Question about Apple iPod nano
Ipod not charging
When i plug in my ipod my computer no longer recognizes it.
ipod screen says no battery power remains.
  • snow cedar
    snow cedar May 11, 2010
    try downloading the latest version of itunes... if that doesn't work, try reformatting your ipod. howeverm that would mean losing allthe contents of your player
    Problem Solver:
  • 12 Answers
It may be possible that your itunes does not recognize your player becauseno power remains in the battery. try charging your player loner or if it doesn't work that way, have the battery changed
Posted on Mar 10, 2009
There is no sound or display on the screen when it is power on
The Apple iPod uses a rechargeable, lithium-based battery that can go between 10 and 36 hours between charges, depending on the model. You can charge your iPod using either an electrical outlet or your computer's USB port, but if you find that your iPod no longer takes or maintains a charge despite having the right connections, you should try some basic troubleshooting methods to restore the device's battery life.
Connect your iPod to a different USB port or wall outlet. If you use a USB port to charge your iPod, you may simply have a low-powered port, according to Apple. You can often resolve this by switching the cable to a different port, or using a wall charger (sold separately) to recharge instead. Charge your iPod for several hours. If you find your iPod completely unresponsive even as it charges, leave it plugged in for three or four hours and check again. If your battery life has been depleted completely, the iPod will need time before it can begin functioning again. Restart your iPod. A frozen or dysfunctional iPod may fail to charge, but a quick reset can fix basic functionality glitches. To reset a touch-wheel iPod, hold down the "Select" and "Menu" buttons until the gray Apple emblem appears on the screen. For iPod Touch, hold down the "Sleep" and "Home" buttons (the only two buttons on the device). Connect your iPod to your PC using the provided USB cable, open the iTunes software and click the "iPod" tab in the left column. Then click the "Update" button to search for and install the latest iPod software. Apple recommends keeping your software up-to-date to ensure that your battery life remains fully optimized. Purchase a new battery from Apple. If your battery fails to charge despite all your troubleshooting efforts, it may simply be too old and depleted to continue functioning. By taking advantage of Apple's iPod Out-of-Warranty Battery Replacement Program (see Link Below), you can send in your iPod and receive a replacement battery or replacement http://www.apple.com/support/ipod/service/battery/ iPod for a modest fee.
Feb 11, 2013 | Apple iPod Audio Players & Recorders
How do i charge my ipod
To charge the battery, choose one of the options below:
  • Connect the device to your computer (not your keyboard) using the included cable to charge the battery and sync. Your computer must be turned on and not in sleep or standby mode. If the device is connected to a computer that's not turned on or is in sleep or standby mode, the battery may drain.
  • Connect iPhone or iPod touch to a power outlet using the included cable and a USB power adapter to charge the battery.
An icon in the upper-right corner of the screen shows battery charging status. If you charge the battery while syncing or using iPhone or iPod touch, it might take longer to charge.
Note: If using a portable computer, make sure it is plugged into power and that the lid or display is open. If the lid is closed, the computer may go into standby, sleep, or hibernation mode and iPhone or iPod touch may not charge.
Important: If iPhone or iPod touch is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, your iPhone or iPod touch may be connected with a FireWire cable. Disconnect the FireWire cable and connect the iPhone or iPod touch to a USB cable or dock.
that should be everything you need to know about charging an iPod Touch. If you require further assistance please feel free to followup with additional comments. If this solution solved the problem please feel free to rate it. Thanks and have a great day-Midwest-Tek
Aug 20, 2010 | Apple iPod touch Second Gen (8 GB,...
IPod not charging
your cable might be worn out
Jul 31, 2008 | Apple iPod nano
Ipod not recognized by computer
I have the same problem. My ipod nano is not reconized by my computer or any other and the Ipod's screen is locked. The screen doesn't light up and only apears the time and a battery half way full.It doesn't turn on or play and it doesn't turn off either, but some times it begins to work again but nor for long. I am runnig windows xp and the latest itunes version.
Jul 29, 2008 | Apple iPod nano 3rd Generation
IPod is not recognized
i have the seem probleme since i have installed a new firmware somone know where to find the original firmware ?
Dec 28, 2007 | Apple iPod MA446LL/A MP3 Player
Froze/no charge
It has a very low batteyr voltage therefor your computer cant charge it. Buy a wall charger but you may have to put it on disk mode.
Jan 11, 2007 | Apple iPod mini 2nd generation MP3 Player
Why isn't the charging icon always animated (flashing)?
For Mac users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB or FireWire port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. Battery depleted? If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging. You're using USB instead of FireWire If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only. With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear: If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub. Your Mac is sleeping Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod. Your Mac doesn't meet iPod system requirements Make sure that your Mac meets the iPod system requirements. Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple. You're missing some system sof
Sep 28, 2005 | Apple iPod nano
Charging icon
For windows users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes. The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. Here's the animated version you would see after 10 minutes, or when the battery is not fully drained: If the charging icon is flashing and your computer doesn't recognize it, Can't see your iPod in iTunes or Windows Explorer? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or Windows Explorer. The most likely causes are listed below?you'll find information for both USB and FireWire (IEEE 1394) iPod connections. Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. iPod appears in Windows Explorer but not in iTunes or iPod Updater If your iPod shows up in My Computer, but iTunes and iPod Updater don't recognize it, there may be a software conflict, or iPod Service didn't load. You may see an ""iPod Service Error"" alert or a ""Please Reinstall iTunes"" message. If you see either of these messages, try the solutions in this article to resolve the issue. Laptop or portable connecting via USB? See iPod not recognized when connected to Windows laptop over USB for more information. Your computer doesn't meet iPod system requirements Make sure that your computer meets the system requirements to use iPod for Windows. Your iPod displays an exclamation point folder or sad iPod icon, or doesn't appear in iTunes or My Computer If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue. Your iPod isn't formatted for Windows iPod for Windows Software only recognizes iPod for Windows. You cannot use iPod for Macintosh
Apple iPod nano Logo
130 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
