Sharp 27L-S100 27" TV
Problem for Sharp 27L-S100 27" TV
Sharp 27L-S100 TV - no tuner video/sound - direct input OK
By Horner - usenet poster
SHarp 27L-S100 TV has raster and screen menu come up. No static on channels
but diect input does work. Most likely the ST5UF78S tuner ? Anyone have any
info. on this unit.
Thanks
EdDataFix
Scotch PLains, NJ
Best Solution
posted on Aug 02, 2007
Helpful)
Joey2
Rank: Apprentice
Rating: 0%, 0 votes
Probably due to a power surge/spike the EEPROM's data became corrupted
so enter service menu (Electronic Servicing & Tehnology Magazine
Issue:June 98,page 26) and change parameter in EEPROM from 30 (or what
ever it is) to about 26 then shut tv off,voila audio restored.
I resetted the original EEPROM back to factory default values while
still in chassis.
Entering Service mode in Sharp tv's:
press volume up and channel up buttons at once then plug the set into
the ac outlet.The tv comes on and enters the service mode.To exit this
mode,depress the power button.
Once in the service mode,press the channel up/down buttons on the
remote control or the set to select the register you wish to adjust
the data.
Resetting Sharp tv's EEPROM values to factory values:
While in service mode press the channel up & down buttons for more
than 2 seconds
For future reference:
IC3001=Sony # CXA2074Q=US MPLX decoder sound IC=Sharp # VHICXA2074Q-1S
(surface mounted 48 pin QPP)
IC2101=EEPROM=Sharp # VHI24C01B/-1
IC2101=EEPROM=Sharp # RH-IX2447CEN1
IC2101=EEPROM=Sharp # 409-321-0902
IC2101=EEPROM=Panasonic # 24C01AIP
Note:the above sub #'s have been taken from:
34 sites containing tv & vcr service mode access:
mapage.noos.fr/tophe/tvser.html?KeohiHDTV
Was this helpful?
Yes
No
Solution #2
Not Rated)
Reynolds
Rank: Apprentice
Rating: 0%, 0 votes
Can you inject IF at the tuner output?
Alsocheck for B+ to the tunerno print here to verify but there is a
Sams Efact available if someone has it to forward to you.
Jeff Stielau
Shoreline Electronics Repair
344 East Main Street
Clinton,CT 06413
860-399-1861
860-664-3535 (fax)
"If you push something hard enough it will fall over."
Fudd's First Law of Opposition - Sir Sidney Fudd
Was this helpful?
Yes
No
Popular Solutions for Sharp 27L-S100 27" TV
Questions and Unsolved Problems for Sharp 27L-S100 27" TV
Do you recommend Sharp 27L-S100 27" TV?
Answer
Answer
i lost my remote and need to adjust brightness manualy
Answer
sharp 27L-S100B. lost remote. how do you get into menu mode?
Answer
what are the remote codes for time warner cable to use a universal remote?
Answer
got a sharp 27 inch tv built in 96. cant turn off the sap. dont have the origional remote. would... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in , OH
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
