Question about Sunbeam Food Mixers
Need to replace cord on vintage Sunbeam Mixmaster Junior
There are two seemingly inaccessible screws (of the four that attach the handle to the "head" of the mixer). How do you get these out? Any tips on disassambling the rest of the mixer to be able to put a new cord in? I haven't tried to take the rest apart, since the two screws I mentioned hold the cord in place below the speed switch. It may be easy but I thought I'd ask for any tips in case there are other special
obstacles in the back part of the mixer. I really want to fix this one
because it worked great (before the cord frayed too much to be safe)
and it was my grandmothers', and the new mixers, at least the inexpensive ones, are crappy!
Thanks in advance!
Diane
For mixmaster junior, but should be relevent to many old sunbeams:
That's not the power cord going to the speed switch. You don't need to get those screws off.
To replace the cord:
Cut the old power cord near where it enters the blender.
remove the two front screws, pull off front housing.
remove 1/4" nuts found in recesses of exposed front plate.
pull speed handle out far enough to get a screwdriver under exposed front plate, and pry gently. It'll come off as it's a friction fit.
cooling fan blade is now visible, you need to remove it.
pry up gently on the teeth attaching it to the motor shaft.
Work your way around the 4 sets of teeth, it'll come off. Don't lose the two washers.
unscrew the electrical contacts.
take off the speednuts holding the brush assembly in place.
gently pull up on the brush assembly with a needle nose, until it comes out.
now remove the screws holding the motor coils in place. They're the same ones the speednuts attached to, and have hex heads you can get at with a needlenose.
once those are out, pull on the motor coils gentle, and wiggle them out of the housing.
You'll see the stub of the old power cord at the back of it.
Get a round replacement wire of the right diameter, thread it through the cord hole in the blender, and connect it up to the coils.
-I had to drill the power cord hole 1/16" larger than it was to get a modern cord to fit through it.
On the stub of the old cord, you'll see a metal ring which serves to anchor the cord in blender body. remove it (screwdriver + needlenose and pry), and attach to new cord at the righ position.
Put everything back together, being careful not to bust the carbon brushes.
Congrats, you now have a functional blender with a cord that won't try to electrocute you.
Posted on Oct 05, 2009
  • fridrich Jan 03, 2011
    Hey Blonk, thank you!
    This worked great. Everything just as you describe. Watch the electrical contact wires when removing the brush assembly, don't pull them out of the coil.
    Habit-Forming:
  • 23 Answers
Www.nelsonezy.com sells replacement cords.
Posted on Jun 12, 2012
  • Richard Nelson
    Richard Nelson Nov 03, 2013
    NelsonEZY.com repairs Mixmaster Jr.'s!
How do I tighten the speed control dial on a vintage Sunbeam Mixmaster PowerPlus?
There is a cover plate over the screw that you need to tighten. This cover plate is held in place by two spring latches, 180 degrees apart. Use a small flat-tip screwdriver to depress first one latch, then the other. Don't use too much force - the latches are plastic and will break if treated roughly.
Jan 27, 2015 | Sunbeam Food Mixers
Need handle replacement and power cord for sunbeam mixmaster mmb
NelsonEZY.com stocks the power cords. The handle should be available on eBay. NelsonEZY com home page
Mar 22, 2014 | Sunbeam Vintage Chrome Mixmaster Mixer Mmb
How to disassemble a sunbeam 2370 mixer
To disassemble a sunbeam mixmaster 2370, find four plastic snappers arranged at 1, 5, 7 and 11 o'clock around the front circle of vents. They can be seen with the help of a good flashlight. un-snap them and the top and bottom shells will separate. From there on, it is clips and screws. Good luck!
Nov 28, 2013 | Sunbeam 2370 MixMaster Series Stand Mixer
Mixmaster junior
This is an issue you will have to take up directly with Sunbeam. Be sure to provide specific model information
Aug 04, 2013 | Food Mixers
My sunbeam mixmaster is about 40 years old and suddenly stopped working
The running capacitor finally died. I used to be their factory service tech. You can change it easily by removing the back knob and the handle. The screws are under the silver buttons. The capacitor looks like a 3/4 x 1 1/4' tube with a small nib sticking out each end.
Dec 26, 2012 | Sunbeam 2366 MixMaster Series Hand/Stand...
Vintage Sunbeam Mixmaster MXG makes a strange noise and has a burning smell when operating. Is there anyway I can fix this?
the motor is burning out at the coil you can send it into a electric motor re winder but it could be expensive look them up in your local directory
Jul 04, 2010 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Mixmaster... where's the model number?
Lift up the head, should be right by where you insert the blades
Jan 24, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
I have a Sunbeam Mixmaster from mthe 1970s,
If this mixer sits on a stand, first remove it from the stand. Turn it upside down and shine a flashlight into the right side socket to look for obstructions. When you say you swivel the head, do you mean you rotate the handle? This is how to eject the beaters after use. It may be that the ejector on the right side is stuck. If so, you will need someone with mechanical skills to disassemble & repair.
May 23, 2017 | Sunbeam 2366 MixMaster Series Hand/Stand...
Food Mixers Logo
2,381 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
