Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Ice tray freezing
My ice tray is freezing and the ice depenser is blocked with ice
  • 27 Answers
The water inlet valve may not be closing properly due to dirt or some mechanical problem in it. u can clean and try
Posted on Mar 10, 2009
My ice freezes as a block when dispensed into ice tray
There are water level adjustment screws behind the plastic cover of the ice maker to adjust the water level when it refills after dumping a tray of ice. When there is to high of a water level it spills over onto the cubes freezing them into a big block. Try to adjust the level of water. There is a arrow which tells you which way to turn the screw to get a smaller fill fixing the problem.
May 04, 2014 | Refrigerators
Ice keeps getting stuck in ice maker # fsc23r505b2
Most icemakers have a low voltage defrosting element wrapped around the ice shute to prevent the ice from freezing and jamming up. Carefully have a look for any disconnected wires or damage to the heating element. If the ice is getting "glued" together in the ice box itself, its likely that the water tray is overfilling and causing water to run down into the ice box. When it freezes, it freezes all the ice blocks together. In this case, you may need a new ice maker tray or ice maker water valve.
Oct 20, 2013 | Frigidaire Refrigerators
I put a glass in the ice cube tray to chill it and forgot about it. The ice depenser froze over but that was easily fixed. Now the ice cube maker isn't making cubes.
You may have pushed the bail up which cuts off the I M
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 19, 2011 | Whirlpool Refrigerators
Ice dispener not working
Is ice in depenser? is despenser blocked? Sometimes a few cubes get too big and block it open.. becareful with your fingers. If all this checks out, then check all connections.
Jul 07, 2010 | Frigidaire FRS3R5EMB Side by Side...
How can I stop my icemaker from making a block of ice? At the front of the ice bin, a block of ice is forming as though wateer is drippping into the bin.
Open the freezer and remove the ice bucket. You should now see the tray were the ice cubes freeze, check to see if it is fractured or leaking and the position of the water outlet pipe to the ice tray. If the water pipe is firing water out of the tray just readjust it.
hope this helps you.
Jun 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
The Fridge of my Rangemaster SXS Fridge Freezer is freezing up
You probably have one of the following problems: A failed defrost system, meaning the defrost timer and/or element has gone out and your evaporator coil is frozen over; you are low on freon and this too will cause your evap coil to freeze over until the freon drops so low all cooling stops; . Unless you have gauges, a licence to buy freon and service valves (or a buddy with such) you are limited to what you can do. Here is my advice:1. unplug the frig and let it defrose over night, or unplug the frig and empty the freezer to remove the back cover to look for ice, a frozen fan and if so get your hair dryer out and melt the ice so you can test the fan and the defrost element (you will need a volt/ohm meter to do the element check. You can do it.
Oct 27, 2009 | Refrigerators
My ice depenser is freezing up and the hole the ice goes through in the door
BET IT'S A GE? YOUR SOLENOID THAT OPENS AND CLOSES THE ICE FLAP HAS RUSTED AND WILL NOT CLOSE ALL THE WAY LETTING AIR IN AND FREEZING THE CHUTE,CALL LOCAL REPAIRMAN.THANKS-MIKE
May 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
The hole where ice comes throuh door freezing is freesing up
Flap closes under spring pressure and may not be closing fully causing ice/snow build up . Bend the spring to adjust the tension and lubricate with a little vaseline
May 04, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
69 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
