Very uneven heating. Burns hot at the end far from the valve. I have tried drillinog out the gunk from the holes closer to the valve, but it didn't help. There is a screw near the gas inlet, which might help and could be adjusted if I knew which way to turn it.
Your phone getting hot is a very normal thing. Mobile devices now are getting more powerful and dissipating heat using copper only goes so far. It's natural for your phone to get hot during usage, when playing games etc. But if your battery gets really hot, i.e. could cause burns or you feel that it's much hotter than it's supposed to be, please get it checked on, battery malfunctions may cause harm.
What you have is a bad case of clogged burners. At least the ends closer to you. This will require removing & cleaning the burners and the venturi valves (part of each burner) to thoroughly clean them This will also provide you a closeup inspection of all the burners for any accessive wear, or rust thru.
Once the burners are removed, use a brass bristle brush to clean the exterior of the burners and then gently yet firmly tap them on something that want damage them, Then turn them so the open end is down and any debris will fall out. Also clean the Venturi valve on each burner. It will be on the burner tube, where it fits over the burner orifice. It will look like 2 slots (1 on each side) cut out of the burner tube. Spiders like to build nest in them. After you have completed all of that, reinstall the burners, turn the gas tank back on Very, Very Slowly and give them a test. You should see a significant difference.
Hope this helps you solve the burner problem. Please let me know and Happy Grilling!!
taps just pass water --hot or could or both
water not hot enough is from a hot water system that is not heating the water
normally there is an inlet supply tap for the hot water system
if your system has a hot water control valve ( a valve that allows cold water into the hot water line (By law) to prevent scalding and hot water burns , that unit has a have a habit of failing and making the water colder that it is supposed to be
otherwise ,
check the elements for operation
Hello. I can help you. Your igniter is on its last legs.
Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
The gas burner valve is not the correct one for LP gas. You have to convert the valve as well as the orifices. The clicking is because it is over heating and cycling on and off o the high limit (safety thermostat)
You should always preheat oven to operating temperature before cooking anything.
Do not put too much in oven, leave plenty af space for good air circulation.
Do not place any reflective foil or the like on the bottom of oven or shelves, as this reflects heat, and you will get uneven cooking.
Make sure fan is working efficiently if it is fan assisted.
