Question about Acer (54.AA806.001) Sound Card
Left speaker has no sound
Can't get any sound from left speaker. I purchased new speakers but get the same result. I have tried many different drivers and have checked the balance in left and right speakers, still no luck.
  • 272 Answers
May be the port you connect your speaker have problem. actually there are two outputs there..a total of 3 lines. the line for the left one is not working...i think.
Posted on Apr 04, 2009
No sound out left side speaker
do the speakers work fine on a different computer? if yes i would say try reinstalling the drivers for your sound card... if this doesnt fix it then the card could be bad. but before that.. you cant try plugging other speakers that work into that computer to see if the card is actually the problem.
Jun 03, 2013 | Dell Inspiron Computers & Internet
Crosley CR6001A: Left speaker barely audible
Hi Eric,
I understand how frustrating this problem can be. The problem can be the result of several different things. Two of them are 1) blown speaker and, 2) blown left amplifier output.
Try listening with stereo headphones. If you can hear both channels clearly, the amplifier is most likely functioning correctly. This is desirable as amp repairs would probably be more costly than a driver (speaker) replacement. Make sure you vary the balance controls while checking for output on both L and R speakers. If the sound is intermittent, the volume or balance control may have dirt built up and may return to working properly by liberally spraying electrical contact cleaner around the stem (knob removed) with the unit unplugged. Use the extension tube to pinpoint the output along the stem. Be careful to keep from over-spraying as it may damage plastic and wood cabinetry. After spraying, rotate the knob fully back and forth several times and then plug back in and try for sound again.
If you can't restore the volume to the left speaker, you may have a blown speaker. This usually happens as a result of excessive volume which leads to distorted sound. If played this way long enough, damage to the speaker is unavoidable.
The speaker can not be fixed - but may be replaced. Replacing the speaker is something most people with conventional hand tools can do - with the unit unplugged. Finding the information on the speaker may prove to require some digging however. You'll need to know the size, wattage rating, impedance value in ohms, and frequency response. It would be best to obtain the exact replacement part if possible.
Other than this, you'll probably need to have it serviced professionally. Good luck!
Dec 06, 2012 | Crosley Cr6001a Turntable
I purchased a new desktop PC with Windows 7, & I'm trying to find out what the correct connection is for the Logitech X-530 Speakers is. That is, can I get all the 5 speakers to work at the same time?
It depends on the sound-card in the PC.
The "back-left" and "back-right" speakers require special connections to the sound-card.
The "left" and "right" and "centre" speakers are connected to the "main-stereo-audio-out" on the sound-card, as per normal.
Apr 03, 2010 | Logitech X-530 Computer Speakers
Left speaker gives no sound
There could already be a problem with the speaker jack, if only one channel is consistently giving no sound on your system.
Try turning the male (connected to speaker wire) jack and you might hear a static crackle while doing this. If you get both channels to produce sound this way, you already have a failing audio jack, and may need replacement later on.
Hope this helps.
Jun 07, 2009 | MSI PM8M2-V Motherboard
Very low sound out of left front speaker, other speakers work fine
Have you tried another speaker? If your left front speaker is in the door as in most cars, it gets banged around a lot. The driver's door gets the most use. This sometimes results in mechanical problems with the speaker, and can cause low sound or distortion. Take the speaker cover off (it may be necessary to remove the door panel in a factory installation), disconnect the speaker and hook another in its place. If the volume is back to normal you know it's the speaker. If not, check the radio and speaker wiring. If the radio itself is at fault because the amplifier is bad, it can be repaired at a service shop. The repair charges might be close to replacement cost these days, so you might consider a new radio if the estimate is high.
Apr 27, 2009 | Sony XR-M510 Cassette Player
Both rear speakers on my z540 system play only the left side rear
Hmmm, this sounds like either a driver issue, or a card/compatibility issue. you might try reverting to old drivers(last resort), making shure you have 4.1 enabled in sound control pannel(do this first), triple checking connections/connectors on both the speakers and the card(remember, you only have 5 speakers, not 8) and if you have the headphone-type phone plug for your speakers, you might try making shure that they are compatible with the jacks on your card, although, I would have to know more about your setup to be completely shure.
Dec 26, 2007 | Logitech Z-540 Speaker
Front right and left speakers problems
This is going to have to be a solution in the don't rate until we have some kind of end-result.
Connect the speakers to a different device such as an MP3 player or a Nintendo DS. See if the speakers still cease to work. If they work just fine with a different device, then consider that it may not be the speakers...but a problem with the sound system in your PC.
Perhaps the sound configuration in Windows is disrupted. Perhaps the driver settings for your soundcard in your PC are corrupted. (A complete reinstallation of Windows with a fresh installation of the sound drivers would probably prove this theory right or wrong.)
Perhaps there is a problem with the FRONT CHANNEL hole on the sound system on the rear of your PC. You could check that by plugging the REAR channel of the speakers into the FRONT channel on the PC.
And lastly...there could be a break or a short in the cable of the speakers. You could always test another set of speakers with each sound channel and see if that might be the possible issue.
If the sound card in the PC turns out to be the problem, then install a different sound card. If the soundcard in your PC is currently the onboard one, then disable it in the BIOS before installing the new card.
Let us hear the results before we do any rating. Unless of course you're able to fix it with the data given. :)
Dec 08, 2007 | Dell 5650 Computer Speakers
No sound from left rear speaker
speaker connectivity problems
get for repair
or trying installing audio driver again
Dec 03, 2007 | Logitech Z-5500 Computer Speakers
Computers & Internet Logo
286 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
