Question about HP LaserJet 3015 All-In-One Printer
HP 3015 scanner not recognizing paper in feed tray
When trying to scan a document I get an error popping up on my pc says ''there is no paper in the document feeder'' even though printer display says document loaded
  • Anonymous Apr 21, 2009
    excatly the same as his/hers.
4 Suggested Answers
SOURCE: HP LaserJet 2840 Scanner problem
Yes, but I don't see any actual paper jams. I have a Vista O/S and I've been reading that that might be the problem; the 2840 scanner driver is not compatible with the Vista O/S and HP hasn't produced a solution yet. I appreciate your efforts, thanks.
Posted on Feb 10, 2008
  • 1894 Answers
SOURCE: Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Posted on Aug 05, 2008
    SOURCE: feeder tray does not feed during fax
    Hp help
    Automatic Document Feed (ADF) does not pick up paper. Follow each step, problem seems to be in pick assembly. Prcess took less than 5 minutes with a successful outcome.
    Posted on Apr 29, 2009
    Samsung CLX-3160N Document jam Scanner Error
    the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
    Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
    Documate error 8
    Hello.
    I am a Support Engineer with Xerox Scanners.
    E8 is a Paper Jam error that could be caused by:
    - paper crumpling during scan.
    - paper is multi-feeding all at once instead of feeding separate.
    - scanner continuously tries to feed after paper has fed through.
    if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
    if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
    if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
    We also have an extensive support site and knowledgebase at
    http://www.xeroxscanners.com/en/en/support/
    If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
    Regards,
    Xerox Scanners Support
    Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
    I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
    Follow these steps to scan using HP software:Step one: Load the item to be scanned
    1. Make sure that the product is connected to the computer.
    2. Turn on the product.
    3. Load the item in the document feeder tray or on the scanner glass
    Tip
    Load the following items in the document feeder tray :
    • Single items
    • Items that are not easily damaged
    • Multipage, single sided items that you want to scan into one file
    Load the following items on the scanner glass :
    • Single items
    • Items that are easily damaged, such as old documents and photos
    • Multipage, double sided items that you want to scan into one file
    • Option one: Document feeder tray
      1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
      2. Adjust the width guides to fit the item.
    • Option two: Scanner glass
      1. Open the scanner lid.
      2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
      3. Close the scanner lid.
    Step two: Scan the item Use one of the following methods to open the HP scan window:
    • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
    • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
    Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
    Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
    Save as JPEG Use this setting to scan pictures and images.
    Hope this information will be helpful.
    Let me know.
    Regard
    Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
    The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
    Instructions
    1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
    2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
    3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
    Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
    Hp 3015 auto feed
    You'll have to replace the feedroller kit. Partnumber CB414-67918. Gerrit Jan
    Nov 04, 2009 | HP LaserJet 3015 All-In-One Printer
    9080c fails to scan single page; has trouble scanning a batch.
    Hi
    what size page are you trying to scan, if they are smaller than the gap between the transport rollers, they will not feed.
    the single sheet problem you have:- the scanner knows when there is paper to feed when the sensor is pushed up beside the pick roller and it will put the tray down again when the rollers are pushed up. sometimes the little plastic sensor to the left of the roller gets a bit stuck and needs to be freed, it wares itself out where it hinges inside the cover around the pick roller. just unclipping it and cleaning it is usually enough.
    good luck.
    Oct 07, 2009 | Canon DR-9080C Path-Through Scanner
    Print OK - Scanner Problem
    I have the same machine and I can not fax or scan. Do I need special software?
    Jul 02, 2009 | HP LaserJet 3015 All-In-One Printer
    ADF paper jam, when there is none
    If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
    1. Close the scanning application (such as PaperPort)
    2. Turn off the scanner and the computer
    3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
    4. Plug the ADF cable back in
    5. Turn on the scanner power
    6. Turn on the computer
    7. Try scanning again
    For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
    If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
    To clear a paper jam:
    1. Open the Automatic Document Feeder cover.
    2. Remove the jammed paper and close the cover.
    If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
    2. Look for the small black plastic arm
    3. When you press on this arm, it should move freely up and down
    4. If the arm is stuck down, please contact Technical Support for troubleshooting options
    5. Close the ADF cover.
    May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
    Resetting PaperPort after paper jam
    I found the solution to this problem. Whenever the paper jammed in the feed tray, I was pulling the jammed paper out without opening the door of the feed tray. Apparently, PaperPort gets confused and does not know how to proceed. Now when I get a paper jam, I open the door of the feed tray, take out the paper, click on the paper jam error message in PaperPort, reset the paper in the feed tray, and then hit "scan." Works like a charm.
    Sep 30, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
    HP LaserJet 3015 All-In-One Printer Logo
    314 people viewed this question
    Seeker5211
    Seeker5211
