Question about Toshiba Tecra M5-S4331 (PTM51U-0LD01P) PC Notebook
On start up my Tecra M5 is coming up with a PCI Express Error and wont progress and any further. Disk drive is okay and works in another laptop of the same type.
Toshiba tecra p5 up on black Screen on PCI EXPRESS ERROR can't boot????
If you can't boot to the bios, you are in major trouble. You can try and see if the manufacturer has a bios flash program you can load on a Flash drive to flash the will have to research that on another computer, obviously.
Nov 25, 2014 | Toshiba Computers & Internet
PCI Express Error. Cant boot at all.
Open the bios menu and change the boot settings to USB or DVDdrive whichever one you have youe OS on.Restart and it will boot.
Nov 20, 2013 | Toshiba TECRA M9 Notebook
Toshiba tecra m9 pci express error
PCI is a slot/interface at the rear of a lot of standalone pc's,you dont have them on newer pc/laptops,perhaps you just dont have the hardware
Jun 20, 2012 | Toshiba TECRA M9 Notebook
Tecra m5 fingerprint scanner anable
Go to Toshiba website and check under support for specific problem.
Mar 08, 2012 | Toshiba Tecra M5-S433 Notebook
I have a toshiba tecra m5 and is showing a message PCI Express error
Welcome to Fixya.
The error that you are getting pertains to a system board-related hardware issue. Please understand that there are no DIY instructions to get this problem fixed as motherboard replacement is the only solution.
I strongly suggest for you to contact Toshiba's support (follow link below) for repair options :
Toshiba Support Website
Tech Support Toll Free number : 1800 457 7777
Thanks for using Fixya.
May 25, 2011 | Toshiba Computers & Internet
I have a toshiba tecra m5 laptop & when i start it it showes the Toshiba logo then it displays a black screen with a note ( pci express error ) so i ask for help with this problem thank you for...
there could be many problems, you will probably have to contact toshiba tech support on this one, but you will prolly need a new motherboard.
Nov 06, 2010 | Computers & Internet
Trying to find interal connectors 2-1 pin audio spdif on a emachine 1831-05. motherboard is mcp73vt-pm
It has been stated from my sources, that the ECS GF7050VT-M5 mobo, is the same as the ECS MCP73VT-PM, with a slight difference.
The difference being that the MCP73VT-PM mobo is based on the Micro-ATX form factor, and the GF7050VT-M5 is based on the ATX form factor.
[ Micro-ATX form factor size is 9.6 inches by 9.6 inches. 9.6 inches is approximately 9 and 9/16ths inches. It's also 244mm by 244mm.
ATX form factor is 12 inches by 9.6 inches. 305mm by 244mm ]
ECS GF7050VT-M5,
To the right of the subheading - Download, left-click on the server location nearest you.
[Taiwan, USA, Europe, China ]
This is a PDF file download. (Motherboard Manual) May take a few seconds before you see the first page, and additional time for the file to fully download.
Suggest you let the file download all the way, before looking through it.
I'm also looking at an ECS MCP73VT-PM on Ebay, as well as the PDF motherboard manual for the ECS GF7050VT-M5.
Motherboard oriented so that the Processor is to the top, ram memory slots to the right, and the orange PCI Express x16 slot to the bottom, the SP/DIF header on the GF7050VT-M5 is located to the left of the PCI Express slot.
From the poor view on the Ebay link, the MCP73VT-PM also seems to have the SP/DIF header in the same location, but clocked differently.
The header is clocked perpendicular to the orange PCI Express x16 slot, while on the GF7050VT-M5 the SP/DIF header is parallel to the PCI Express x16 slot.
The header is 4 pins long, with 1 pin not installed.
Pin 1 is marked on the motherboard.
Pin 1 is SP/DIF Digital Output
Pin 2 is +5VA ( 5 Volt analog power)
Pin 4 is Ground
There is no Pin 3.
Apr 06, 2010 | Computers & Internet
PCI express error
Unfortunately this is a very broad error, i suggest you contact Toshiba support on this one,
Which could lead too your motherboard been replaced.
Feb 09, 2010 | Toshiba Tecra M4-S435 Tablet PC
What jumpers do i need to short in the toshiba tecra m9 to reset password. THANKS
i have toshiba tecra m9, i get the error massege when i on the laptop. the error massege is "PCI Express error". plz help how to remove this massege...thax..
Jan 04, 2010 | Toshiba TECRA M9 Notebook
Dead hard drive, replacement not working
The solution is that you simply cannot go out and buy a replacement HD. You have to buy TOSHIBA's replacement HD.
They make a 40, 80, 160 and 320 GB HD for Tecra MV2's etc.- Other HDs simply will not detect.
Jun 05, 2009 | Toshiba Tecra M2V-S310 Notebook
Toshiba Tecra M5-S4331 (PTM51U-0LD01P) PC Notebook Logo
431 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
