Question about Stanley Air Tools & Compressors
Carburetor kit I have a Tecumseh 5HP Engine Model HSSK50, Spec #67404S, Engine Family #YTPXS 1951BF. The carburetor has 4 digits (5145) and J1V stamped on the flange. I would like to know what repair kit number I need and what the letters and numbers mean on the flange. I appreciate your help.
  • 195 Answers
SOURCE: Ariens SnoThro w/5hp Tecumseh has no fire
Check the fuel. Pour some fuel into a clear jar and let it set. See if it seperates due to water in the fuel. Very common problem.
Rich
Posted on Jan 15, 2009
  • 376 Answers
SOURCE: replacement carburetor OHH55 tecumseh 5.5 hp rear
Need the 5 numbers and a letter following the model number to tell you that. :)
Posted on Jun 06, 2009
  • 148 Answers
SOURCE: need brand/model no for my troy bilt 475SS carburetor
Have you looked on the Carb itself? If you look closely you should see a name and some type of marking of the model number.
Also look up the model number of your blower at www.managemyhome.com and you should be able to the owners manual from there (which should have it).
Posted on Aug 04, 2009
  • 13 Answers
SOURCE: my tecumseh engine 5hp leaks gas threw the carburetor to the airf
stuck needle valve or bad float in carb.
Posted on Mar 27, 2010
2strokeguy
  • 183 Answers
SOURCE: need replacement spark plug for 4.5 hp Tecumseh;
In my shop, I use Autolite brand plugs. Your engine would have come originally with a #255 or equivilent. Most shops will upgrade that plug to a #458. It is slightly hotter and gives a more efficient burn. You can also use a Champion J19LM or an NGK B4LM.
Posted on Oct 15, 2010
How do correct RPM surge on a LH 195 Tecumseh engine
Hi you're governor gears inside the motor could b the problem ...good luck
Aug 11, 2015 | Tecumseh Garden
I need a free diagram of a tecumseh carburetor 5TPXS.3582AA Spec. 206915F
You can find a free diagram at www.sepw.com, use the part number of the carburetor as a model number under tecumseh brand lookup. Your carb part number is 640065a.
Jul 12, 2013 | Garden
Tecumseh engine snowblower, will only run if I keep pushing the primer bulb, Why?
Take off the screw that holds the carburetor bowl on and clean the holes with a needle and blow air through them. These holes feed gas from thr bowl into the carb and may be clogged.
Feb 23, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Tecumseh 5hp feul bowl leaking
Tecumseh rebuild kit number 63021B comes with a needle and seat, bowl gasket and bowl nut gasket. Should solve your problem.
Nov 08, 2012 | Tecumseh 5hp Engine Snow King Mtd Blowers...
I have a 5hp tecumseh motor HS50-67324K on a craftman snow blower,could you please tell me the high and low RPM speed settings on this unit.
Here is a 70 page Tecumseh service guide. Locate the type of carburetor you have in the guide. All instructions with diagrams are available. This is a PDF file. Adobe Reader will be needed to view it.
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh/Tecumseh_quick_reference.pdf
Dec 14, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Have a Troy-Bilt Chipper/Vac model # 47282 5hp sp, the Carburator needs to be replaced, I cannot find a part # for it, or where one can be purchased, please help
I believe the carburetor part number for your model is 632631. I have the same TroyBilt chipper/Vac. It has a Tecumseh H50-65582W engine. A good parts diagram can be found at
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-H50-65582W-PARTS-LIST.pdf
If this is the right part, you can buy it at Jacks Small Engine parts for $79
Good Luck!
Dec 12, 2010 | Troy-Bilt Chipper Shredder
Need replacement spark plug for 4.5 hp Tecumseh; model number YTPXS
Oct 08, 2010 | Tecumseh Heavy Machinery
Air Tools & Compressors Logo
220 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
