Question about Optoma EP750 Multimedia Projector
Optoma EP755 new lamp when power standby button
Optoma EP755, new lamp, when power standby button pushed, led changes from flashing red to solid red, lamp cooling fan does not start, no light from bulb.
  • Anonymous Mar 22, 2014
    My Optoma HD80 powers up after self-test, the fans start, the color wheel starts to turn, the lamp comes on and then everything stops, no fans, no wheel, no lamp and the control panel Blue LED's all flash with no Red warnings at all. It will not switch off from the power switch, when unplugged and left it does exactly the same when tried again, any help please
  • 4 Answers
You need to reset the lamp timer, usually done by holding some buttons while turning on
Posted on Mar 10, 2009
    New Friend:
MY SHARP PROJECTOR STANDBY LIGHT ON OFF WHAT PROBLAM
Posted on Dec 31, 2013
Optoma hd73 the temp light is red and wont start fans or light just the standby light on flashing could this be a ballast issue or thermal sensor?
if you projector auto shut down, and Lamp LED Light - Check Lamp - Check Lamp Driver - Check Main Board b. Temp LED Light - Check Thermal Sensor - Check Thermal Switch - Check Fan
May 12, 2016 | Office Equipment & Supplies
Optoma ep 1690, the on/standby led is flashing green but when I try to turn it on the temp and lamp led's flash twice and nothing happens, the on/standby continues to flash green.
The projector lamp life may have exceeded its safe limit, check your instruction manual, sometimes you have to hold the on or off button for 10 seconds to reset this. All manufacturers are different but that may be the problem.
Here is a copy of the manual, I havn't read it, my solution is from experience of other projectors.
http://www.myprojectorlamps.co.uk/projector-manual/Optoma/EP1690.html
Good luck
Aug 04, 2011 | Optoma EP1690 DLP Projector
The problem with my projector is it keeps flashing green and red
hi,
your statement is not very specific but if the power led is flashing green and the lamp led is flashing red that indicates a fan failure.
contact optoma support here and enquire if you can have a warranty repair, or how much it may cost to have the fault fixed.
Feb 14, 2011 | Optoma HD65 DLP Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
Optoma 719, can't get lamp and fan to turn on.
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Jan 31, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Only power light will power on for few seconds then flashes.
Does the main lamp light at all? It sounds light a cooling fan failure. If the fan iis not working the the main lamp will not turn on and the power light will flash.
Jan 07, 2009 | Optoma EP755 Multimedia Projector
Orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Nov 12, 2007 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
No Picture
its probably the ballast that is bad, call Optoma and you can buy a ballast for it, but you will probably want to have a pro do it, changing the ballast is a lot more involved than just changing the bulb, the ballast is what powers the bulb and it does go out on occasion.
Oct 28, 2007 | Optoma RD65 65" Rear Projection HDTV
Optoma EP750 Multimedia Projector Logo
1,741 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
