Question about GE Ovens
While using my LP gas oven I hear a "poof" sound like a flame going out or lighting after about 20 minutes of use and through out the whole time I have it on. About every 15-20 minutes. Yesterday it made this same sound and then a very loud noise (like a empty semi trailer coming down the highway) I turned off my oven and within a couple minutes the noise stopped. I turned it back on only to hear this noise again. I turned it off. This morning I had a very strong odor of gas. Turned off gas supply. Returned home this evening and turned it all on. The oven lights and no noise but still getting gas odor if the gas supply is on even with the oven off. Turned gas supply is off again.
  • teejdew Mar 10, 2009
    Qualified tech??? Appliance repair tech or LP gas company???
  • GE Master
  • 3,361 Answers
You have a gas leak.
Call a qualified technician quickly.
Posted on Mar 10, 2009
  • steve
    steve Mar 10, 2009
    I would go with the appliance tech.
    Gas techs generally do not know appliance repair.
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
I bought a used 24 inch GE gas wall oven, changed it over from natural gas to lp and it will not ignite they glow red but no flame
Many times, unless you have the universal, the orficies have to be changed. From nat to LP. they do make a universal type.
Dec 15, 2009 | GE 24" Built-In Single Gas Wall Oven
Pilot light keeps going out when turning on oven
Sounds like the GSD. The Gas Safety Device valve needs replacing
Oct 17, 2017 | Ovens
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
GE PGB975SEMSS Broiler and Oven flames too large and yellow
It sounds like your not getting enough air mixed in with the gas.if you can't adjust for more air make sure you were not supposed to change the spuds that feed the gas on the lower units.
Mar 16, 2009 | Ovens
Oven makes poofing sound when in use
hi. thanks for the question .Yes the igniter is at fault here. replace it. thanks the appliance doc
Oct 02, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
IMPERIAL ICV-1 SINGLE DECK CONVENCTION OVEN
this is a common indication that the ignition module is probably going bad or the flame sensor is not sensing the flame on the burners. There are other, more technical issues possible but this is usually the most common. The "not restart" , if referring to the burners, is an indication that the ignition module has "locked out" the system, usually after 3 failures of attempts to light the burners.
Oct 31, 2017 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Oven slow to heat and top burners weak flame
sounds like you have a gas pressure /flow problem. id start with hte gas company have them come out and check you tank pressure(if using LP), or the pressure from reguator leading to home
Mar 13, 2008 | Ovens
Ovens Logo
722 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
