Question about Compaq Presario Notebook
Regularly adjust screen brightness & now function F5 not working
Now my function key is not activating any of my "blue" keys. I accidentally hit shift 5 times, but I believe I did not activate sticky keys, but don't know what I did to deactivate my function key. Also, is there another way to access& adjust that "brightness bar" on the screen besides the function F5?
  • RescueTechLA
    RescueTechLA May 11, 2010
    What's the exact model of your laptop?
    Problem Solver:
  • 18 Answers
Try right clicking the desktop and click properties find out what video card you then visit their website for answers
Posted on Mar 15, 2009
Locked out of laptop Toshiba C55-A5220 screen on there is a power sign and a narrator sign
Look like the sticky keys are active. Tap Shift Key for 5 time it should opo up a message to activate or deactivate the sticky keys.
Oct 02, 2013 | Toshiba Computers & Internet
Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
You might have "sticky keys" so try this:
When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
    • Press the "Shift" button five times in a row to turn off sticky keys.
    • Open the "Start" menu and then click "Control Panel."
    • Click "Ease of Access Center" from within the Control Panel window.
    • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
    • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
    • Click "Apply" to save your changes and then click "OK" to close the window.
Hope this helps. Good Luck!
Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
Keyboard numbers are jumbled
Im not sure what happened but a sticky key caption appeared on my screen and i just deleted but since then when i hit shift key to get symbols and the AT sign it wont work and its frustrating when trying...
You've turned on Windows' "sticky keys", one of the accessibility options. Pressing the Shift key 5 times in a row activates it. Sticky keys lets you type key combinations (Shift-x, Ctrl-Shift-x, Alt-x, etc.) one key at a time. It's for people who have trouble holding several keys down at once. Press the Shift key again 5 times to bring the sticky keys dialog box back and turn off the function. You can also disable it permanently in the Control Panel's accessibility settings program.
Jan 25, 2011 | Computers & Internet
The Shift Lock is stuck in the CAPS position. When I turn it off it goes off CAPS but as soon as I hit the shift lock for caps which I need to do, I can't get it back to where I can type numbers, which I...
Sounds like the shift key isn't entering. Try both shift keys and see if one will turn the light off. If so tou need a keyboard rebuild. It may be cheaper to replace it.
DickyO
Aug 16, 2010 | Brother EM-530 Typewriter
I accidentally hit the shift button 5 times and
Hit the shift key again another 5 times to disable sticky keys.
Regards.
Jun 29, 2010 | Computers & Internet
Cant figure out how to get it off the little blue symbols
Either the "blue" coloured 'FN' is _stuck_ in the "down" position, or you have accidentally activated the "Sticky Keys" Windows "accessibility" tool.
With "Sticky Keys", you press keys just _one_ at a time, e.g., CTRL then ALT then DELETE instead of pressing multiple keys (SHIFT and '8') at the same time.
Restart, in order to turn-off "Sticky Keys".
Or, "exercise" the 'FN' key, until it "unsticks" itself.
May 07, 2010 | HP Pavilion dv4000/dv4200 Series Keyboard
Can't switch key function (Don't know how)
Sir you have activated FN keys which caused others functions to get activated on #2 key. So just de-activate FN byt pressing its key.
Dec 04, 2008 | Acer Aspire 5315 Notebook
Compaq Presario Notebook Logo
224 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
