Question about Dell Latitude D620 Notebook
Battery My battery light is flashing on my Dell D620 latitude. It goes dead when I unplug it from the power source, but light flashes regardless.
    Scholar:
  • 54 Answers
The flashing light is telling you that your battery is not holding a charge. The fact that it goes dead when you unplug it tells me that the power adapter is working properly and the battery is the suspect. If your computer is under warranty, contact Dell for a replacement battery. If not, you'll need to purchase a new battery.
Hope this helps.
Posted on Mar 10, 2009
Battery light flashs orange continusly on a dell latitude d620 if i disconnect the power cord the computer shuts down
Two possible causes for flashing Amber battery light.
1) Your battery won't charge and needs to be replaced.
2) Your charging circuit for the battery is defective and then your motherboard of laptop will need to be replaced.
Oct 20, 2011 | Dell Latitude D620 Notebook
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
My dell d620 laptop need a battery, I want buy one online, so everybody, how about this http://laptopsbattery.us/dell-latitude-d620-battery.htm ?
The one you have listed is for a good price but this one may be a tad bit better:
http://www.amazon.com/7200mAh-battery-Latitude-Precision-serie/dp/B001RNACES
Price is a bit better but its just knowing what the shipping is going to be.
May 28, 2010 | Dell Latitude D620 Notebook
My Dell Latitude D620 Screen is Black and the keyboard dosent work when I turn on the computer. The only LED light that shows is the power light, the wifi or the little cylinder light dosent work. I can...
remove all attached devices like printers or flash drives. remove battery and power on using ac adapter only. if it still wont work, try another good ac adapter. make sure ac adapter light is on. if it still shows the power light on and nothing else, replace motherboard.
May 15, 2010 | Dell Latitude D620 Notebook
Dell Latitude D620 isn't getting power to the mainboard.
diagnostic procedures as follows:
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. get a new battery replacement.
No. Call Dell for technical assistance.
if you need Dell latitude d620 Battery you can go to online shop
http://www.global-battery.co.uk
http://www.sales-batteries.com
here you can perchase high quality battery easily
good luck!
Feb 04, 2010 | Dell Latitude D620 Notebook
Battery light flashes red
Your battery is dead.
When the 1,3, 5 lights are flashing when you press your battery test button, then it means your battery is dead and will not hold a charge. You can still use your PC on A/C power with no issues, but if you want to use it on battery power then you will need to purchase a new battery.
sorry
Sep 16, 2009 | Dell Latitude D600 Notebook
I cannot get the laptop battery to charge.
I had the same problem with a D620 at work. The laptop worked fine but the lights kept flashing on the front. I tried a few different things but it ended up being a bad battery. If the battery is less than a year old Dell will replace for free. Otherwise, you'll have to purchase a new battery.
Feb 23, 2009 | Dell Latitude D610 Notebook
Dell Latitude D620 Notebook Logo
879 people viewed this question
Alun Cox
