Question about Dual XDVD8181 Car Video Player
Daulxdvd 700 how do i adjust the bass on it?????
    Problem Solver:
  • 8 Answers
Go to fm then touch E
Posted on Mar 12, 2009
I have a kalmazoo bass guitar with the numbers 000011 on it. Can you tell me anything about it?
Gibson reused serial numbers in different decades on different models, which makes this tricky sometimes. However the Kalamazoo is recorded as being made from 1966 till 1969, so we can say your bass was made at the Kalamazoo Plant, MI, USA in 1967.
Depending on condition and originality, it would be worth about US$700-800 I think.
Sep 05, 2017 | Bass Music
Is the base and treble audio adjustible on this 1996 Sony TV KV- 20S20
Adjusting various sound settings (e.g. bass/treble ... - Sony
docs.esupport.sony.com/imanual/NA/EN/hx850/c_snd_qv.html
You can adjust various sound settings, such as bass, treble, balance, etc. ... [Setting Memory]: Applies custom sound settings to the current input or to common ...
General information on how to adjust the bass and ... - SONY
https://us.en.kb.sony.com/.../general-information-on-how-to-adjust-the-b...
Aug 15, 2015 - Follow this procedure to adjust the bass and treble surround parameters on the A/V ... Adjustable sound field parameters vary by sound field.
Dec 25, 2015 | Sony KV-20S20 20" TV
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Trying to connect peavey tour 700 to a trace elliot 1518 bass enclosure. Plug the enclosure to the back of the amp. Then plugged my bass into the high gain. Turned it on and nothing happens.
Check continuity on all cables, try a different cabinet with the head and a different head with the cabinet and the bass with a different rig to see which part of the chain isn't working, make sure the volume controls are turned up on both the amp and bass. Once the problem is narrowed down it will be easier to advise you.
Oct 12, 2014 | Music
MARANTZ MA 700 NOT SURE HOW TO MAKE CONNECTIONS. NO MANUEL. LIGHTS UP
you'll want to use the rca sub out from your pioneer, to almost any input (aux, tape, cd) of the marantz, then speaker cable from marantz to sub. once you get them hooked up, adjust volume, bass, on the marantz to blend well with main speakers at a nominal lvl,
Mar 20, 2013 | Audio Players & Recorders
Fender jazz bass serial no n900373 what year and value
according to this web site:
http://www.guitarattic.com/Fender%20Serial%20Numbers.htm
it could be either a 1990 or a 1999. Not particularly sought after years, unfortunately, but still a great bass. Do a google search for those years to get an idea of pricing in your region...different areas value some basses/guitars differently...probably in the 700-900 range
Mar 20, 2013 | Fender Music
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Sep 20, 2009 | Jasco GE 98903 2.1 Speakers
Not gettin enough bass
Hello saini_jatt_2, On the JBL3501 700 watt monoblock, you have adjustments for low pass and a setting for boost marked DBO, allowing you to select and boost the frequencies sent to the subs. If your amp is not the 3501, but a different JBL amp, the settings may be different. Set the LP to either the white dot (about 100Hz) or slightly below to about 80Hz. Set the HP to about midscale or slightly higher. Set the boost to wherever the bass sounds best. One other setting that will affect bass volume is the "input level" or gain control. It should have been properly set by your installer, but you can "tweak" it for best performance. Turning it up increases the sensitivity and matches it with the output from your head unit. Too high will cause distortion. Too low will result in less bass. So you want to set it just to the point that you begin to hear the distortion and then back it off slightly until the distortion disappears. Hope this helps.
Jun 05, 2009 | JBL GTO1202D Car Subwoofer
Dual XDVD8181 Car Video Player Logo
26 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
