Question about Microsoft Zune JS8-00001 Digital Media Player
It won't charge
When i plug my zune in my computer nuthing pops up on my zune or my computer
  • 38 Answers
Not charging
check the cable and make sure the cables not bad if it is then repalce it
Sep 23, 2009 | Microsoft Zune JS8-00001 Digital Media...
Zune 120 is charging do i nees to download
I'm assuming the Zune is new(at least to you).
You can download the software at www.zune.net Most likely it will update your Zune the first time you run it. Just follow the directions, it's pretty simple. Any music or video content on your computer will by default upload to the Zune as well. You can rip CDs and load them on the Zune by just popping them in your drive and letting it go by default.
Jul 18, 2009 | Microsoft Zune120 Digital Media Player
Nothing wont come up on my computer
Did you download the Zune software?
The Zune website has the Zune software which must be downloaded for your computer to communicate with your Zune.
And when you connect your Zune to your computer it should begin charging (as I'm assuming this is a new device).
If you have already installed the software I would assume the low battery was slowing the communication between your Zune and your computer.
If you Zune is fully charged and the software is fully installed try plugging the USB cable into a different port. Sometimes the Zune and the connector USB isn't automatically sensed on certain ports and certain moments.
Jun 26, 2009 | Microsoft Zune JS8-00001 Digital Media...
Usb device not recognized when i plug in my zune
maybe the USB is rusty or dirty...it also happens to me
May 05, 2009 | Microsoft Zune JS8-00001 Digital Media...
My 30 gb zune is frozen
There's a fix:
Your zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connecter. Your zune should start up immediately. Press the backing of the zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
It's an easy process but if you're unsure don't attempt it.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune froze when I turned it on. It is frozen on the Zune welcome screen with the loading bar at the bottom. I have tried the back and up button and it has not worked. I have also tried the back, up and...
There's a fix:
Your Zune will need a "hard reset."
To do this, use a small screwdriver to pop off the plastic shielding where the Zune cable plugs into and remove the two screws on either side of the plug. Next pop the cover off and locate the battery plug at the top left corner of the Zune, using your screw driver, pop the cable connection half way off, and do this to the other plug on the right side. Wait 3 seconds, then push down the right connector and then the left battery connector. Your Zune should start up immediately. Press the backing of the Zune down (make sure headphone jack is aligned) and put the screws and cover back in place.
Zune froze on boot up this morning. Reset buttons won't work nor will any others. Tried charging battery to no avail.
There's a fix:
Zune wont show connection
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jul 06, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune symbol flashes while trying to charge
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If this fails, then there is a hardware issue that cannot be resolved without replacement.
May 20, 2008 | Microsoft Zune JS8-00001 Digital Media...
My Zune says it is not connected but it still charges it when it is plugged into the computer?
Just Restore it or whatever its called. click the arrow button and click up on the pad.
May 08, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
29 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Richard Roth
Richard Roth
Mark Chaney
Mark Chaney
Mister Danger
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
