Question about Coleman Pack-Away
I have an older Coleman packaway kitchen and the plastic clips connecting the shelves and table are breaking. I need replacement clips.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
RF197ACRS Samsung fridge How to remove glass from the shelves to clean
Well, I don't know about the individual shelves, but for the long glass shelf above the crisper drawers, there are two white clips located at the back edges of the glass that need to be pried out with a knife blade, or something similar. Place your blade in between one of the grooves of where the clip meets the plastic frame (and, NOT between the clip and glass! ) and pry the clip with a bit of a sideways motion. It's a little stubborn, but if you break a clip, don't worry, you really don't need it for the shelf to function.
Anyway, after you pry up the two corner clips, lift and slide the glass toward the back to get it out of the front groove, and voila!, the glass comes right out.
Aug 14, 2015 | Samsung / RF197ACRS
I have a coleman 5317 RC series lantern that wont go into the dim mode what can I do
Hello. I've just looked at several Coleman lamps, some have krypton bulbs (mainly battery powered), some spiral fluorescent bulbs (mainly mains powered/charged). If this one is yours then it appears yours has a spiral fluorescent bulb. Gas discharge bulbs commonly are fired up by an initial high voltage pulse then followed by a continuous ac medium voltage (say 80 volts or so) to give a FIXED LIGHT OUTPUT.
THIS DOES NOT ALLOW CONTROLLED DIMMING. Dimming can usually only be done on an INCANDESCENT TYPE bulb eg an older type tungsten filament bulb. These are however much less efficient.
So in summary, if you do have a fluorescent bulb, I don't know why your remote indicates you can dim it. You could try switching the bulb for an incandescent type, but this should only be attempted by qualified persons. Check over the user manual again. Good Luck.
Jun 17, 2014 | Coleman 5317-700 lantern - 8d square...
Lower spray arm partially blocked with vegetable (lettuce Leaf ) matter. How do I release this arm for cleaning?
If it's a Bosch as listed above, the lower spray arm simply pulls off. Grip the spray arm near the centre, give it a sharp tug. To refit, insert the shaft into the hole, push down on the centre and make sure it clicks home.
To clean inside the spray arm, you can also separate the arm from the shaft to give better access. There are 4 plastic clips, holding the arm to the shaft (I've ringed one in the image below). Insert a blunt table knife or flat bladed screwdriver behind each clip and gently lever it off. It's easiest to get one side partly off first , then do the other side. Be careful with these - on older washers the plastic can be quite brittle and the clips break more easily.
Hope this helps. If you need further assistance - or you don't have a Bosch dishwasher - please let me know.
Apr 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Replace tailgate handle 2002 avalanche
If it's similar to a Silverado, the tailgate handle consists of a bezel (plastic cover) and a Red and Green plastic clip that break very easily. Take the bezel off (just pull carefully from the tailgate, careful not to break the plastic clips) look for 2 rods, again 1 connects to a red clip, the other to a Green, replace the broken one, or a cheap/temporary fix is to use a plastic zip tie at the connection. Snap the bezel back in.
Jan 23, 2011 | 2005 Chevrolet Avalanche
2007 silverado tailgate stuck closed r bar no longer connected to
EACH rod has a plastic clip that holds rod to tailgate handle you probably just need to replace the clip. it is a plastic clip that locks on rod insert new one in handle then install rod and snap clip down. to gain access you will have to remove tailgate bezel and these usually break when removing.
Feb 17, 2010 | 2006 Chevrolet Silverado
Plastic splash pan under frontend in cracked how do i order a replacement?
You can order one from your dealership, or even better, try to shop online by trying several jeep dealerships. I've found that these days they are real happy to sell their parts to older models that have been sitting on the shelves too long and even with shipping, you can save some $$$.
A general search for jeep parts OEM will get you plenty of resources.
These also can be repaired using good plastic cement if taken off & held in place until they dry, then reinstall. I use similar flat plastic from other projects to add extra support to the cracked areas from the back side when the breaks are not too bad. good luck
Jan 31, 2010 | 2000 Jeep Grand Cherokee
The plastic drawers and shelves on my frigdaire break very easy
lube plastic with silcone spray after cleaning . the clips can be orderedfrom whirlpool or any parts dist. hope this helped mm
Dec 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Changing bathroom window
use a reciprocating saw to cut around the outside edge of the frame to cut the screws that are holding it in. this way the whole unit can be removed without breaking the glass. if you dont have one and have no option but to break the glass try covering the glass with a sticky backed plastic like you use to cover old kitchen shelves. this will hold the glass as you break it stopping pieces flying all over.
Apr 27, 2009 | Saws
I have an older (20 yrs) coleman cook top camping stove that does not work. It runs on coleman fuel. What are somethings i can try to fix it
Here is Coleman's web support. I also need some work on my stove.
Jul 07, 2008 | Kitchen Ranges
Coleman Pack-Away  Logo
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
