Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
I have a freeagent go 500gb portable hard drive. Can I partition?
I have a freeagent go 500gb portable hard drive. Is it possible to divide it into two 250gb partitions? I'm not a computer geek, so not sure I'm even describing it correctly. I have two laptops and want to keep info from both separate. If this is possible, how would I go about doing it? One laptop had XP on it. The other has Vista. Will this be a problem?
  • lbwlbw Mar 10, 2009
    Update:
    Both laptops have XP. My mistake in thinking one had Vista.
  • 59 Answers
Use AOMEI Partition Assistant to split one Partition into two without data loss.http://www.disk-partition.com/help/split-partition.html
http://extend-partition.com/resource/how-to-make-a-partition.html
Posted on Dec 20, 2012
    Genius:
  • 1,061 Answers
YES YOU CAN YOU CAN INSTALL AND USE ACRONIS DRIVE PARTITION OR CONTACT SEAGATE TECH SUPPORT AND THEY WILL ASSIST YOU.RICHARDM69
Posted on Mar 10, 2009
Seagate freeagent go
It is a better job to extend the partition with 3rd party partition software, you do no to do much effort and then you could achieve the goal, and there are several free partition software that could achieve this goal without data loss like AOMEI Partition Assistant, Gparted live CD and so on, i prefer Aomei, it is much friendly than Gparted and the Diskpart commond.
Sep 19, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I am trying to format my FreeAgent GoFlex 500 GB to FAT32, but the only options available to me are NTFS, and exFAT. How do I format it to FAT32?
The problem is that Windows doesn't format anything larger than 32GB as FAT32. You need to use a specific tool to do so. Have a look at this website
Jul 22, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
How do I format my new Seagate 500GB FreeAgent GoFlex Hard Drive to Fat32 for use with Xbox 360? I am using Windows 7 and when I open up the formatting options only NTFS and exFAT are available.
Windows Disk Management can only format a hard drive less than 32 GB to FAT32. If you want to format your 500GB drive to Fat 32, you need to use third party program like AOMEI Partition Assistant. http://www.disk-partition.com/free-partition-manager.html
Dec 25, 2010 | Seagate 500GB FreeAgent GoFlex Hard Drive
HOW TO PARTITION FREE AGENT 500 HARD DISK. i HAVE NO PRIOR EXPERIENCE AND WOULD LIKE TO ENSURE EXISTING DATA IN FREE AGENT REMAINS INTACT. pLEASE ADVISE
First, copy all of the data from the drive to another as a backup.
Now the drive already has a partition or you would not be able to store data on it. Therefore, you could only be speaking about dividing it into multiple partitions.
Therefore you delete the exisiting partition and then create smaller partitions. In Windows you will be limited to 4-partitions.
I hope this helps.
Sep 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a freeagent go 500gb portable hard drive. Is it possible to divide it into two 250gb partitions?how?
yes it is possible. First you can use a partition software. The second is using the disk management tools, these are the steps.
1.To run Disk Management Tool, click on Start, right-click My Computer, and select Manage from the menu that appears. When you see the Computer Management window, click the Disk Management item listed underneath the Storage heading. You then see the main Disk Management pane in the right side of the Computer Management window.
2.Creating the partition: Unallocated space appears as an Unknown Partition in the Disk Management diagram, you can use it to create a new partition in some or all of the space. To create your new partition, you need to right-click on the part of the diagram that represents the unallocated space, the unallocated space has a black stripe running along the top and then choose the "New Partition" on the menu that appears. To create your new logical drive in an extended partition that has free space The free space has a light green strip along the top, right-click on the free space then choose New Logical Drive from the menu that appears. Now you will see the New Partition Wizard.
The Partition Wizard will asks you to specify the following:
1 The Type - Primary, extended, or logical partition. Your hard drive can contain up to four primary partitions, or three primary partitions and one extended partition. Choose the primary partition if you are created a partition in which you will install an operating system (this is unusual situation). Choose extended if you plan to create several logical partitions within it. The logical partition type is available only if you choose to create the new partition in an extended partition with some free space.
2 The Size - You may use the entire available space, or leave room for more partitions. The Partition Wizard will displays the minimum and maximum size for the partition, this is based on the space where it will be stored
3 The Drive letter or path - Two operating system on your computer. You may select any unused letter, but the wizard will offer the next available drive letter. To Mount in the following empty NTFS Folder, you need an NTFS partition with a drive letter on the same machine. You may select the "Do Not Assign A Drive Letter Or Drive Path" option, this will let Windows assign a letter later, usually the default drive letter.
4 The File system - The default is NTFS (recommended), but you can use FAT32 (not recommended) as well. Both NTFS and FAT32 will efficiently utilize disk space on large drives.
Note: NTFS has better security features, the better recovery capabilities after a major crash, and has file-level compression built in. NTFS will also give you the option of enable compression.
5 The Label - Type a name for the partition, name it something that will indicating what you will use it for, data files, my files, fatboy one, etc.
I hope this solution was helpful.
Aug 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Partition external hard-disk
You can partition your hard drive using any of the available free partition tools such as EASEUS Partition Master or Partition Logic. You can even buy tools like Partition magic to do the same job.
Please rate if Helpful.
Thanks
Apr 12, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to partition FreeAgent Desk
use any Partition Manager (google and download)
Dec 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have Seagate - FreeAgent Go 500GB External USB 2.0 Portable Hard Drive, I formated with MAC now is now detected by my PC. What should I do?
Open up the control panel with the drive connected, open administrative tools and computer management. Select storage and see if the drive is listed there. It will probably let you format it from there.
Oct 24, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
PARTITIONING MY FREEAGENT PRO 500GB
why dont you just make use of win98 bootable disc or smart installer to partition the stuff?
Feb 05, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
1,024 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
