Question about HP Color LaserJet 4550n Printer
Oops....it will not turn off we have a network set up in our home and my husband can set the printer to kick off on the timer and it will then suddenly shortly it will kick back on on its own so basically it runs all the time. Did not start until we go a wireless router? Help
  • jebalch Mar 10, 2009
    That's the problem we really don't like the printer running all the time and it will kick off to standby then it shortly kicks back on by itself
    Changed the IP address on the printer and it still does not work
    still will not shut off
  • 22 Answers
Im not a wis but I can try to help. I don't know how you have it hooked up in your network but if its hooked to the router, the router could be send a check to the port and the print may be responding to it by turning on. I leave my printer on all the time, I just set it to go to standby mode a few minutes after the last print.
Hope this helps.
Richard
Posted on Mar 10, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 167 Answers
- You may need to range the IP Address of your Network Printer accordingly to the IP Address that is being broadcast by your router.
How do i make my x543 wireless
You can find a User Manual here: http://support.lexmark.com/index?page=product&locale=en&productCode=LEXMARK_X543&segment=SUPPORT&userlocale=EN#3 I could not find that it has Wireless capability. You can set it up as a Network Printer on a Home Network. Use this procedure: http://www.trainsignal.com/blog/how-to-setup-a-small-home-network-part-2 OR, http://www.ehow.com/how_8038760_setting-up-wired-printer-network.html Once you have it setup as a Wired Network Printer Share the printer that way you can connect Wirelessly to ALL computers on your Home Network. All computer must be in the Home Network and the Computer the Lexmark is connected to via a Hardware printer cable must be turned on to print Wirelessly. Setting up a Home Network procedure: http://compnetworking.about.com/od/homenetworking/ig/Home-Network-Diagrams/
Mar 07, 2013 | Computers & Internet
Forgotten how to turn it on. It seems to be set on timer. Oops
push stop button for a few seconds until it beeps or the readout changes. unplug,,,,,plug back in....push "Select" or "menu" button depending on which machine you have....push again and again until the program you want is on the display or readout. Then push the "start" button ....Don't push any timer buttons or arrows!
Dec 04, 2011 | Kitchen Appliances - Others
My Iphone 3G won't connect to home wifi after working well for months. In settings, it searches indef. for networks. 3G works fine. My husbands iphone works fine. Any suggestions?
you can try to set your wifi same as your husband's one, check the wep code and wifi shold be enabled.
try this and give feed back!
good luck
Jun 30, 2010 | Apple iPhone 3G
How do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
Dec 08, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Everytime Panda does an update on my laptop, I can no longer connect to our home network which is how I get online. We have a dlink router and never had any problems until we installed Panda on my husbands...
Meh, maybe Panda doesn't like connecting NATed through your husband's box or that's inconsistent with the settings you've told it about.  If you're both just peers on one side of the D-Link uplinked to your ISP though, it doesn't make much sense.
    Check Panda's logs on your system (or turn them on so you can perhaps see what its notion was in cutting off connectivity!)  Whitelist Home Network in Panda.  And of course use their support for their stuff too!
Nov 12, 2009 | Panda Internet Security 2009 - 3 User for...
Brand new Dell netbook won't connect to internet (at home). Connects fine at work. Wireless strength is good at home but no internet connection. Husband's notebook connects just fine so it appears to be an...
No, it's probably because you have setup a wireless home network with security in place.
Go through the settings on your husband's notebook settings for your home network and set your Dell up the same way. You will need to know the SSID for the wireless network, security type and key to set it up.
Oct 28, 2009 | Dell Computers & Internet
How do i do a wireless connection between computer and a kodac 5100 all in one printer
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/5100AiOPrinterUG_EN-US.pdf
follow this manual ...
  1. Check the Wi-Fi Status Indicator on the front of the printer:
  2. Status: Do the following: Off
    1. Select Menu (or Home)>Network Settings and press OK.
    2. Select Turn Wi-Fi Radio On and press OK.
    3. Select Wi-Fi Setup Wizard and press OK.
    4. Select the SSID (name) for your router.
    5. If you have your network secured, you must also enter your password.
    Blinking
    2. Select Wi-Fi Setup Wizard and press OK.
    3. Select the SSID (name) for your router.
    4. If you have your network secured, you must also enter your password.
    5. NOTE: If the message Your printer is already configured for Wi-Fi network appears, your printer cannot find your router.
    6. If this occurs, check that the router is turned on and located within 100 ft (approximately 30 m) of the printer.
    On The WiFi Status Indicator could be on, but you could be connected to the wrong router if you used the manufacturer's default SSID and password when you set up your router. If this is the case:
  3. Select Menu (or Home) from the printer control panel on the front of your printer.
  4. Select Network Settings and press OK.
  5. Select View Network Configuration and press OK.
Place the KODAK All-in-One Printer Software CD into the CD-ROM drive on your computer.
Follow the on-screen instructions. Do one of the following depending on the version of KODAK All-in-One Home Center Software:
  • When the KODAK Printer Setup Utility screen appears, select how you want your printer to be connected:
    • USB cable
    • Wireless Wi-Fi® connection
    • Ethernet cable
Oct 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Setting up printer on home network
Because your printer is not either wireless or network capable, the only way to get the results you need is to purchase a usb print server, hook it to your router, set it up through it's management console, and if your router is wireless, you can hook up to your router and print to your printer with your desktop turned on or off.
Apr 13, 2009 | Computers & Internet
Epson Stylus CX9400 driver settings
Not sure how you're removing the driver, but if you go to control panel device manager remove the printer totally as an option; reboot and then reload the printer. You also need to identify the remote printer in the print sequence or as your default printer in set-up (device manager). Hope this helps.
Jan 14, 2009 | Epson Stylus CX9400 Photo Printer
RTH6300B Honeywell Thermostat
my air conditioning does not turn on at the time i want it on. previous owners had set timers for it to turn on, how do i re-set the timer as we do not want the timer on. we want to be able to turn it on and off as we please.
May 29, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
HP Color LaserJet 4550n Printer Logo
32 people viewed this question
Ben Johnson
