Back to:
Tags:
Epson Singleweight Matte Paper 44inX131 Multimedia Projector
Unexpected problem with Seagate factory refurbished...
By Riddle - usenet poster
I have had this experience now with 2 Seagate drives sent in for RMA
repair. As you probably know when they receive the defective drive
another refurbished unit is sent out (different serial number).
Both drives were 18GB SCA LVD's (ST118202LC). The replacements had
model ST118202LC on the label and looked identical but when queried by
the host adapter were SX118202LS. Also these refurbished units
operated at 40MB/s and not 80MB/s which the original units did. I can
tell since my host adapter card, Adaptec 4-channel 3400, reports this
info.
I was interested whether others have noticed this practice. I have not
called them on it yet as otherwise they have provided very good
service and I have had good luck with their products.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Jimmy NY
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If these drives failed soon after being purchased, you may be able to
get the seller to replace them with new stock and to treat them as DOA's
back to Seagate. Good to know for future reference.
Where did you buy the original drives? Seagate does not look at the
model number when they exchange drives, but at the top-level assembly
part number, which will be different for drives provided to various
OEM's. If your drives originally had OEM firmware and your vendor changed
the firmware to the standard/generic firmware, you'll get back the orig-
inal firmware when you RMA the drive, since that information is part of
the assembly number.
I've had drives that my local Seagate rep had upgraded to ASA-II code
from the ASA-I code, and when I RMA'd them, the replacements came back
with ASA-I code because that's what the label said.
I've RMA'd drives that were no longer made, and received newer (better)
models in return.
Without knowing what the labels said on your original drives, I can't
say if you ran into this particular issue. You should certainly call them
and find out what they think happened. Note that with the serial numbers
from the "in" column on the yellow sheet you got back with your drives,
Seagate can determine who the original drives were sold to, and if they
were OEM drives or not.
Terry Kennedy #
Jersey City, NJ USA
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Unexpected problem with Seagate factory refurbished drives:
I don't want to Accept this solution
Can you Help with these Multimedia Projectors problems?
How to reset the lamp timer on PJ506d, I can´t reset...
I have just turned on our 18mth old projector run with sky...
my OPTOMA EP774 keeps saying cant find source.. I tried to...
can u tell me how to make a professional template please.
all the bottons are locked
Loading problems.
Repair Service
Find Multimedia Pro. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
