Question about Samsung HCN653W 65" Rear Projection Television
Old pink and purple bathroom needs help.
Old bathroom needs help no money to change fixtures. The tub, sink and toilet are dark purple. The floor is white and purple tiles. The counter tops are pink tile. What colors should we paint the walls to tone all this purple down.
  • woolfordclan Mar 23, 2009
    We just painted our bathroom with purple (lavender) toilet and sink a pale green (like a celery shade, not minty) and installed some crown moulding which was painted purple to "blend" in with the purple. It's a small bathroom and it needed some brightening up. It looks fabulous and we've received a lot of positive feedback. There are some paint company websites which you can take a picture of your bathroom, upload it and then experiment with the colors to see what looks best before deciding. We used Benjamin Moore's but I'm sure many paint companies have this.
  • 201 Answers
The consensus here is a medium to pale/light blue - black or dark blue would blend better, but it would be one darn dark bathroom. You want something that blends, not accentuates the purple.
Hope this helps :)
Posted on Mar 10, 2009
My pfister shower cold water faucet handle broke off. The stem is stuck so I can't replace the faucet handle. How do I remove this stuck portion of the old handle?
the model is needed for a step by step but. if your faucet is for a sink and not a shower then the handles may be connected to the pour spout or separate depending on model and in either case there is a nut screwed under the fixture that hold it in place. do not unscrew any of the faucet until you have turned of the water running to it.
here are links to the different types
Price Pfister Bathroom Sink Faucet Repair
Moen 4570 Handle Fell Off But Then Fixed It Here How
How to remove kitchen faucet
and just in case it is a bathroom fixture
Maintenance How to Remove Replace Cartridge on Single Handle Tub Shower
Sep 03, 2017 | Plumbing
I have a water leak in bathroom not from toilet. How can I check the pluming in that area?
Your idea may correct. But majority of cases it is floor/ground seepage....leaks through your tiles or waterproofing layers and so on..To chk...keep on pouring water to the ground of the bathroom, near wetting areas, and close the freshwater line leading to the bathroom taps
May 18, 2016 | 2006 Tahoe Transport
I have a toto toilet , model MS604114CEFG , bought 2 years ago . Last night , when I flushed it , the water level in the toilet bowl did not come down . It stay high in the bowl . In the tank reservoi
If the toilet is the only fixture in the bathroom group that is having an issue, then there is a partial blockage in Strap of toilet or in drain pipe close to toilet. If other fixtures are showing sluggish drainage, then the main drainage line is clogged. If all is fine with tub lav shower etc., pull toilet from floor and carefully turn upside down, and look to see if anything is visable. if so remove it and reinstall with new seal(wax ring). Also, look into pipe and see if any water is standing in it. If water is standing in pipe, the drain line is clogged and must be rodded(snaked) out to cure problem
Nov 14, 2014 | Toto MS604114CEFG01 UltraMax II Toilet,...
Bathroom leaks from upstairs bathroom
There are several causes for this, but I need to know.... Which fixture leaks ( toilet,sink,shower/tub) ? If you don't know, you'll need to determine which is leaking. Is the wetness coming through the ceiling, on the floor, under the sink, etc.?
I'd like to help but I need more info.
Hope this helps!!
May 17, 2014 | Computers & Internet
Does Kohler recolor existing fixtures? Do you have pedestal sinks and tubs for art deco period such that one could get a light teal or purple tub or sink?
The companies don't recolor fixtures but there are bath refinshing outfits that do. There are also do it yourself kits to be had. I did a harvest gold shower once and it still looks good after 7 years.
Feb 08, 2011 | Kohler Overture 5ft Vikrell Bath -...
Do the saniflow toilet need to be plumbed in to mains waste? I have a patient who needs a toilet located outside the house that needs to be trouble free
Hi and welcome to FixYa, I am Kelly.
In short yes it will need plumbed with a smaller drain line to the home waste drain.
The unit uses a fast-rotating blade to reduce waste and toilet paper in the flush water, which is immediately and entirely released under pressure through "small-diameter piping" to the sewer or septic tank. No special maintenance is needed and the pump is sealed for life. This simple and cost-effective alternative to conventional plumbing is ideal for basement renovations and other home-improvement projects. Properly sized, a Saniflo macerating system can handle all the fixtures in a bathroom, including the sink, shower, tub and toilet & endash; even on a septic system. What's more, these fixtures will work up to 12 feet below and as far as 150 feet away from a septic tank or sewer line.
Go to this page and download the manual for the installation instructions:
http://www.saniflo.com/Downloads.aspx
These are all the installation downloads available on that page:
Installation Instructions:
SANIBEST SANIGRIND SANIPLUS SANICOMPACT SANIPACK SANIALARM SANISHOWER SANISWIFT SANIVITE SANICUBIC Classic SANISTAR SANITOP
Thanks for using FixYa,
Kelly
Jun 01, 2010 | Home
Toilet works fine,but drains for sink and shower stall drain very slow
hello there:
sounds like you may be having a partial block in you're drain lines do too paper and things being flushed down the toilet you may need to go to the outside of the house and find the cap on the drain vent and use an industrial snake and run threw the drain lines to get ride of the clog this should solve the problem you should be able to rent one from ace....hope this helps you out thanks
May 29, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Removing gold toned grab bars and fixtures from old whirlpool tub
sometimes a plumber leaves an access panel to get at the drain and jets under the tub---it's usually small and may not be enough to get a body in---usually the grab bars are permanently glued or siliconed on a fiberglass/plastic tub....a cast iron, or other non-plastic type tub may have removable grab bars...look for access area, or you may just have to cut out a piece of the wall to look----or if you do find a small access panel, and can get a telescoping mirror to look back at the back of the grab bar underneath the tub, you will find your answer----or you could contact the original manufacturer of the tub, and they can tell you if the grab bars are removable....another solution is to coat/paint/sandblast the metal bars however you'd like them to be
Mar 13, 2010 | Home
How to Improve Sanitary Conditions
You should use toilet seat paper covers. In addition to promoting sanitary conditions, the use of disposable toilet seat covers can also help your organization to save both time and money. When you consider the alternatives of toilet seats, it is easy to see how beneficial toilet seat covers can be. When visitors to your restrooms use the proper toilet seat covers, restrooms are more easily maintained.
Aug 27, 2008 | Kohler Flush Actuator K 9446 [ Bathroom,...
Samsung HCN653W 65" Rear Projection Television Logo
146 people viewed this question
Henry  Thomas
Henry Thomas
