Question about CMB T43 750 Notebook
I have a HP laptop, i bought it before 2 or 3 months, now when im turning it on, using it for 10 or 15 minutes maybe, it STOPS!!! everything get stuck and stoped, i cant even move the pointer, i cant do anything! everything just stop....so i have to hold the power button to restart it again, is it a virus???? or what??? plz help me, its a new laptop;(.....btw i dont have abattery, i open it with the laptop charger all the time,! so i dont know if this is the cause of the problem, plllllllllzzz help!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
- Try to run the System Restore.
Posted on Mar 10, 2009
Computer fan turns on every 2 minutes and runs for 30 sec.
Does your computer seem to be running hot? If not maybe that's all the fan needs to run to do its job. The only thing you could try is to replace the fan.
Jan 04, 2014 | HP Computers & Internet
The old battery will not hold a charge when not plugged in so i bought a new battery. the battery came today in the mail and says "plugged in, not charging" and the battery light on the front is...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Your response is very much appreciated...
Feb 15, 2011 | Computers & Internet
First ,touchpad freezes (including scroll). the mouse on screen moves every...20 minutes. clicking sets off a continuous beep. this stops after maybe 5 minutes. the light on the wireless button doesn't...
Syptoms u have identifies are most probably linked to registry errors on ur computer it is wise to run a registry repair scan with reginout registry cleaner....
Aug 30, 2010 | HP Compaq Presario CQ60Z Notebook
Turning off
Perform power drain ( remove all accesories including the battery and the power adapter) press the power button for 1 minute.
Connect the power adapter only then turn on the computer - try using for more than 1 hour. If the computer does not shut down then the issue is the battery.
Run anti virus software.
If problem still persist it is a posible hardware issue. If you are still in warranty you can call sony and they can help you fix the issue for free.
Mar 27, 2010 | Sony VAIO Notebook
My HP zt1170 Laptop's battery isn't charging; I bought it today (used) and he said that the battery did charge properly. I plug the AC Adaptor in, the batt. light turns amber for 1 minute then shuts off....
Sounds like the battery was on it's last legs to begin with. The charger appears to be working correctly. Try to reach some agreement with the seller over replacing the battery (not cheap!).
Dec 16, 2009 | HP Pavilion zt1170 Notebook
Laptop speaker won't stay on
Best Not to touch it IF its under warranty . if it were not under warranty u could maybe open it up and check the solder joint on the speaker to the motherboard.
Jul 10, 2009 | HP Computers & Internet
I am having a sound problem with my XP hp pavilion dv1000,
did you see a audio voulem control icon on the right side in the corner on your desktop?
and 1st.
try to use head phone , plug in your laptop, see everything works ok ?
A............ working good, that means the speaker of your laptop may have problem, hardware problem. (no one can do anything for you)
B............still no sound, maybe the software/driver problem, try to uninstall the old driver, and reinstall again.
Dec 30, 2008 | HP Pavilion dv1000 Notebook
Information
Go to Device Manager and uninstall the webcam drivers and restart the system...It will load the webcam drivers...Check the webcam if it works then the problem is resolved if not delete the webcam drivers and download and install it from the hp website..it will resolve the issue if this does not resolve the issue then contact HP for sending your system in for repairs
Aug 01, 2008 | HP Pavilion N5415 Notebook
Hp dv 6000 I cant turn on my laptop !????
you can turn on your laptop if you dant have an removal battrey n then plug the charge back in and it will work fine however not only that check if the battrey shows any sign of leakeage also once your computer is back on then turn it off again and put the battrey back in if u do not have a removal battrey then keep the laptop unpluged for 5 minutes and try to turn it back on at least 2 times if u have done it then u could try tihis plug the charge wait for ten minutes see if it give u any sign of charging then turn the laptop on .
please try this out and see if it works as im not an it guy but justed wanted to help u
thanks
this is my e mail id
alson_1925@hotmail.com
can u please let me know if that worked for u or not thanks .
Jun 23, 2008 | HP Pavilion dv6000z Notebook
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
Computers & Internet Logo
61 people viewed this question
Top CMB Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
vojvodabudva
Masood Rasool
Level 1 Expert
Are you a CMB Computer and Internet Expert? Answer questions, earn points and help others
