Question about Dell Inspiron 9100 Notebook
My Aspire 3003LCi has different colored lines streaming verticaly down the left side of my screen. This happened on my other comp and it eventually went completely back. Please Help soon before my computer is ruined.
  • danielle2005 Mar 10, 2009
    can i use any external monitor? and how do i go about connecting that?
    President:
  • 2,653 Answers
There's nothing you can do. It's hardware related. Either the video card (gpu) or the lcd (most likely) is failing.
You'll have to replace some hardware to correct the issue.
Try using an external monitor, if the lines still appear then your video card is the problem, if not it's most likely the lcd.
Sorry for the bad news but it is what it is.
Posted on Mar 10, 2009
  • RescueTechLA
    RescueTechLA Mar 10, 2009
    Most laptops have a vga plug, just plug the monitor into the plug, make sure the monitor is on, then turn the computer on, it should automatically display on the external, if it doesn't try pressing FN + F5 on the keyboard, most laptops are setup this way.
    Let me know what happens or if you have any snags.
Line down the center of tv screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 04, 2015 | Samsung Televison & Video
Dell Latitude D505 half of screen is black with colored vertical lines.
Sounds like you have a section of dead pixels. This can happen if the laptop has been dropped a lot or stepped on or some type of impact on the laptop. This is a hardware issue. You will need to have the screen replaced. In my opinion, by the age of the laptop, its better off getting a new one.
Oct 01, 2014 | Dell Latitude D505 Notebook
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
I have a "purple" stripe running verticaly down the left side of my screen in all modes (Cable via HDMI and VGA) It looks like the video is wrapping around, and I do not know how to adjust it.
Purple stripe of "LCD panel Death". In most cases when there is a color strip across or down the screen, means the lcd panel it's self is gone down. In this case, cheaper to buy new flat panel tv. In some of thses models you could have a back lite out, not likely, as when the lites oare out you don't have color on that side.
Oct 09, 2009 | Polaroid TLA-04011C 40 in. LCD TV
My 42 inch lg plasma has colorful lines running verticaly on the left side of screen. i moved it to another location then it worked for a few hours then went back to the lines. what is the problem?
u might had placed some powerful magnet nearby, so pls check
if lines appear again switch it off for a few hours or remove the magnet and let it work...
it will become normal when the effect will be over
Jul 11, 2009 | LG 42PM1M 42 in. HDTV-Ready Plasma...
Acer Aspire 3003LCI Laptop Fan starts but stops after 5 seconds
remove the memory then make a clean or replace a new memory
Jun 25, 2009 | Acer Aspire 3003LCi Notebook
I have red lines up/down on my Vizio, how can I correct this?
Your sympton need to be more specific, but if what you see is 1 or more tiny lines running from top to bottom of screen (verticaly) and those lines change colors (red/green) depending on the background color on the screen, then your control board need to be replaced, you will need your TV model and product code, both located in the back of the TV next to serial number
Jun 03, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Yellow line on left side of screen-
If this is only happening on one input like your cable input and the dvd player is working great on a different input, then the issue can possibly be signal related and not a problem with the tv, if this haapens on any input you are watching, check to see if it affects the menu if it does then your looking at a Logic board issue, if it doesn't affect the menu but happens on multiple inputs then you have to replace the signal board
Aug 18, 2008 | Philips 42PF7421D 32 in. LCD HDTV
Acer laptop
Mine did that I just blew it out with some compressed air blow it out the opposite way of the air flow it fixed mine hasn't shut down since.
May 21, 2008 | Acer Aspire 3003LCi Notebook
Acer 3003lci will not boot up.
sounds like locking up on boot, hence why nothing happens when you hit F2, try tapping F2 as soon as you push power button, if still hanging, you may need to take it to get looked at, could be a number of things causing it to lock up
Dec 11, 2007 | Acer Aspire 3003LCi Notebook
Dell Inspiron 9100 Notebook Logo
Alun Cox
