Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
We have 2 openers and both have lost their signal range to where the doors wont even open at times.
  • 1 more comment
  • shanedunlap8 Mar 10, 2009
    No I haven't yet but one of the remotes is built into our escalade so it is powered from the vehicle and it is happening on two seperate openers. It did the same thing last year I believe there is some sort of interference problem I just don't know where to start looking. Nothing has changed in my home
  • pandaman113 May 11, 2010
    hos old are they and when was the last time you replaced the 12volt battery inside your remotes. both of them tell me it's the remotes need new batteries good luck
  • kev442 May 11, 2010
    Did you change the batteries?
  • 25 Answers
Replace the batterys 12volts
Posted on Jun 20, 2009
I have a Clicker universal Garage door opener remote control Model KLIK1U. How can I increase the range to open the door? Currently, I have to be within 10-15 feet of the door opener to operate. I have...
Check the antenna on the motor. It is usually a single thin wire. There also could be something nearby that is causing interference to the unit and it wont pick up the signal till the transmitter is close enough to overpower the interference.
Oct 28, 2013 | Building Materials
Master Mechanic garage door opener has lost it's range. Only works when remote is very close to garage door. I have replaced the batteries in the remotes, reprogrammed the remotes and disconnected the...
Sorry to read about your problem, I hope this helps you out.
either 2 things, you have a defective receiver, or their is a outside interference jamming the signal. this is a common problem, in some areas.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kitchen Ranges
Hi, when i enter the code on my keypad, the door will not open. It will close, the remotes in the car work and I have changed the battery
Your keypad has lost signal strength. The door cuts the signal down even further and causes the problem. A new keypad will fix your problem.
Sep 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Kenmore self cleaning stove: cannot open door after cleaning cycl
F9 is your oven sensor im sure.Also try to unplug your range and plug back in.Some times that works.Hope i helped:)
Mar 13, 2010 | Kitchen Ranges
I have a mgr4452bdq and the oven doesnt stay lit long enough to reach temperature does the broil igniter send a signal to the valve to stay open? thanks Joe
NO THE HOTTER THE IGNITOR THE MORE CURRENT FLOWES THROUGH TO OPEN THE VALVE.SOMETIMES WHEN THE IGNITOR IS WEEK THE VALVE WONT STAY OPEN OR WONT OPEN AT ALL.IF THE IGNITOR SHUTS DOWN THERE IS A PROBLEM WITH THE CONTROL OR SENSOR. IF IT STAYS ON ALL THE TIME ITS PROBEBLY BAD.
Mar 06, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
When I enter my code on the keypad it will not open the door, however, if the door is open and I enter my code it will close it. also one of our remote openers has stopped working, batteries have been...
If your remaining remote(s) have normal range then it is your keypad that is going bad. When one of the units start loosing range it is common for the door to cut down even further on the signal strength.
Feb 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener remote range limitted
Yes the receiver can go bad over time and lose range. Most likely the receiver cost plus the labor will cost as much or more than a new unit...depending on who does the repair. FYI another cause of reduced remote range can be signal interference from other sources which would be a little harder to track down unfortunately. Wireless routers, new appliances anything with electronics are a possible source of trouble.If you or a neighbor bought any new gadgets there's a small possibility of thatbeing the issue. But based on the age of the unit that's my first guess.
Rustym62
Apr 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
My sears garage door opener wont open or close the door
If you can get access to the back of your motor assembly on the ceiling and look where the wires are connected there should be a slide button that will have a list that will have you set the main unit to a position that will allow you to accept new remotes or reprogram for lost signal to existing remote. If all else fails there should be a phone number you can call listed on the unit and they can walk you through.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kenmore gas range trouble
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 20, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Keeps opening
may have a microswitch that signals that the door is closed that may be faulty. look for a switch that is actuated when the door closes.
Nov 06, 2007 | Emerson EWR20V4 DVD Recorder/VCR
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
135 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
