Question about Wurlitzer Jukebox CD Player
My cd rowe ami jukebox is stuck in scan/transfer mode
As soon as I turn on my jukebox, transfer starts and runs continuously going to every ninth cd. It picks up one, transfers it, puts back into magazine and goes to the next. I have tried to put it in service mode, but have no digital displays. Could it be the outer cam switch? Is there a reset button? Please tell me what my options are.
    Scholar:
  • 195 Answers
You say you do not have the digital display lite up, have you checked all of the breakers on the power supply?
If not do so. Rowe Ami jukeboxes are very prone to dry joints (cold joints in the USA) this is cracking around the soldered pin on the connections to the boards.
If you can solder correctly then check out the printed circuit board on the power supply. I would retest and see if the display now lights after correcting a fault on the power supply.
If that has not made any difference then proceed to the Mechanism Control Board and the Central Control Computer (CCC) and check again for dry joints.
If you can not solder with any confidence then send in your boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
Posted on Mar 11, 2009
I have a 89 Rowe cd jukebox it transfers the cd continuously. Any solutions to fixing this problem?
Posted on May 17, 2011
Selections already made on jukebox, how do I clear them
Hello stillwell42,
What model is your Rowe Ami jukebox, there will be an information label on the back or inside the jukebox with the serial number and the model type. We can suggest a solution once we know your model type.
Regards
Alan
Alan Hood
ami-man
UK
Mar 13, 2015 | Audio Players & Recorders
Code to initialize ami rowe jukebox
For full initialization, in service mode, press 3 to enter init. sub menu, type 0 for full initialization. Press popular, then put switch in normal position and initialization will begin. You can still select and play discs while initialization is in progress, providing you select from cd's already finished. The machine will continue initialization after selections are finished playing.
Feb 02, 2013 | Wurlitzer Jukebox CD Player
I have a Rowe Ami cd 100 that we just got.The cd,s skip-music starts and stops, and it seems like the machine is not reading them [sometimes it picks a cd and returns it to rack].Anyone have any...
Did you lock down the jukebox mechanism (caurosel) during transportation?
Make sure that all the plugs that go to the all the circuit boards are fully seated, Unplug each in turn and plug back in MAKE SURE YOU UNPLUG THE JUKBOX FIRST if this does not sort out your problem look at the microswitches on the transfer motor (this is the mptor that tranfers the CD onto the deck) the spades on the microswitches are uninsulated so they can short out if pressed together.
The other main problem with Rowe Ami is that the boards are prone to the connection pins having dry joints (cold joints in the USA) on the soldinging to these connection pins.
It may be as well having all the boards tested by a Rowe Ami specialist.
In the USA the best guy is Bruce Wentworth (search for his details on Ebay by putting in Bruce Wentworth jukebox) or you could contact me in the UK.
Regards
Alan Hood
ami-man
UK
Apr 29, 2010 | Wurlitzer Jukebox CD Player
Rowe Nostalgia jukebox will only play a few of the numbers of the 100 cd;s. Is there anyway to reset it so it will play all numbers?
You will need to go into the programming section on the menu.
I suggest that if you do not have a manual that you obtain one from Rowe Ami, Victory Glass or distribution.
Have you initalised all of the CD's on your jukebox? Every time you replace a CD you have to initalise it.
Regards
Alan Hood
ami-man
UK
Jan 31, 2010 | Wurlitzer Jukebox 1015 One More Time...
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Oct 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
Need to get wurlitzer jukebox working
Place a help request on the following jukebox forums, you will need the jukebox makers details (Rowe Ami, Wurlitzer, Rock Ola or Antique Apparatus etc) and the model number and what fault you have.
www.phonoland.com
www.jukeboxmadness.com
www.arcadecontrols.com (go to message board and then jukebox)
Regards
Alan Hood
ami-man
UK
Jun 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
Apr 27, 2009 | Wurlitzer Jukebox CD Player
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
909 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
