Question about Dell Computers & Internet
Female receptacle in the computer broke
When i plug my working charger,i have checked, into my computer, the computer does not charge.
How do i replace the part where the charger plugs into?
  • 124 Answers
Unfortunately, you cannot replace just that one part. It is part of the motherboard. You'd have to replace the motherboard or get a new laptop. Sorry.
Posted on Mar 10, 2009
I have the Auvio Bluetooth speaker n can't find the charger..where can I order another charger for speaker at??
On the rear of the speaker, you should see a female receptacle, probably the same as your phone. the other end is a usb which would plug into the computer to charge or you can pick up a 5volt wall charger that the usb cable plugs into and the charger plugs into the wall. Any walmart, fry's, radio shack has the readily available.
Jun 02, 2017 | The Audio Players & Recorders
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
How can I determine whether the on-board charger is working?
The m51 is notorious for failure of the on-board charger. An easy check would be to plug an off board charger into the 3 prong female charging receptacle at the front of the joystick to see if you can bring the voltage up. You can test the on board charger with a voltmeter at the battery connections or charger joystick port with the charger plugged in. Hope this helps
Jan 13, 2016 | Invacare Pronto M51 Power Wheelchair
Charger works but cant get it to charge when plugged into my cart 48 volt
This can be one of several problems. Make sure charger works on another cart first. If it does then check total voltage of your cart, has to be at least 42 volts before charger will turn on. If you plug in the charger and it does not turn on then listen for a small click from inside the charger. That would be the relay and if it operates then your voltage is ok and you have something else wrong. If you don't hear the click then check the small gray wire at charger receptacle. It sometimes breaks just inside the receptacle, Without this sense lead, charger will never turn on. If all batteries, wiring, sense lead, fuse in the sense lead are ok, then it might be the OBC (on-board computer).
May 13, 2015 | Golf Cart Parts & Accessories Energy...
I do not have an owners manual for my Dalton power wheelchair. When hooking up the charger do I plug in the charger and then the chair or vice versa? And should the chair be turned on when its charging?...
You should plug the charger into the chair first, then into the wall receptacle. The chair should be turned OFF when charging. This will allow it to charge faster and completely. When charging is complete, remove the plug from the wall receptacle first, then from the chair.
Feb 26, 2011 | Health & Beauty
The female plug in my Compaq Presario (for AC adapter) is broken from the motherboard. Computer still runs, since the battery is about 90% charged. Cab this battery (it has 5 female terminals) be...
i cannot think of a commercial product designed for this. I believe that you either may need to send it in for repairs, or if the pin inside the female end is bent, try bending it back. BE CAREFUL.
Feb 09, 2011 | Compaq Presario 1245 Laptop Charger...
Battary not charging
I have experience this problem myself however replacing battery and charger does not fix the problem. it seems to be something related the power receptacle (where you plug the charger in the laptop) the solution is to replace the part, but that can be expensive
what i did, as a workaround, is to plug firstly the end of the charger that goes into the computer and then connect the charger to the outlet this for some reason makes the battery charge.
hope it can help you
Oct 29, 2010 | Dell Inspiron 1525 Notebook
USB port bad
sadly, i havent seen a usb port on a gps that has not ripped the tracers off the board, making a repair, impractical.
have you looked at the board to verifiy it can be repaired, if so, i might be able to lead you in the right direction to aquire 1 ...btw, doesnt this model (4250) also have the standard round female power port?
Aug 06, 2009 | Magellan Maestro 4250 GPS
Compaq presario v2000 charging plug melted and will not charge
The problem maybe with the electrical circuit. Find an electrician to check it.
Mar 18, 2009 | HP Compaq Presario v3000z Notebook
Computer wont charge. Plugged up and still wont charge. Is it internal, battery or charger?
I'm not asking if the computer will charge, I'm asking if when you have it plugged in does the computer operate normally. You should be able to take the battery out of a laptop and plug in the computer in and the computer should still operate.
Nov 07, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Alun Cox
