Question about Jensen Car Audio & Video
Jensen UV7I Problem when i push my clutch in its mutes the sound.
I have a Jensen UV7I everything works great until i press my clutch in while driving and the headunit mutes itself. When I release the clutch the sound comes back on. Any solutions?
How do i bypass the eme brakes to look at a movie
Posted on Aug 18, 2009
I would check to see if a wire is touching the clutch pedal ,when its depressed.either its grounding out on the clutch arm or its a loose connection that is being moved by the clutch arm.
Posted on Mar 11, 2009
No Sound from Jensen VM9725BT
Jimmie Monica Hey, Its not a problem with the unit. You have the blue or Blue/White wire hooked up wrong. Disconnect both the blue wire and the blue and white wire and I guarantee the sound starts working on everything. If you have one of those two wires hooked up for a power antenna or remote amp turn on, then switch which one you are using and that will fix the problem permanently. Disconnecting them both will get it to work though. I guarantee it. Please post back and let me know if it works for you. Thanks
Sep 06, 2013
Feb 22, 2013 | Jensen VM9725BT Navigation receiver
No audio with uv10
I have Jensen uv10. I hooked it up and this no sound in a 94 f159 4x4
Mar 20, 2011 | Jensen Car Audio & Video
No sound
hi! press the audio setting and set on the audio set on
Sep 08, 2009 | Jensen VM9020TS Car DVD Player
Jensen UV7i Need internal amplifier
I own a shop either get me the PN off the IC. I will either have it in stock or, can order for you. Audiovox will not sell parts for this unit. But, they will service this unit for you. Call us @ 727-530-5221, Radioactive Car Audio #1 in Tampa Bay area since 1987.
Dec 10, 2008 | Car Audio & Video
Jensen uv7i
did you try resetting the unit?
May 29, 2008 | Jensen VM9510 Car DVD Player
Jensen VM9311/ UV7i wont turn on!!?
Yo, I've got the perfect solution to your problem. Pull out the head unit from your dash. Then, remove the wiring harness carefully from the unit. Now, push in the yellow power wire (even jiggle it a little) making sure it's tightly snug the small port of the wiring harness. Then, plug the harness back into the unit and try turning it on. I've found that the wires come lose easily on this unit. hit me back up at Darkintel74@aol.com.
Mar 03, 2008 | Jensen VM9510 Car DVD Player
I cant get a picture with my UV7i with or without the brake on
Its very simple splice the power wire "constant power" Red wire.
Next attatch the yellow parking switch wire to the constant power.
wallah... You can now watch movies on your in dash while driving! The deck thinks the brake is engaged
Alot easier then codes and pressing brake pedals and all that jive. They wont do it if your get it installed somewere so you have to do it yourself, its very easy
Nov 05, 2007 | Car Audio & Video
How do i bypass the parking brake switch in order for my video to play
isn\'t there a way to bypass the parking brake so my video plays anytime i want
Dec 15, 2006 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
120 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
