Question about Sharp Televison & Video
Sharp LC-52SB55U doesn't work with any remote
I bought a Sharp LC-52SB55U from BestBuy a little over 30 days ago and it worked fine up until two days ago. My programmable remote stopped working. I tried the remote that came with it and my comcast remote but that did doesn't work either. The buttons on the side of the TV work but nothing with a remote. I tried the recommended reset of the factory remote which didn't work either. Anyone have any ideas?
  • art1733 Mar 10, 2009
    I unplugged the tv for an hour then plugged it back in and it works now.
    I unplugged the tv for an hour then plugged it back in and now it works.
jsinex2421
  • 62 Answers
SOURCE: may sharp lc-52sb55u
Well, there is a way to have the clearest possable picture. Get HD cable TV box that is HDMI compatable and watch only HD channels. Or buy a blu-ray player, hook it up via HDMI and only watch blu-ray disc in 1080p!
Posted on Jan 10, 2009
  • 814 Answers
SOURCE: no picture controls
Check your owners manual look for the section that tells you how to adjust the televisions features using the on screen menu.You probably Have it set on auto adjust. You must turn this feature off, to use the manual controls. If this does not help go to the Sharp website and search the frequently asked questions and troubleshooting sections. Search for your problem and similar one that may have answers. If all this fails you, call technical service and ask them for help with your problem.Hope this helps you with your problem.
Posted on May 12, 2009
SOURCE: Remote stopped working
frpm baldmeaney i unpluged my tv same model for 5 min and all was well again . this may work for you . good luck!
Posted on Nov 18, 2009
SOURCE: Flickering screen (LC-52SB55u) with HDMI
Do a quick google for this on the AVForums site where you'll find numerous threads covering this problem. First, select the HDMI input before turning on the blu ray player. The handshake over HDMI is the problem. I have the same problem with a Technika blu ray which is fine on my other TVs.
If this doesn't solve it then you ned a firmware update which can be downloaded from Sharp's website and installed using a USB pendrive or by PCMCIA card from Sharp if you have an older model with a rocker on off switch and no USB update port on the back of the TV.
Posted on Jan 09, 2011
alexander404
  • 276 Answers
SOURCE: How do I hook the
Your HDTV would have to have internet connectivity, either an RJ-45 ethernet jack on the rear panel or wi-fi capability. Sharp calls it the AQUOS NET feature on the TV and is usually an ethernet port. If your TV does not have this capability, you can use a laptop and hook this up to your HDTV. You still need high-speed internet service and a Netflix account.
Posted on Mar 13, 2011
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
Jul 13, 2011 | Sharp LC-26GA5U 26 in. HD-Ready LCD...
My sharp aquos tv suddenly won't change channels. It was working fine a few days ago. We've had it for five years now. Model lc-37d4u The remote allows us to adjust vol and mute but no other functions...
U can tries take out the batteries,pushes all the buttons a couples times,wait awhile put batteries back,see if that solved ur problems.Not the remote is garbage now.Remote control have dead CPU chip or it CPU is short will have some functions lelf,remotes devices are heavily depend on it CPU chip.This can't be repair,because it just a circuit board and a CPU chip about it on the remote control,that it.Try website like Remotes.com to buy an original remote or very close to it.
Jan 22, 2011 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Iam on remote lockout,how do i get back in ? also how do i turn off the close caption? the tv is a sharp lc-32sb24u
Unplug your TV for 30 seconds then plug it back in , remote should work after that. Press CC button on your remote until you'll see CC OFF.
Nov 16, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Cannot get vga out put from a toshiba satellite to work with #4 input on the sharp lc-52sb55u
I realized I had not addressed my display settings to allow out put to
an alternate screen
Oct 09, 2009 | Sharp LC52SB55U LCD TV
I have a Sharp LC-52SB55u. IF THE TV SIGNAL IS
do you have left and right audio plugs connected?,if no,t you will hear stereo(as it will play threw one lead,but if in mono,you wont hear anything unless you plug the other lead in instead...
Aug 31, 2009 | Televison & Video
Is it worth fixing a seperation in the two front screans of a sharp LC-52SB55U and how much would it cost
To be really Honest, it better to invest in new rather than looking for replacement screen. Sometimes, replacing a screen may cost anywhere between $200 - $350.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 03, 2009 | Sharp Televison & Video
Television displays in blue , only checked all
For your remote problem, mine has stopped working a couple of times and here is what Sharp had me do: Take the batteries out of the compartment. Next press and hold down the power button on the remote for a count of 30 seconds. Return batteries and the RC should be reset. As for the other problem, I had a similar thing happen tonight, hence I am on this site looking for help. My remote quite working, so I did the above, to no avail. I noticed the channel number box was frozen on the screen. I could not turn the TV off manually and had to unplug from AC. I plugged it back in and got sound but no picture, just that bluish dark screen. TV would not turn off. Then I got nothing, no sound, no pic. I left the TV unplugged for several minutes, 5 or so, plugged it in and it did work and is working now, RC too. You might try unplugging it for an extended time.
Jun 11, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No picture controls
May 12, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Dec 31, 2008 | Sharp LC52SB55U LCD TV
Televison & Video Logo
295 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
