, just turn on your bluetooth and connect.
Jul 15, 2011 | Cell Phones
I have HP Pavilion DV6 model no WW146AV.How to activate bluetooth in this model
If your particular model of HP has the blue tooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the blue tooth, as well as the wireless LAN. A blue tooth icon should appear in your task bar near the clock when blue tooth is turned on. ELSE
You have to go into start, then all programs, then look for the blue tooth connection setting. Hope this helps.
Go into start, then all programs, then look for accessories, the find blue tooth wizard. You can switch it on via that.
Mar 21, 2011 | HEWLETT-PACKARD Hewlett Packard Hp...
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Feb 21, 2011 | Plantronics Explorer 230 Bluetooth Headset
I turned my headset on and now the blue light is on and I cannot turn it off.
your blue tooth device is in discovery mode you must pair it with your phone again,it just you held the power button down to long turning it on ,most blue tooth manufactures use the power button for the discovery mode,in case you don't have the pairing pin code again most blue toooth manufactures use a 4 digit factory code,they are as follows 0000,1234,1111 or 9999 i hope this helps.And if your blue tooth drained the battery and you need to charge it before you proceed ,to put it into discovery mode hold the power button down for 6 to 10 seconds when turning your blue tooth device on.i hope this helps
Feb 18, 2011 | LG HBM-760 Bluetooth Headset
Bluetooth video is blocking my webcam on my labtop. i can not get access to my webcam it says that the bluetooth is blocking it.
If your not using blue tooth try turning it off. You didn't say what operating system your using. On windows 7 you can just click the window icon and type blue tooth in the search window. It should find your default program and get you to where you need to be to turn it off. :You may have some thing on your task bar that allows you to turn off blue tooth. Also try opening control panel and selecting device manager, Look for anything that list blue tooth and disable it. You might have a program on the the program bar under accessories that is listed as blue tooth. Somewhere you should have a way to turn it off.
Feb 17, 2011 | Computers & Internet
How to I turn off Bluetooth
Just go to blue tooth sub menu then turn off you blue tooth. If it does not work , your blue tooth is in problem and to fix at dealer.
Jan 30, 2011 | Samsung S3600 Cell Phone
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
Motorola Razr 2 V8 blue tooth will not power on
my motrola v8 b tooth can b powered on , and it can recieve data but i cannt send data to any blooth tooth device , the send botton in the last not working, cn u tell me why.....
Oct 18, 2008 | Cell Phones
Dell Latitude D800 Notebook Logo
236 people viewed this question
Alun Cox
