Question about Cuisinart DGB-600 Coffee Maker
THE SELF CLEAN LIGHT COMES ON AFTER BREWING, EVEN THOUGH I have clean it several times
  • Anonymous May 22, 2009
    self clean light won't turn off. buttons are non-responsive.
  • 8,596 Answers
Unplug the unit for one full hour, and when you plug it back in, the self-clean light should have disappapeared.
Posted on Mar 11, 2009
Electrolux icon duel fuel range racks red light wont stop flashing even though I removed all racks, so oven will not start self clean cycle
Good Morning Andrea,
I see that you are having trouble with your Electrolux range, model# E30DF74GPS, and getting it to go into the self-clean cycle. I would suggest giving it a hard reset. First make sure the racks are in. Next, cut the power at the circuit breaker and leave it off for 2-3 minutes. After the time has elapsed cut the power back on. Start the self-clean cycle with the racks inside the oven. We're trying to get the oven to recognize the racks are inside. Once it states the racks are in, cancel out and take the racks out. Now, with the racks out start the self-clean cycle again. If you are still receiving the red light blinking, I suggest contacting the manufacturer or your local authorized technician. Hope this has been helpful.
-Best Regards-
WP
Mar 23, 2014 | Electrolux Icon E30df74gps 30" Pro-style...
Allegro DVD/VCR combo - not reading disk & eating tapes.
Sorry I know very little about the dvd side but my experience with several VCRs is they need cleaning sometimes just like audio tape recorders and players need cleaning. Early in my days of VCR ownership the engineer I used was sick of seeing me and taught me how to clean the heads, guides and rollers myself to restore performance and help prevent tapes being chewed. Head cleaning tapes simply did not reach the parts needing cleaning though the the wet type sometimes helped.
A VCR might work normally for several months and then suddenly it would happen again. Sometimes I needed to do a clean several times in a month. I did have a Sharp VCR once and that had something called an idler reel that would "suddenly" need replacing (several times) due to chewed tapes but other than that manual cleaning did the job every time.
Later VCRs were fitted with a self cleaner that worked well and meant there was no trouble for a long time but when the self cleaner became loaded with filth they actually made matters worse.
Matter of interest, I use clean newspaper and methylated spirit for cleaning.
Oct 23, 2017 | Allegro DVD/VCR ABV511
Dcc-1200 coffeemaker self clean light blinks
There is no self clean button on mine, and I have done the above with vinegar and water......what next?
Nov 11, 2011 | Cuisinart DCC-1200 Coffee Maker
It's telling me to self clean?? Can't find manual
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
Sep 20, 2009 | Cuisinart DCC-1200 Coffee Maker
Clean light stays on,help me trouble shoot
If your Cuisinart is one that is missing the Self-Clean function, just brew the vinegar and water like it is coffee by using the brew function.
Sep 19, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
Jul 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
How to clean the coffee maker & set warmer
In order:
1 and 2) Clean the coffeemaker by puring in 1/3 caraffe vinegar, and 2/3 caraffe water. Either use the self-clean light or brew it as if it were regular coffee - just press the on button and then press the self-clean button, and it will begin.
3)
The Automatic Shutoff Time can be programmed
anywhere from immediate shutoff
after completion of the brew cycle up to four
hours. When the coffeemaker shuts itself off,
two tones will sound. Four hours is the default
time. The 0:00 setting shuts the unit off immediately
after brewing is complete. To check the
current setting, press the “On/Off” button and
the Automatic Shutoff Time will be displayed.
To change the preset time, press and hold the
“On/Off” button until the red “power” light
begins to flash. This signals that you have
entered the “Set Automatic Shutoff” mode.
Press the “Hours” and “Minutes” buttons
to scroll forward through the digits until
desired time appears. The first setting which
appears is preset at “4:00” and the next
display will be “0:00”, since four hours is the
maximum Automatic Shutoff setting. Pressing
and holding either button will allow you to
scroll continuously, slowly at first, and then to
accelerate to the rate of about three digits per
second. As the desired time setting approaches,
release the button and then press repeatedly
to advance one digit at a time.
The Automatic Shutoff Time (ASO) may be
programmed either before or during coffee
brewing. You may also re-program the ASO
time when brewing has been completed. If you
do so, the Automatic Grind & Brew™ will automatically
account for any time that has already
elapsed after brewing. For example, if you set
the ASO for 40 minutes and 25 minutes have
already elapsed, the Grind & Brew™ will shut
off automatically after 15 minutes (40 minutes
minus the 25 elapsed equals 15 minutes).
-Tha Mp3 Doctor
Mar 27, 2009 | Cuisinart Coffee Makers & Espresso...
Will not self clean
soundsas if theres an issue witht the latch assy not recoginzing teh door is closed, and for safety reasons with out door closing will not engage cleaning cycle
Feb 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self Clean Button
Unplug the coffeemaker for 1 hour or longer - it should reset the coffee maker and get rid of that self-clean light.
-Tha Mp3 doctor
Jan 24, 2009 | Cuisinart Coffeemakers
Cuisinart DGB-600 Coffee Maker Logo
124 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
