Question about HP PAVILION A847C Intel Pentium 540 HT 3.20GHz, 512MB DDRAM, 250GB Hard Drive, LightScribe DL DVD RW... (PP169AA) PC Desktop
Won't power up
Green light on psu blinks, no led on mother board. Swapped with "questionable" psu that when plugged to mb has steady green on psu and board and it blinks as well
  • 63 Answers
Hi
seems like your ram is bad and also change your vga [graphics card]
kind Regards
RAHUL_hunk
Posted on Mar 10, 2009
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
When I put the plug into the PSU for my sony tower pc the green indicator light just keeps flashing. Now when I unplug the 24 pin connector from the mother board the light on the PSU is steady green. What...
the PSU has Problem . It is not supplying enough voltage to boot the PC, capacitors inside the PSU are weak or damaged. Its dangerus to open the PSU coz, Capacitors have high voltage currents. If you have the Knowledge of electronics, then open the PSU and detect the Weak or Leeky Capacitors and replace them with new one( this method is for experiment and thrill) . But the replacement new PSU is better , perfect and cheaper then repairing the psu from outside. best of luck
Feb 03, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
The machine won't power up. The green light on the PS flashes. What does this mean? If I disconnect the large plug from the mother board the green light will come on steady. Plugging it into the mother...
Can you tell if the flashing is a pattern. count the flashes ( long and short) in a cycle. This will provide an error code to hopefully discover the problem.
You may also try removing and reseating the RAM and Video card, blowing out the connectors with compressed air before reseating.. Also look closely at the components on MB for any signs of swelling, leaking, burning etc. I suspect the MB.
Nov 11, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Need front panel pin connection for HD led ,power led and switches for AMD Duron mother board
Hello there
here is a pdf downloadable flile that will help you.
best regards michael
  1. [PDF] A7V133-VM 3051k - Adobe PDF - View as html Supports Socket A-based AMD. Athlon™/Duron™ processors. North Bridge ... p.37 System Power LED Lead (3 pin) 22) RESET (PANEL) p.37 Reset Switch Lead (2 pin) ...dlsvr03.asus.com/pub/ASUS/mb/socka/km133a/a7v133-vm/e698_A7V133-VM.pdf
Sep 13, 2009 | AMD DURON,1.2GHZ,1200MHZ, FSB200Mhz ( OEM...
Green light blinking
posible the PSU has failed or have a short somewhere inside case/MB/hardware
Jul 01, 2009 | HP Pavilion a620n (PC028A) PC Desktop
I have a emachine PC. PowerSupply blew up. changed it still down
try to remove the memory and put it back again make sure put it fit and correctly
May 28, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
ATX Bestec 1956F Power Supply Failure
sounds like your power supplie has not been switched on by *********** board.the fan will not turn on until power supplie is turned on by mb.as far as what is wrong there are several things i can think of.i would try resetting bios. It sounds like your power supplie is working and your motherboard could have a short.but i have no way to be sure without testing. I can however tell you how to perform a test on your power supplie.unplug the 20 or 24 pin connector from your mb. look for a green wire,and then locate the grey one.short these two together(you can use a paper clip or something).if it dosnt power up. your power supplie is bad.also do not short any other wires,and only touch the grey and green for a few seconds as this is not how it was intended to be powered on.
Mar 03, 2009 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
PC will not power up
Check that the ram memory hasn't come unseated from the mobo. If you are using an above board video card also check that it is properly seated as well.
The clicking noise from the PSU is kinda perplexing though...
Mar 01, 2009 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Swapped mother board
Hi Paul,
see page 8 number 15 for location. Than see page 19, System Panel Header in your manual.
The basic wire color's for positive are red, blue, green & can also be light blue, light green, light red.
Negative wires are usually white or black. Case wire colors do vary from case to case.
To see pin one shown on page 19, (positive + for hard drive led = HDLED+). Bottom row farthest pin to the left of set. Pin two is above pin one. Pin two is, PLED+ (known as power led). Pin 3 is to the right of pin one & is HDLED- (Hard drive led, negative). Pin 4 is above pin 3 & is also PLED-, (Negative for power led). ECT!
6781222.jpg If your new case has an internal speaker (Used for P.O.S.T, power on self test). This would connect to, Chassis Speaker Header located on page 8, number 16. Again, normally only two wires are used across the 4-pin connector. (One at each end of the connector).
To see ASRock's main site for the 775VM800 motherboard click this link:
http://www.asrock.com/mb/overview.asp?Model=775VM800&s=
Good luck Paul!
Run into a snag, just post the issue here.
Mike
Nov 02, 2008 | Asrock 775VM800 Motherboard
Psu blinking green light, no power
I read all the solutions, followed the manufacturers instructions exactly, replaced the cmos battery and nothing solved the problem (blinking light on PSU after a power failure and no startup at all). I had ascertained that the PSU was intact by disconnecting all the PSU connections to drives and motherboard at which time the PSU LED stopped blinking and was constantly on.
Just before throwing my computer away I decided to follow the instructions listed by "guest" to unplug the power to the motherboard and then with the power supply back on to plug the cables back into the motherboard. No only did sparks not fly, but it started up and ran perfectly! Many thanks to "guest."
Oct 31, 2007 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Computers & Internet Logo
137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
